Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > Car Detailing and Show & Shine Prep sponsored by Autogeek.net
Car Detailing and Show & Shine Prep sponsored by Autogeek.net Keep your BMW always looking its very best. Discuss the best detailing methods and get tips on that prize-winning shine from Autogeek.net - At autogeek, We Are Car Care.
Autogeek.net Car Care Products
** 10% off @ Autogeek.net - PinnacleWax.com & Wolfgangcarcare.com - Coupon Code = clubmember
Old 09-18-2004, 12:35 PM
Yuen's Avatar
Yuen Yuen is offline
Break My Wallet
Cars: 1992 E36 320i
DIY Write-up: Cleaning E36 Bosch Ellipsoid Lenses
Last weekend I decided to take apart my Bosch ellipsoid headlights (that came stock with my Euro car) as the lenses had gotten dusty throughout the years. Here is a short write-up on the it. I thought some of you might find it useful.
1. Firstly, you have to remove your corner lamps. Remove the indicator lamp bulb, then use a screwdriver to pry the clip that holds the indicator lamp free. Slide the indicator lamp out forwards.
2. You can now remove the headlights. To do so, you need to remove the 3 screws that are on the top, and two on the side. On my car, they were all Phillips screws. The screw below the indicator lamp area is quite hard to get to. It would probably be relatively easy if you have a short Phillips screwdriver.
Pull the headlamp out towards you, then disconnect the connectors. Set your precious headlamp down on a soft, gentle surface!
3. There will be 2 small metal clips on both the top and bottom of the ellipsoids. Unclip them by prying them off with a flathead screwdriver. Remember to pry from the plastic end because you might break/chip the glass if you apply too much force on it.
4. Unhook the 5 big plastic clips (3 on top and 2 on the bottom) with a flathead screwdriver.
5. You should now be able to separate the lens part from the reflector part of the headlight. Pull them in separate directions. They might be tight, so wiggle them free.
6. This is how your headlight will look like when it has been opened:
7. Notice that both lenses are held in by factory silicone. Using a blade, slice them off. Your lenses should now fall out quite easily. If they don't, you can use a flathead screwdriver to gently nudge it out. Be very, very careful!
8.
Clean the insides of the headlight thoroughly. I sprayed window cleaner then used newspaper to wipe it clean. You may want to wipe the projector for the low beam as well. Remember to wipe underneath the projector lens! You will see a definite improvement in clarity.
9. Make sure you have gotten rid of most, if not all, of the factory silicone. Put the lenses back into their original positions. Double check by looking at the orientation of the other headlight. Now, apply new silicone (I used Selley's Marine Sealant silicone) to the rim of the lenses (where the factory silicone was before). Let the silicone dry, then make sure the lenses are secure.
10.
Double check for any smudges on the glass, then reassemble in the reverse order of disassembly.
Now, let's make a comparison:
Dirty Left Ellipsoid
Clean Right Ellipsoid
At this point you'll say "That was worth it!"
Old 01-20-2005, 05:53 AM
doodle doodle is offline
Cars: '04 330ci zhp
Bump.. I just found this by accident, but props for the DIY. I also notice my headlight is pretty dirty like the picture of your left ellipsoid, but I had just guessed it was the Stonguard or something.
Since I'm going to be removing my inner lenses just to see how it looks, I'll give this a try :.
Old 01-20-2005, 10:04 AM
Yuen's Avatar
Break My Wallet
Cars: 1992 E36 320i
Cheers. Are you running ZKWs? I'd be interested to see how different the inside of the ZKWs are. Let me know how it turns out!
Old 01-21-2005, 08:54 PM
Daved's Avatar
Daved Daved is offline
Moderator
Moderator
Cars: 5/94 Euro 325i coupe
This is great write-up. I should clean my Bosch's too, they look like your dirty headlight pic.
Do you think it's really necessary to apply the silicone?
25/May/1916 ~ 26/Jun/2006 RIP grandma
Originally Posted by ClintonM3 View Post
the Audi A4 is a tweaked, cosmetically enhanced, cross platform, put-together overnight VW.
