Here is a comparison for the debate of how capable the GT35R is compared to the T61. Same car (mine), and same setup minus the turbo swap.
T61 run is at 20 psi. The turbo is the standard trim AA uses.
GT35R runs are at 19 psi. The turbo has a 0.82 housing, not the larger 1.06.
In the GT35R runs, it was spinning the tires on the dyno with Nitto drag radials on the car.
http://www.icsperformance.com/Cust%2...%20v%20t61.htm
Very nice comparison Josh. It shows that the compressors flow about equal amount of air... but the GT35R has much better spool... it probably has a smaller Turbine than the T-61 (or probably clipped for crappy spool with a low A/R). What are the complete specs on the T-61?
Thanks,
Boris
P.S. Nice numbers... your car is a monster!
'96 Cosmos Black M3 422rwhp/407rwtq SAE @ 13psi / 444rwhp/444rwtq SAE @ 14.5psi
Engine/Drivetrain: Technique Tuning Stage 2 Turbo TT Turbo Exhaust, M50 Manifold, TMS Oil Baffles, SSR Comps, SPEC Stage II Clutch, UUC SSK, Titanium Cavallino Ti-130R Shift Knob, UUC TME, EMC Diff Bolt, RCCA's. Suspension: GC Coil-overs, GC RSMs, GC RTABs, GC Trans Mount; H&R SB. Instrumentation: VDO Boost, VDO Oil Press, VDO Oil Temp, VDO Water Temp, BMW Traffic Pro Navigation, Valentine One TODO: W/A Injection
WOW! :hotflash
Thats awesome. Thanks for sharing.
Josh, quick question on this run. I'm assuming YES on all these but just thought I ask to confirm.
1. Was this on full race gas.
2. Was this on open pipe (no cats).
3. Was this run still on the 440cc injectors?
Oh... is it possible to post the corresponding AFR's for those runs please? I'm more interested in the low end where you get the better spool.
Thanks,
Boris
Hey Jon...Originally Posted by jonsibal
1. Pump Fuel - 93 Octane
2. No cats
3. All of these runs are on 550cc injectors
I was by Ics thursday and seen your dyno sheet, the #'s were real good.
Boris, I'm not entirely sure what the trim is on the T61. Perhaps someone here that has a Stage 4 AA kit can chime in on that. In terms of spool though, the difference really is huge. Having driven both for a good amount, I would say unless all you do is highway driving, the T61 is a not good a choice for our cars. It is quite laggy and unpredictable.
I do not have the A/F graphs here but can say that the car is tuned a little rich to help deal with the super cold weather we have now. I'll see about getting them.
Awesome, thanks Josh!
So I take it you're out driving about in that little monster these days? Hows about we hook up, I want to check it out!
Boris
Should be picking up the car next week from George. The final tuning was finished yestarday. Hopefully the weather will hold.
Congrats Hope next time I see you you bring her alongOriginally Posted by Josh
Boris
Originally Posted by ParadigmGuy
Factory OBD1 ECU with custom chip.
Why not stop by to Ics performance to check it out, also this car made 440rwhp and 405 torque on 10 psi (untunned) for the 10 psi. And believe me there is room to grow still on this turbo a/f was very very conservative.Originally Posted by ///3oris
We went over that before, George... if you want to talk, you know how to contact me privately.Originally Posted by IMPORTEDCARS
Boris
I only asked if you wanted to see for yourself, I never said anything about talking, anyway in going to make 400whp tonight with Seans car tuned @ 7 psi, so I can show you, ill video it also, like we spoke before.Originally Posted by ///3oris
The car we talked about before made either 430 or 440rwhp @ 13psi... you were claiming it'd do over 400 @ 7psi . I'd love to see the video though...Originally Posted by IMPORTEDCARS
Boris
Great comparsion Josh. If only wheel spin could be avoided and we could see an actual HP peak... wheel spin at 4000rpm .
You have one amazing car... one of the the nicest in the area
Bayerische Motoren Werke
That car made 455whp on 13 psi stock internal's, and believe me it could make much more, but.... stock internals again.Originally Posted by ///3oris
I would add: in the whole of of this great US of A.Originally Posted by ///BimmerPower
Now there is some useful information, thanks for sharing. It would be great to get more real life comparisons like this where possible.
.-=[ Kenny ]=-. See the BFc Drag Racing Standings List for BMW street cars. Watch my drag racing movies on YouTube. Some info on
BMW turbo street car Drag Racing 101
Hey Kenny when are you going to post your Dyno sheet! Id love to see it.Originally Posted by MrBlonde
