I just got back from a little weekend vacation, so my car has been sitting in the driveway for almost five days. During those five days, a couple bad storms hit (i.e. a lot of rain). Lately, my car hasn't been starting with the greatest of ease. It usually takes a couple more turns of the starter (not the key... just one turn on the key) than it used to for the engine to come to life.
So I went out to my car just now, I turned the key, and all I get is a sort of fast, fairly loud clicking sound. The car obviously doesn't start. All the internal lights and radio and all that come on, so it's not battery related (I don't think). Any ideas on what it could be?
Yes it is battery i believe. Those lights will still come on even if the battery is dead...the fast clicking sounds is what makes me believe it is the battery so go have it tested.
battery.
Yeah, just because the interior lights/radio works doesn't mean the battery has enough juice to start the car. Try to jumpstart it.
Interesting. Where do you get Interstate batteries? Are Optimas any good? Thanks guys.
Yep, battery. Mine does it more often that I would like...lol.
Why not just push start it (assuming you have a 5 speed).
Turn key to ON position, roll car, put in 2ND gear, and pop the clutch...she should start. Note: If the battery is totally cooked, it wont run, period, but I doubt thats the case.
Go on a nice 30 minute drive and she should be charged up enough to gp from there.
I would not jump the car...BMW electronics are SENSITIVE. Rather, if you dont like the push start method, disconnect the battery and put it on a charger for a while. Tim
1995 M3 (sold)
1997 M3/4 (sold)
2004 GT3
2008 E90 M3 on order -- week 23 build -- DCT and 19's!
battery or starter...
I have idea about the validity of this, but I heard that you can't get Interstate car batteries anymore, that the name changed to something else. Don't remember what though.Originally Posted by ////\/\ark
The starter motor takes considerably more current to function than the radio and lights do, yet a lot of BMW owners fail to understand that simple concept. Just because the radio turns on does NOT mean the battery is "good".Originally Posted by ////\/\ark
www.understeer.com Your source for:
Stromung|UUC|Eurosport|Hawk|H&R|Koni|Apexcone HID|Short Shift Kits|and moreUUC Evo3 SSKs are IN STOCK - free 2-Day shipping!
I've never heard of someone damaging the car's electronics by jumping it. BMW put a pos. terminal in the engine bay just for that purpose. Either a jump or a rolling start should work fine.Originally Posted by ArcticFox
I tried a roll start but I couldn't get it to go. So I just ran to pep boys, got an Optima red top, and it works great now. Thanks for the help. Do you think I should consider changing out my alternator now? Could that have been why the battery crapped out?
Not likely, batteries typically die from inactivity. The longer they sit without being charged, the worse they get. Most likely your battery wasn't in great shape to start with and sitting for a week finished it off.Originally Posted by ////\/\ark
Aren't you relieved that your problem isn't really "serious" ?
gotta love when it's somewhat of an easy fix.
Also, after this happened I picked up one of those battery boosters from Costco and I keep it in my trunk. It's $60 and it even comes with an air compressor that you can use at the track/autoX.
'03 ///M5
Just did a quick google search...looks like the name pops up for car batteries...so I dunno...Originally Posted by surfacewound
I got my battery from a local Independent BMW shop...Stealer also sells original BMW battery for a premium...and I was told Interstate is one of the best batteries around. In fact, my local Stealer kept them as an option for their customers...but now only carries BMW Batteries.
In addition to all the good info listed, it is also common for the battery connection or ground wire to become corroded, causing the same symptom. Normally, you will receive some fault codes showing charging system problems prior to a battery really dying.
I dont think there is anything to show that.The corrosion is probably due to the battery being old and having to work too hard.The sides sometimes bulge out.I've had on 2 occasions the battery drop a cell.You can jump it,bump it but the starter will not start it.Just clean it up and make sure you have the vent hose connected.
Martin
12/95 alpine white m3.Last of the breed
also remember not to let the battery sit idle too long. Battires discharge every moment they aren't in use. With motorcycles it's even more so. You can kill a brand new bike battery by letting it just sit for a month sometimes.
Absolutely. It's funny... I've been driving around since I replaced the battery, and it just feels so good. Those few hours of having a "broken" car really made me realize how nice it is to have the M. So thanks again for all the help guys.Originally Posted by 318daily