Originally Posted by joeuser528e View Post
Staggard setups are for cars that you park at show meets. They go well with 5 screens and 3 12"s.
Old 01-23-2005, 06:54 AM
Yuen's Avatar
Break My Wallet
Cars: 1992 E36 320i
Thanks! Yeah you have to apply the silicone, because without it, the lenses will be loose and fall out. Plus I think it prevents the headlights from getting fogged up that easily. After I cleaned them, the left headlight had condensation on the inside one cold night when I parked it outside, but it went away by itself and never came back again. I'm not sure if that means that I should have applied more silicone. Since it never came back, I can't be bothered to check, but I might the next time I have to remove the headlights.
Old 08-26-2005, 08:41 PM
e36 e36 is offline
-Mike
Cars: '92 M50318///M, '93 525, '85 325e
Send a message via AIM to e36
looks great!
mike
::::318->M50 Swap::///M Body Kit::Bekkers Coilovers::BBS Wheels::Euro Clears:Bosch Ellipsoids:::
SOLD!
Old 08-27-2005, 05:57 AM
Yuen's Avatar
Break My Wallet
Cars: 1992 E36 320i
Thanks Mike
This is a bit of an old thread now!
Old 08-27-2005, 09:07 AM
RhInO328i's Avatar
RhInO328i RhInO328i is offline
Aussie E36'er
Cars: 1995 328i Black 2 Door
I did this today while I was installing my Angel Eyes - WOOH (pics coming soon)
Lighting: Red/Clear tails & Clear Side Markers/Umnitza Chromium Angel Eyes/6000K H1 Prolumen HIDS/White LED Interior Upgrade
ICE: Alpine Amps/Subs/HU Focal Fronts & Splits Eclipse Rears Custom sub boxes.
Styling: Black/Chrome 97+ Grills
Old 08-29-2005, 08:49 AM
Yuen's Avatar
Break My Wallet
Cars: 1992 E36 320i
Where the pics at?
Old 09-11-2005, 02:18 AM
toolateseeya toolateseeya is offline
Cars: '97 318is
hey, some pics would be great!
i have these bosch headlights and i am stuck in the middle of installing angel eyes.
i cant seem to seperate the glass front from the black backing.
i have tried installing the angel eyes through the back by removing the inner glass rings as in the above pics, but cant put pressure on them to get them to glue to the inner glass since the front glass is still on!
does anyone know if the front glass can be removed off the bosch headlights?
i've tried heating for 15mins @ 100c but they wont budge
any help would be greatly appreciated
cheers
Old 10-20-2005, 02:21 PM
kabal kabal is offline
Cars: 03 AW E46 M3
I also have bosch in my euro 328i.
any tips on cleaning the "rectange" glass cover?? mine are a bit pitted.
e36 Alpine White Club member #2
E36 328i AW/DG - RiP
E46 M3 AW/Bl -
Old 10-21-2005, 06:44 AM
Yuen's Avatar
Break My Wallet
Cars: 1992 E36 320i
If you mean cleaning from the inside, you'll have to spray some glass cleaner in the 2 lens openings (after you've taken the lenses out of course ) and use a paper towel or newspaper to wipe it. That'll get rid of the filmy oily layer that has built up over time.
Old 10-21-2005, 06:48 AM
Yuen's Avatar
Break My Wallet
Cars: 1992 E36 320i
cheers
Hmm, this reply is kinda late, better late than never
I have not tried removing the front glass from the black plastic. I have not done an angel eyes install before, but I think you can put the CCFLs onto the lenses, then put the lenses in. The wire can then be run from the top of the glass lenses, I suppose, as they do have some room around the lenses (which is why you need to use silicone to keep them from falling out).
Old 10-25-2005, 01:14 PM
manuelku's Avatar
manuelku manuelku is offline
Cars: 95 Daytona Violet M3/2
Send a message via ICQ to manuelku Send a message via AIM to manuelku Send a message via MSN to manuelku
does it work on stock US specs headlight? the headlights are so yellow, making ultrawhite light blubs yellow too.. -__-
95 M3/2 DaytonaViolette` 5spd |-Hamann HM2-|-Dinan chip-|-stock-|
Old 11-03-2005, 05:01 AM
Yuen's Avatar
Break My Wallet
Cars: 1992 E36 320i
Wow. THAT yellow? No it doesn't work on stock US headlights unfortunately. Yours are plastic. Ours is glass... I'd suggest you buy new headlights. They make a world of difference according to the US guys. Ellipsoids, ZKW, Bosch or Projector36.
