Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1991 - 1999 (E36) > E36 Common Problems and DIY Fixes
E36 Common Problems and DIY Fixes E36 DIY Instructions - Documents instructions on how to take certain tasks. Pictures are normally included.
Old 07-17-2004, 08:41 PM
Robstah Robstah is offline
Do you like to DIY?
Cars: 2K M Roady, '86 944T
DIY: Replacing Door Handle Trim
Recently I have noticed that a lot of people are asking how to remove the old nasty door handles either to replace them with new ones, replace the cracked rubbers, or to just repaint them to make them look nicer. Anyway, after finding out myself, I decided to create this DIY. It was hard to take pictures of the inside of the door, so bare with my on the pictures.
What you need:
- Flat head screw driver
- Some type of hooking device, coat hanger whatnot
First things first, open the door of choice, and you will notice a little grommet. (Yes, e36 door panels blow )
Remove the grommet with the screw driver to be able to access the "Slider".
Here are a few more pictures of the "Slider".
To help people understand the purpose of the slider, I drew the slider's location based on looking at the door. For instructions, push the slider towards the front of the car to release the old door handle piece. To install the new one, place your hook in the proper position to pull back on the slider and hold in the new piece up against the car (you could also grab a friend to hold it in for you). Pull towards yourself (or towards the back of the car) to lock the slider and hold the new piece in place.
I hope all this helps.
Rob | 2000 BMW M Roadster (practical daily) | 1986 Porsche 944 Turbo (so fast, it can't get out of the garage)
"The problem is it rolls, so I thought I had to make up time in the straights, and then it developed a misfire."
Old 07-17-2004, 09:13 PM
stoo stoo is offline
Cars: 320i SE
Great write up!
My recent post asks how to do this on an e36 coupe. The slider doesnt seem to be accesible through the hole, without taking the darn window out and taking the door apart. Anyone any ideas?
Old 07-18-2004, 04:49 AM
nathan's Avatar
nathan nathan is offline
Cars: E36 Bmw
you kick ass..
thanks..
when i wanted mine painted..
i read how to take em off in the chilton manual.. and it was super shit..
i ended up just slowly prying each one off..
And breaking every fukin clip..
mine are held on by tape.. gosh..
-nathan
Old 08-21-2004, 09:10 PM
custom custom is offline
Cars: bmw 325is 94
haha nathan thats getho. at least you didnt buy new covers for the rear doors on a 4 door, have them painted, and then realize that they dont fit!
Old 01-10-2005, 09:34 PM
ziggysux ziggysux is offline
Cars: Brilliantrot 1992 325isA
Originally Posted by stoo
Great write up!
Bump for the coupe.
Old 01-11-2005, 08:35 PM
uuc328's Avatar
uuc328 uuc328 is offline
Cars: none
Originally Posted by ziggysux
Bump for the coupe.
Old 02-08-2005, 01:56 PM
bigbilly's Avatar
bigbilly bigbilly is offline
314 FTW
Cars: 1998 328iC, 1987 M6
Luck with a 'vert (coupe too?)
I finally got lucky finding the "slider" on my 'vert. There is a "gasket" hidden behind the rubber trim on the door, but it's pointless to bother with b/c there's a piece of sheet metal that blocks access to the slider anyway.
After screwing with the gasket access I finally gave up and took the trim and soundproofing off the door from the inside. I tried looking with flashlights and mirrors and couldn't find the hooked end of the slider, but could easily locate the other end (towards front of car).
I was able to cram my hand into the hole and felt above and aft of the lock mechanism. You can just feel the hooked end of the slider and with some effort, push it forward. After that the hardest part was holding the trim on with one hand outside the door while working the slider from inside.
For some reason the driver's side was harder to do - not sure if the parts are different (why would they be) as I'd already reassembled my passenger door. Luckily a buddy came over and helped by holding the trim in while I futzed with the slider. I ended up using a screwdriver to pry it into place from the "front" (non-curved) end as that area is easier to see.
It was a minor pain but much better than taking the door apart...
BigBilly
Hellrot 1998 328iC
Deletes: CDV, Wood Trim, E36ME's ASC-ectomy, Mudflaps | Undeletes: Fan (after one rebuilt head, can you blame me?)
