Hi Guys,
We completed some baseline runs on our Dynojet before the teardown for a new build with this car for much more power. Please do not ask what we are doing or using because we are doing some testing for a few manufacturers as well as our own products and can't discuss them with the public at this time.
Please note the following:
1. NO A/F Chart (We have all of our dyno 02 sensors in other cars that are being built/tuned)
2. Getty 92 Octane (no race fuel or anything else, Defacto M6 was with us when we got gas)
3. NO Water/Alky Injection
4. 1.5 Bar Boost
5. 50 Dg F outside
6. Raining Hard outside
We are very busy and might not be able to do Q&A as usual. These are the numbers before we go insane with this car, enjoy....
ICS Monster M3 Dyno Plot
Brian
- Brian Rosenberg
What was the turbocharger ? T61 i think but it is too small for such power - please tell me
A4 TDI
E36 powered by M5 3.8 S38B38 340hp engine
E30 M20 2.8 drag project
It is our usual 35R Turbo SetupOriginally Posted by KAMIKADZE
George
Gotta go build some cars, till then...
WOW! Awesome job guys!
1997 M3
1999 Z3 M Coupe - Turbocharged
Congrats again George very impressive other than the little blip from 6300 to 6500 what was that misfire or slight detonation as the other run did not have it.
Very impressive dyno for smoothing 0 and that's using 92 octane and no water injection
On this dyno what is the spec on this GT35.
AA Stage 1 Gen III, BMP head gasket, Bored Throttle Body, 3.0"DnPipe & Custom exhaust with AA Gen 2, Aquamist 1s water/methanol injection,
Last dynojet Aug 02 248c SAE 369whp/354ft-lbs at 10.5psi, 1/4mile 12.6@116mph
New Sept 02 Head work and exhaust porting, April 04:UUC Pulleys, Turbo to intercooler pipe 2.5" Aug 04 3.5"HFM,11.5psi
Gotta love mo power!
Can't wait to see this monster with the new setup...
That's insane
blahosidfnsd
wow....thats awesome
Topmount T4 GT35R
The blimp was a fraid wire on the dynojet inducter that grounded out. With W.I and some more timing I believe she has 30-40 more whp.Originally Posted by M3TurboCa
Thanks for the clarification George Maybe another 15 to 20hp with the water injection, if you are running the same boost with tuning of the a/f and timing.
But then again I am no tuner.
Good luck
wow, that is going to be one hell of a monster
ICS production!!!!!!
OLD:505WHP/516WTQ Dynojet
NOW:665WHP/638WTQ
Eurowerkz
PBMW mag 06/06
Now that is MO POWER Good work George. Now make another one
10 GTR R35
06 M5
04 330i zhp
93 318is
99 328i (Sold)
99 M3 Turbo (Sold)
Awesome #'s.. very impressive
1995 M3 Custom Turbo, Turbonetics T66 BB,72lb injectors, Sias Tuning PnP Tec 3, IBM T30,PLX M250 wideband O2 sensor,Blitz SBC-iD Built low CR 8.5:1 motor CP Pistons,ARP head & main studs,Metric Mechanic HP Valve springs,walbro 255hp,BMP FPR,Modified fuel rail # 6 SS feed line,3in ss custom magnaflow exhaust,Lower level turbo intake,AA six puck disc, Spec Stage IV PP ,AA differential bracket,AA strut tower brace,UUC UD Pullies,UUC short shifter,UUC tranny mounts,UUC clutch stop,Fluidyne HP radiator.M3 LTW wheels Est..1001 rwhp!
Http://members.cardomain.com/bassmasterM3
(DIY custom turbo)
I am sure this is a beginner question but why does one graph make peak power/torque at 4k rpms and the other make peak power at 6k rpms?
I am confused about the difference between the two.
-Richard
915whp '98 M3 Sedan /// 37k Mile '95 M3
Nice M3 you have there!Originally Posted by 95RogueM3
So are you talking about the first graph that the monster came out with before? If you happen to know the thread where that is...could you post both of them please so we can all compare?
Originally Posted by highboostingm3
No, i think he's referring to the chart above...and the difference between runfile_006 and runfile_009. One peaks power around 4K and the other peaks around 6K!
<font face="century gothic"><b><font size="2">2003 Alpine White M3...</font></b>
<font face="century gothic"><b><font size="1"></font></b><br />
The infamous "Paul E." and I after some detailing...
Thanks. No, I meant in the above graph the peak power outputs (2 humps) are similar in height (620rwhp) but one occurs at 4k rpms on the x-axis and the other occurs at 6k rpms on the x-axis.Originally Posted by highboostingm3
I think I am reading the chart right.
Originally Posted by ///M3ryder NY
-Richard
No, in that graph the torque and hp of file 6 occur much eariler than those of runfile 9. For one run the torque and power occur much eariler than in the second run.Originally Posted by highboostingm3
-Richard
I probably laid into one earlier than the other.Originally Posted by 95RogueM3
I see...
Rich, you and i were both looking at the graph incorrectly. The two lines that peak at approx 4K are both trq output in different runs... ie. light blue and dark red are both TRQ....
Ahhh. Thanks Chris.Originally Posted by ///M3ryder NY
Cameron, you were right..sorry about that.
George, thanks for the info. I need to come and dyno and go for a ride sometime.
-Richard
Anytime Richard.Originally Posted by 95RogueM3