Old 11-03-2005, 06:42 AM
Kaiv Kaiv is offline
Custom User Title
Cars: E46
Thanks for this DIY I'm definitly gonna do this
Old 12-23-2005, 04:51 AM
Cars: 03 AW E46 M3
ok so no one know if it is possible to replace the front glass cover of the Bosche headlight?
Mine are a bit pitted, but I can get brand new glass covers (not Bosch) for about $55 for both at my local aftermarket store.
E46 M3 AW/Bl -
Old 02-07-2006, 02:03 AM
Yuen's Avatar
Break My Wallet
Cars: 1992 E36 320i
Actually, I think Umnitza sells them, if they don't, I'm sure the dealer will, but probably at a higher price.
Old 02-07-2006, 05:06 AM
RhInO328i's Avatar
Aussie E36'er
cheers
Read my write up. It's for Chromiums but the basic steps are the same - you shouldn't try and separate the glass front from the front of the headlight.
Writeup - http://forums.bimmerforums.com/forum/showthread.php?t=479600
Old 03-11-2008, 04:31 PM
S1Driver S1Driver is offline
Cars: Martini BMW E36
A big thanks from England! I want to install yellow transparent tint, but got stuck once I opened the headlight. Didn't want to install from the bulb side as if it gets too hot it will melt it. The part where explain that silicone is removable and easy to assemble helped me a lot. Is normal bathroom sealer ok to do them up afterwards? I might only have white and I'm worried it will show through!
Old 03-11-2008, 05:06 PM
Yuen's Avatar
Break My Wallet
Cars: 1992 E36 320i
Does it say what temperatures the bathroom sealant can withstand? That would be my main concern. From memory, the sealant will not be visible from the front if you don't overapply it. Since you have the lights open, have a look at the areas where the sealant goes and see if you can see them from the front.
Btw, if I were to do these again I'd use a hair dryer to just blow dry the inside of the headlight and lenses before reinstalling. I read somewhere that this will get rid of excess moisture and prevent fogging later on, it's worth a try.
Old 03-11-2008, 07:04 PM
Ok, I've removed it and just used a heat gun to remove the old OEM glue/silicone stuff. I had a look from different angles and I don't think that part will be visible, maybe only if it's very bright rainbow colour and you look from the side of the glass. White won't be a problem, plus I already got a white BMW . As for the bathroom sealer I don't think temperatue would matter that much as it doesn't get extremely hot. It's only there to hold the glass anyhow.
Old 11-27-2009, 07:53 PM
M3C's Avatar
M3C M3C is offline
Cars: BMW M3
Re
I am mounting Bosch headlight on my US E36 M3.
Some questions that I am not clear, can someone please reply on the following:
1.Bosch E36 headlights have stamped on the rear "24V", what does this mean, is it some kind of additional part that is required in order to provide 24V or they can be plugged into car's standard 12V?
2.The front glass covers have 2 top and 2 bottom metal clips that looks they hold the glass to the headlight. If these clips are removed can the glass be removed or it is permanently glued to the headlght?
I am sking this for cleaning and/or adding angel eyes.
3.Is it safe to use silicone as some hig tem is there. Is it better to use hi temp RTV gasket material.
4.Some mounting tabs are broken. This is a major problem. What epoxy or bonding material would be good to use for tab repair. It is really small area to be glued so it has to be super strong material to hold the broken tab parts.
Old 03-16-2010, 04:48 PM
krugerblue krugerblue is offline
Cars: E36 320i Coupe
Does anybody know if I can just get rid of the lenses ?
Newer cars do not have those lenses anymore, but other than that the headlight looks just the same.
Old 03-28-2010, 08:15 PM
I got rid of the lenses themselves, and the improvement is even greater.
