Well we are getting closer to my boost leak problem. Seems the BOV spring was getting weak and we had to tighten the screw in just a little. Its holding 19 psi but we need to turn it up to 20 psi after making sure all other possibilities are looked at.
This is also the first time I have gotten to dyno the car running like its suppose to with the built motor. AA built the motor with forged internals, knife edged crank etc. I will dyno again once temperatures start to cool even more to see the difference. I never thought the car was making this much power.
BTW, George at Imported I appreciate your suggestions, I guess it ended up being the BOV after all. We will see.
BBS RC 18X8.5 et13:245/40/18:Koni SA/H&R Sport/M5 3mm Upper Spring Pads/M5T 25mm/20mm Swaybars/Racing King Subframe Inserts/Magnaflow High Flow Cats/Magnaflow Exhaust/3 Inch Tips/Euro Clears/32%Tint/40% on Windshield/6500K HID H1's Headlights and Fogs/Depo Smilies/Factory Shadowline Trim/Shadowline Grill/93 Octane EAT Chip/M5 License Plate Holder/UUC Short Shift Kit/3.15 LSD/ More to Come...
Great results! Very nice
What kind of dyno was this on?Do you know what that spike at 3800 RPM is?
Anyway, congrats
Boris
'96 Cosmos Black M3 422rwhp/407rwtq SAE @ 13psi / 444rwhp/444rwtq SAE @ 14.5psi
Engine/Drivetrain: Technique Tuning Stage 2 Turbo TT Turbo Exhaust, M50 Manifold, TMS Oil Baffles, SSR Comps, SPEC Stage II Clutch, UUC SSK, Titanium Cavallino Ti-130R Shift Knob, UUC TME, EMC Diff Bolt, RCCA's. Suspension: GC Coil-overs, GC RSMs, GC RTABs, GC Trans Mount; H&R SB. Instrumentation: VDO Boost, VDO Oil Press, VDO Oil Temp, VDO Water Temp, BMW Traffic Pro Navigation, Valentine One TODO: W/A Injection
Please use something else to host dyno sheet. We can't see it & Imagestation has had problems many times before.
Try this site!!!
http://imageshack.us/index3.php
Thanks,
Cameron
:eek Fastest E36 M3 ever (street driven)!
Wheels in Sig are SSR GT3's 19" E46 M3 fitment. Dinan E46 M3 Suspension. Pic thanks to Kyle K.
Yeah, I agree... I can't see pics many times when people host it on "NWS" servers (including this one).Originally Posted by highboostingm3
Boris
I can see any pictures nor results so this post is useless!
Alan
2006 325i
2015 M3
That looks pretty good. We will see how my car does really soon on race gas and 20+psi.
Turbo '99 M Roadster
11.49@130.4 and 570whp@16psi on a stock m52 shortblock.
WTB: Low compression M52 pistons & GT30r or 35r
FS: PT-67 DBB turbo, freshly rebuilt
PM me with questions.
Wow... :eek
Congratulations, now you need to update your signature!
What was the result? I cant see it either.
1995 M3 Custom Turbo, Turbonetics T66 BB,72lb injectors, Sias Tuning PnP Tec 3, IBM T30,PLX M250 wideband O2 sensor,Blitz SBC-iD Built low CR 8.5:1 motor CP Pistons,ARP head & main studs,Metric Mechanic HP Valve springs,walbro 255hp,BMP FPR,Modified fuel rail # 6 SS feed line,3in ss custom magnaflow exhaust,Lower level turbo intake,AA six puck disc, Spec Stage IV PP ,AA differential bracket,AA strut tower brace,UUC UD Pullies,UUC short shifter,UUC tranny mounts,UUC clutch stop,Fluidyne HP radiator.M3 LTW wheels Est..1001 rwhp!