Adds: aFe CAI | BMW: Brake Upgrade (e46/330) - Hardtop - MTech Front Spoiler - MTech Euro 3-spoke Steering Wheel - MTech Mirrors - M50 Manifold - S52 Cams | BSW ib108 Subwoofer | Diffsonline 3.46 LSD | Eurosport: M50 Manifold Kit - S52 Cam/M50 Manifold Software | UUC: Big Boy v2.0 - Black TME - DSSR - ERK - EvoII SSK - RSC36 Exhaust - Sachs Stage 3 Suspension - SS Brake and Clutch Lines - Strutbarbarian - SwayBarbarians - Underdrive Pulleys | ZKW Euro Ellipsoids w DDE
Waiting to install: CF Trunk Lip Spoiler
Attention convertible owners: Please post all e36 convertible-related questions in the "Convertible Questions" e36 Subforum.
Old 02-08-2005, 04:44 PM
uuc328's Avatar
Cars: none
thnx man, nice to know...too bad i already returned the parts
Old 02-08-2005, 04:51 PM
Boost Infection's Avatar
Boost Infection Boost Infection is offline
SPEED KILLS DRIVE A HONDA
Cars: E36, E39&E34 Touring,E39 540
Nice write up
Old 02-21-2005, 01:48 AM
jengah jengah is offline
Cars: '98 M3 Sedan
Door Handle Replacement Rubber Available on eBay
FYI - there is a guy in the far East (somewhere like Budapest) that is selling the door handle rubbber on eBay for about $25. It fits pretty well and makes your door handles look like new. No more cracked, ghetto-looking door handles on a $50,000 vehichle.
Good luck.
Old 02-21-2005, 03:25 AM
hal9000 hal9000 is offline
Cars: M3/4
Good luck.
Actually kenneth_woo is from Malaysia. $22.00 + $10 s/h for all 4. Alot better than $26 per handle!
Thanks for the tip, I was about to order them from the dealer next week.
Old 04-19-2005, 07:38 PM
Mminehan Mminehan is offline
Cars: 328i E36
E36 Coupe Rubber Door Handle Trim Replacement
I own a 328i coupe and recently changed the rubber trim. What a mission. There is a slider behind a gasket, but it is very difficult to find and move. If you lift the rubber seal on the top edge of the door (where the window meets the sill just above the latch) you will find a very small gasket (see picture). If you look inside this gasket you will see a lever that moves down when you lift the door handle (a curved grey dull colour).
The slider is directly behind this (a few millimetres towards the front) against the outside panel. The slider itself has gold/yellow appearance and is in the shape of an "L" with the bottom of the "L" sticking out from the panel. You can just see the tip of slider. Use a flexible LED torch that you can poke it into the gasket and light up the area. It’s hopeless shining an ordinary torch into the gasket and trying to find it. You can’t look in and shine the torch at the same time.
The best way to slide it forward (towards the front of the car) is to use an Allen key. The Allen key allows you to get in behind the handle lever. If you can imagine the slider being an “L” shape and the Allen key being an “L” shape, then the idea is to push the bottom of the Allen key (tip of the “L”) against the tip of the “L” of the slider. Be careful as the locking mechanism is in very close proximity to the slider and you don’t want to damage it.
I my case the slider was difficult to move. But a few taps on the Allen key with the handle of a rubber grip screwdriver did the trick.
Once you get the trim off and replace the rubber use the Allen key as a hook to pull the slider back.
The best thing you can do is to find/make and LED flexible torch that will poke through the gasket. Once you do this and get a glimpse of the slider you will see how it all works.
There is no need to pull the door apart.
I got my rubber trim from EBay (kenneth_woo, $25 plus $5 shipping for a set of 4).
I hope this helps you guys. It’s difficult to explain and even more difficult to photograph (even though I tried).
Cheers, Marty.
Old 04-19-2005, 08:14 PM
Cars: 328i E36
OK, I just took another look and tried to take some better pictures.
I made a mistake in the previous post. The Slider tip is just in front of the door handle lever (see the pic for details). It’s between a small piece of painted sheet metal on the inside of the outer panel (just visible through the gasket) and the door handle lever.
Hope these pictures explain things a bit better.
Marty.
Old 05-23-2005, 02:30 PM
LmtdSlip's Avatar
LmtdSlip LmtdSlip is offline
Cars: Suzuki SV650
Thanks for the great write up and pics....I plan on doing my vert in a week or two.
