If the cluster has never been taken out since it was installed at the factory, then over time, the combination of heat, humidity, dust, and cleaning product residue has probably 'stuck' it to the dashboard. Use a dull, smooth, thin tool like a butter knife to carefully separate the cluster from the dash. Wiggle it into the crack between the dash and cluster slowly until the two surfaces begin to part, then slide the tool around the edges of the cluster to complete the separation. Work slowly and carefully and you won't scratch anything. You might have to 'help' it a little with the butter knife, but the cluster will then tilt out from the top.
'98 328 Alpinweiss Cabriolet, 150K, CD43, CHA-S634 MP3 Changer, Chromeline Interior Trim, 'Redlined' Gears & Diff, Z3 Chromed 16" Rims, Billet Front Stress Bar, aFe CAI, 'Golf Tee' Exhaust Mod, Powerdiscs, SS Brake Lines, CDV delete, JTD Underpanel, BAV Lowering Springs, Bilstien Sports, Bimmerworld Rear Lower Control Arms and Front Camber Plates, E46 RSM's with reinforcing plates, Electric Rad Fan, Alum. T-Stat Housing, Mishimoto Hi-Capacity Aluminum Radiator, Hi-Performance Water pump, 3.23 LSD, Sharked.
Sometime to come: New Clutch with LWFW, Clutch Stop, M50 Manifold, M3 Cams, Supercharger (I can dream).
