| E36 Common Problems and DIY Fixes E36 DIY Instructions - Documents instructions on how to take certain tasks. Pictures are normally included. |
Thread Tools |
installing immobiliser to e36 ( under construction)
so you want to install immobiliser like this one?
if you know how to solder wires then i think you will qualify ![]() step first open up fuse box, you will want to make thieves life as hard as possible. you need torx screwdriver. unscrew two front screws, be careful, apply pressure, do not break torx pattern on heads.also open drivers side under dash to get acess to wires and screws that hold fuse box in place. unscrew these 4 screws to get fuse box loose ![]() now you can get acess to fuse box rear screws. unscrew them carefully. open the box ![]() now its time to locate circuits that you will immobilise for example green/purple wire coming from fuel pump fuse (17)is ideal. measure voltage on wire( test light or tester one lead grounded): ign off- no voltage ign on- no voltage crank and run- +12 when car running, cut the wire- if engine stops( after couple seconds), you have found right one. you can connect it temporarily together to locate another circuit after that connect it to immo as on its wiring diagram ![]() second circuit can be ignition for ecu it is green wire going from connection point to engine harness connector outside fuse box it has power when ignition is on if you cut it engine will stall immediately, remember that there are couple wires in that connector cut the right one, if you miss, connect back and be more careful next time ![]() now connect it to immo wiring ( connect now fuel pump wire too) remember power comes from ignition lock and goes to engine harness: twin wires for immobilising, third ignition sense for immo ![]() power up immo: red pernament power brown ground ![]()
solder all wires
![]() cut sharp edges ![]() isolate all connections ![]() locate drivers side door switch wire near drivers side speaker brown/gray/yellow ![]() never connect immo circuits on steering column. it is too easy to reconnect ![]() install led and antenna into center console. antenna can be located anywhere where you want, it does not work through metal ![]()
wiring diagram
sweet. It's up on the page now
1995 BMW318ti (sold)
2006 Acura TL A-Spec (sold) 2006 Mercedes CLK-350 (sold) 2006 BMW 330Ci (SP, CP, 6SP, UUC Evo3, Orion V2, ACS-R Lip, RE DMS) (current)
Re: installing immobiliser to e36 ( under construction)
Uhh, what's an immobilizer?
nice write up man,,
Thats why the call it"The ultimate driving machine"
Hallo,
Somebody help me with bmw imobilaser instalation problem. Did anyone have an instalation manual for pat. No. 82929402597 |
nice write up cheers.
nice write up cheers. I
nice write up cheers. I knew
nice write up cheers. I knew a
nice write up cheers. I knew a guy
I thought the "code" feature on the OBC was an immobilizer....
pics plzz
-Dr. Seuss |
i just uninstalled that kind of immobiliser.
but now, the car only starts when the drivers side-door is open(!). any ideas? |
| Bookmarks |
| Thread Tools | |