Hi, I am Bill Janklow. I killed a motorcyclist and got away with it...
<img src="http://news.mpr.org/features/200109/27_hetlandc_forestfires-m/images/janklow.jpg"border="0" alt="">
Old 06-07-2005, 07:30 AM
Casebrius's Avatar
Casebrius Casebrius is offline
Cars: E36 M3's
Send a message via AIM to Casebrius Send a message via Yahoo to Casebrius
So where is a link to replacement rubbers for a Coupe?
Dakar 95 M3 (4/95 manufacture)
Techno Violet 97 M3 (12/96 manufacture)
___________________________________
"I have no idols. I admire work, dedication and competence." -- A. Senna
Illegitimus Non Tatum Carborundum
Old 06-14-2005, 02:55 PM
kyleabaker kyleabaker is offline
Cars: Boston Green 1995 325is
here...... http://forums.bimmerforums.com/forum...4&postcount=12
and here... http://forums.bimmerforums.com/forum...4&postcount=13
...its correct, i just replaced mine yesterday.
Old 06-14-2005, 03:08 PM
amancuso's Avatar
amancuso amancuso is offline
Who, me?
Cars: 318ti Z3 540i 330i
What rubber seals are you all replacing? I've looked at my door handles and I don't see any.... nothing looks old, dried out or cracked...
-Al.
Old 07-04-2005, 10:27 PM
325ven 325ven is offline
Cars: 325I coupe 1994
Send a message via MSN to 325ven
the *&%/()& is not visible on coupe, and you can spend hours changing it!!! good luck or at least more than i had!!!
325I 1994.
Venezuela .
Old 07-22-2005, 12:51 AM
Cars: 328i E36
Like most DIY projects, it takes time to work out what people are writing about. But once you do it once you can do it a 100 times with ease. It's tricky but not impossible on the coupe.
Old 08-02-2005, 12:27 PM
Dunx Dunx is offline
Cars: BMW E36 coupe
Did you have to remove the interior door trim in order to do this?
Starting to think I should of went for the saloon now LOL
Old 10-22-2005, 01:53 PM
LmtdSlip's Avatar
Cars: Suzuki SV650
Hello all. Just wanted to let you know that I just did mine and it makes a HUGE visual improvement over the disentegrated old ones.
Huge thanks for the DIY write up as it was a bit tricky to figure out. I used a wire hanger to do it. I straightned out the part of the hanger that hangs on the rack and then put a 90 degree bend about a 1/4" from the tip. I used this to push and pull the slide.
So now I have a set of rear door trims as mine is a coupe. If anyone needs a set for their rear doors shoot me an email.
Old 12-21-2005, 03:30 PM
Vinci Vinci is offline
DO IT YOURSELF.
Cars: 98 M Roadster
I just swapped those gaskets out on my MZ3, and it was a breeze. Though, beware if you buy those gaskets from that eBay dealer that someone mentioned earlier. I ordered a set, and they don't fit quite right. The outside edge wasnt rounded in the right places, so it didn't sit right on the door. It may fit different on a 3-series, but it was supposed to fit the Z3's as well. I ended up just buying another set from the dealer, which fit perfectly. If you go to the dealer, they give you the whole surround along with the rubber gasket, and it ended up being the same price ($16 per side).
Old 02-16-2006, 12:03 AM
spsinha spsinha is offline
Cars: 2005 X5 4.8is
Send a message via AIM to spsinha
Does anyone know how to remove the exterior door handle and lock cylinder? Bastards broke in and smashed it all to pieces? If you have a used drivers side door handle, please let me know.
Old 02-25-2006, 07:57 PM
pcmedics911 pcmedics911 is offline
Cars: 318i
OK i'm trying to push the slider back (towards the front of the car) to remove the door trim.
Anyone have any problems pushing it forward (towards the front of the car)?
I used an allen and hammered it forward toward the front and it won't budge.
I"m so close..yet so far away.
Help!
Old 02-25-2006, 10:43 PM
SQ Bimmer's Avatar
SQ Bimmer SQ Bimmer is offline
License Suspended
Supporting Vendor
Cars: '05 Ram 1500
Send a message via AIM to SQ Bimmer
Good explanation of the slider.
