Dyno conditions:
74.87F
30.57 in-Hg
21% humidity
Video conditions:
Full tank of gas +Passenger
Racelogic videos:
Check out how boost builds in 1st and 2nd gears with racelogic kicking in and the speed build up.
3-4-5 gear boost build up videos are from 60mph on...3rd gear build up is actually sooner in the revs if the roll is from a lower speed.
Side note: fuel pump is acting on us and it will be changed with a different set up soon...
Happy New Year...
Dyno Graphs:
http://www.aatuning.com/temp/gt40r22psi.jpg
http://www.aatuning.com/temp/gt40r22psiSAE.jpg
Videos:
Boost build 3rd gear:
http://www.aatuning.com/temp/AAMcoupe3rdgear.wmv
Boost build 4th gear:
http://www.aatuning.com/temp/AAMcoupe4thgear.wmv
Boost build 5th gear:
http://www.aatuning.com/temp/AAMcoupe5thgear.wmv
Racelogic set at DRY gears 1-2-3
http://www.aatuning.com/temp/AAMcoupe123DRY.wmv
Racelogic set at 10% gears 1-2-3
http://www.aatuning.com/temp/AAMcoupe12310percent.wmv
Damm Omar you tease us with the hardware and I can't download to see your incredible car in action.
Congrats on your monster setups.
So it's you and Sean hogging Karl time/
AA Stage 1 Gen III, BMP head gasket, Bored Throttle Body, 3.0"DnPipe & Custom exhaust with AA Gen 2, Aquamist 1s water/methanol injection,
Last dynojet Aug 02 248c SAE 369whp/354ft-lbs at 10.5psi, 1/4mile 12.6@116mph
New Sept 02 Head work and exhaust porting, April 04:UUC Pulleys, Turbo to intercooler pipe 2.5" Aug 04 3.5"HFM,11.5psi
Technicalities, should be up soon..Originally Posted by mrdoenutz
HOLY SH*T!
That last video with Racelogic set @ 10 is INSANE!
EDIT: Also, your car HAS to be trapping in the 130mph range to be doing that. Simply amazing. Nice work.
nice setup i'm thinging of doing something like this in the near future.Originally Posted by OZ3M
WOW good stuff
Holy crap... that's fast.
Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
awesome.. what a monster.. esp in the little M coupe!
Omar, that's pretty amazing! Congrats man! (When's the race?!? ).
I must say, if you remove the AFR from that picture, past ~4.2k RPM it must be the best torque curve I've ever seen AA produce. That's 'textbook perfect' in my eyes.
I'm very impressed... congrats!
BTW, what type of gas was used to produce this?
Thanks,
Boris
'96 Cosmos Black M3 422rwhp/407rwtq SAE @ 13psi / 444rwhp/444rwtq SAE @ 14.5psi
Engine/Drivetrain: Technique Tuning Stage 2 Turbo TT Turbo Exhaust, M50 Manifold, TMS Oil Baffles, SSR Comps, SPEC Stage II Clutch, UUC SSK, Titanium Cavallino Ti-130R Shift Knob, UUC TME, EMC Diff Bolt, RCCA's. Suspension: GC Coil-overs, GC RSMs, GC RTABs, GC Trans Mount; H&R SB. Instrumentation: VDO Boost, VDO Oil Press, VDO Oil Temp, VDO Water Temp, BMW Traffic Pro Navigation, Valentine One TODO: W/A Injection
Mobil: 93...Originally Posted by ///3oris
Wow, very impressive! That little MCoupe is insane..
Very nice
1995 M3 Custom Turbo, Turbonetics T66 BB,72lb injectors, Sias Tuning PnP Tec 3, IBM T30,PLX M250 wideband O2 sensor,Blitz SBC-iD Built low CR 8.5:1 motor CP Pistons,ARP head & main studs,Metric Mechanic HP Valve springs,walbro 255hp,BMP FPR,Modified fuel rail # 6 SS feed line,3in ss custom magnaflow exhaust,Lower level turbo intake,AA six puck disc, Spec Stage IV PP ,AA differential bracket,AA strut tower brace,UUC UD Pullies,UUC short shifter,UUC tranny mounts,UUC clutch stop,Fluidyne HP radiator.M3 LTW wheels Est..1001 rwhp!
Http://members.cardomain.com/bassmasterM3
(DIY custom turbo)
I cant imagine being in a car that fast.
That is F'ing sick!!! I'm driving down to get a ride in that monster! Congrats to you and AA!
Wow, I'm speechless...
Maybe Karl can upgrade my little Coupe too!
Jamal
99 M Coupe
AA S/C
AA Track Pipe
GC Race Coilovers
Race logic is the traction control upgrade right? What does it mean when you say you have the race logic "dry" or at "10%"?Originally Posted by OZ3M
Ah...this brings back memories when I almost sh*tted in my pants in his car...
2008 X5 4.8i
2003 330xi -sold-
2001 X5 4.4i -sold-
2001 M5 -sold-
2001 M Roadster (SCed, Highly modified) -sold-
2000 M Roadster -sold-
1995 325is -sold-
Racelogic settings:Originally Posted by 96INFMSM3
wet, dry, 10%...
more here:
http://www.racelogic.co.uk/traction/
I had offered the ride to you before...let me know when you are in MiamiOriginally Posted by FLMCoupe
I love the acceleration past 100mph wicked
That was insane.
Omar your car is insane.