Http://members.cardomain.com/bassmasterM3
(DIY custom turbo)
It looks good... finally the cursed boost problem is being resolved.Originally Posted by slvr98 M
I was checking the dyno sheet at AA and noticed that your torque peak is coming up about 500 rpm sooner...did you change anything after the car left AA or is this a result of a different dyno? Do you remember the conditions of your last dyno at AA? how much HP and TQ difference you think you have between your last* dyno at AA and this one?
This clearly shows that there is a significant difference in the numbers...
WOW that's alot of power
Kevin
Just say no to slow Ayrton Senna "The Best"
For those who can't copy and paste this: http://www.imagestation.com/picture/...0.jpg.orig.jpg
he's making 524.1 rwhp and 532.4 torque at the wheels on only 19 psi
Whoo that is some solid numbers there congrats.
Im glad that you found the problem and back on track enjoying your car.
Damm you mean rasta man George does know what he is talking about is he Santa brings joy to his customers cars
Boris spike could be from his dual aquamist nozzles spraying tire slip ?? No big deal anyways look at his incredible power.
Ps: Silver was the 480rwhp done at AA on the mustang at the same boost 19psi and this is a different dyno or was there work done recently.
Im wondering when you dyno the cars on a mustang and the higher the rwhp if there is more loss or is the load factor turned off comapred to a dynojet you just spin that sucker up.
AA Stage 1 Gen III, BMP head gasket, Bored Throttle Body, 3.0"DnPipe & Custom exhaust with AA Gen 2, Aquamist 1s water/methanol injection,
Last dynojet Aug 02 248c SAE 369whp/354ft-lbs at 10.5psi, 1/4mile 12.6@116mph
New Sept 02 Head work and exhaust porting, April 04:UUC Pulleys, Turbo to intercooler pipe 2.5" Aug 04 3.5"HFM,11.5psi
Holy hell, that is some great numbers, especially considering you're only running 19 psi and have been having boost issues. What CR are you running?
I call BS - there's no bmw driver that can't run his car faster than any magazine has ever done before.
-Joe
Dammmm :eek :eek Great numbers Kenal congrats
10 GTR R35
06 M5
04 330i zhp
93 318is
99 328i (Sold)
99 M3 Turbo (Sold)
Originally Posted by OZ3M
Omar I think the temperature difference and the difference in dyno's made the difference. It was 95 degrees in Miami when it was dynoed there and 75 degrees here in Atlanta. I think my wheels were slipping on the mustang dyno but didnt on this one. There is about a 50-60 hp difference between the last and this one. The car is still being tweaked, not tuning wise but to locate the boost problem that I have been noticing. I havent hit the 20-21 psi mark that I am used to seeing yet maybe this afternoon we will get it there. There is still more power to be made.
Also, it is VERY humid right now in Atlanta...
I think the rollers on the mustang are different than the rollers on the dynojet resulting in possible wheel slip. Im not too sure. Again we have to obtain a consistent 20-21 psi before we are done.Originally Posted by M3TurboCa
Great numbers, glad I could assist you, let me know if I can help any other way.Originally Posted by slvr98 M
Well Kendall I hope you find and fix any problems that you are having quickly and damm I can not imagine what 19 much less 20 or 21 psi feels like.
How the does the car drive straight when you wot 3rd gear or even 4th. I can tell you that with the little power I have when the temp is cool low 60'F the car feels scary.
Up here in Canada where some of the roads look whiter mixxed with some concrete on some parts of the roads compared to the black asphalt the car is already scary once the boost and torque kicks in.
So stoked that I can't see the dyno sheet!
Can you please host it here for goodness sakes!
How about now.
That is what Karl is saying as well...Originally Posted by slvr98 M
As an example my gearing is good for 115+mph on 3rd but the dyno does not register anything over 104mph while testing, however we were able to see 110+ on 3rd when we tested for roller speed vs speedometer check they were identical. On a regular run I see the speedometer hit around 112-113mph at the end of the run, while it registers about 10mph less on the dyno. Tires get extremely soft and sticky after the runs...
I need to get my car on a dynojet as well...maybe then I can see a difference between 20psi - 24 psi
