I've just finished making my very own heat shield. Hope some of these pictures can help those who wanted to do it. I used a plastic cardboard measure and cutted to fit. Make sure there is no gap. So the hot air can't go thru it. Then use the sponge with aluminum foil (purpose is to reject the heat from the engine) to glue them together with the plastic cardboard and cut into shape. Finally fix everything in place.
I use a computer's temperature sensor to test it. It reduce 10 degree celciuos after installed the heatshield on idling. It will reduce more when driving ofcause....
OO=00=OO
Calvin Tan
Eurocar Motorsport - automobile Technik
www.EurocarMotorsport.com
http://www.geocities.com/calvintan_e30
More pictures
OO=00=OO
Calvin Tan
nice!
ford truck
nice work - paint it black and put a rubber edge around it and it'll be perfect.
I can't paint it, because the plastic is soft. The paint will crack and peel off piece by piece. Also the sponge is too thick to put the rubber edge. But thanks anywayOriginally Posted by Zoso
OO=00=OO
Calvin Tan
What about that Krylon (sp?) spray paint? It is supposed to bond, molecularly, to plastic.
Have you felt a difference on the butt dyno with the headshield installed?
I'm not sure where to buy the krylon sp.? Actually I haven't test drive it yet. Just tested at idle with the bonnet closed. Because I've just finished installed it few hours ago. Maybe will try tommorrow, it is too late to test....12pm at night now in Malaysia...Originally Posted by Zoso
By the way how can I put an Avatar on the forum?
OO=00=OO
Calvin Tan
Go to your "User CP" (near top left of the page). There is an option for avitars in there.
The Avatar feature has disable, I can't check the box.... Do I need to get approval or something?Originally Posted by Zoso
OO=00=OO
Calvin Tan
you need 100 posts i think
Rob
Yeah, now that you mention that, it sounds very familiar.Originally Posted by Rob
about the avatar, theres definately nothin about 100 posts. ive had one since ive joined and i still dont have 100 yet as you can see.
