Results 1 to 25 of 30
Thread: 335i/6 vs 540i/6 dyno overlay (dynojet)
    Jul 2012
    Hayward CA
    1999 540i 6 sport
    Hello all,
    I'm new to the forum. Just wanted to share with you all a dyno graph that I have of my 1999 540i vs my friends stock 2007 335i coupe.
    My dyno reading is in the red line and the graph is STD reading for both cars. Also my car was running a bit rich over 4.5k rpm.
    My car:
    STD:278whp 305wtq
    SAE: 268whp 296wtq
    frist two SAE runs for stock 335i were 251whp and about 270wtq. my friend couldnt believe it so we waited untill his car cools down some more and on 3rd run he posted some better #'s
    let me know what you guys think.
    BTW i have m60 intake, muffler delete, fan clutch delete, k&n filter and gutted airbox.
    Aug 2012
    Flemington, NJ
    2001 540i E39
    You need at least 15 post to be able to post pictures. Until then, we won't be able to see them.
    e39 2001 540i 142,xxx miles - CAI, Redline MTL, Bilstein Sport w/H&R Sport, m60 manifold, 10w AA, Hankook ventus v12, and maintenance
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Interesting to see the graphs eventually if legit and indeed was done same day same dyno.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Queens, NY
    destiny
    335i is suppose to put down ~275whp in factory form.
    Current
    2008 E70 4.8 BSM/Black - 100% Options2007 335i SG/Coral Red - 6MT - Ets, Spec, BMS, VRSF, Broadway Static
    2004 325i AW/Black
    Past
    2000 M5 Silverstone/Silverstone - ST Coilovers
    1998 E36 M3 - Tiag, Bride Gias, RK Tunes, M50, AA Track Pipe..
    Jul 2012
    Hayward CA
    1999 540i 6 sport
    Quote Originally Posted by Silverlight View Post
    Thanks, I'll work on that and update the thread.
    Quote Originally Posted by TriniSpeC View Post
    It did in standardized reading.
    Feb 2009
    Bay Area, CA
    '03 540i M-sport
    Graph state almost exactly 275 for the 335. Impressive results OP.
    Jul 2011
    hillsborough n j
    2001 540i sport 6spd
    Was 335 stock?
    ~2001 540i/6speed~
    Schmiedman M5 headers, SPEC stage2+ kevlar clutch, JBR 11lb lightweight flywheel, ESS Tuning m60 manifold software tune, 3" SS freeflow OBX catback, afe cold air intake, m60 intake manifold, Cdv delete, powerflex urethane sway bar bushings, M5 rear sway bar ,Autozone replacement driver side blinker light bulb, 545 short shifter zhp weighted, "dsc off" sticker, m5 3.15 lsd differential, m5 chassis rods, akebono ceramic pads, G2 caliper epoxy, ecs braided lines, BC-Racing br-plus series w/swift springs 8/6~
    On the night that I go back in time, you will be shot by terrorists. Please take whatever precautions are necessary to prevent this terrible disaster.
    Jun 2006
    Frederick, MD
    e39 540i/6, e36 318i
    my butt dyno tends to believe this is close to correct. OP, are you near sea level? That's the worst case scenario for the 335i and the best case for the 540.
    1985 325 - 5 speed - LSD - M50NV - MS2/extra - AEM UEGO - TiAL MV-R - 750cc injectors - HX35 - Blunttech Manifold - 3" exhaust
    1991 318i - 5 speed - M50NV - e36 rack - Smileys
    May 2005
    Meriden, CT
    '03 540i/6 M-tech
    Interesting...
    2001 330Cic/A in the same color combo is "Her" ride.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Why STD rather than the normal SAE?
    What temp and altitude? The right combination will cause an over correction of the turbo car.
    /.randy
    Jul 2012
    Hayward CA
    1999 540i 6 sport
    Yes the 335i is stock and he usually has a cobb tune but he wanted to see what it does stock. The temperatue for when 540i was dynoed was 55 deg.F and for the 335i it was 59 deg.F. Both cars were dynoed on a same dyno and the altitude of the city is 50ft above sea level. SAE gives lower reading so my friend decided to use STD for the printout. Two e39 m5 dynoed their cars and one dynoed at 303whp and other at 315whp.
    May 2005
    Meriden, CT
    '03 540i/6 M-tech
    did he dyno at all with the cobb tune?
    Jul 2012
    Hayward CA
    1999 540i 6 sport
    Quote Originally Posted by Justin517 View Post
    No he didn't but we suspect he will dyno about 320whp and 360wtq. I have raced him befere with cobb tune and he just walks me .
    Jul 2012
    Hayward CA
    1999 540i 6 sport
    Dec 2007
    Great Dismal Swamp
    That's the kind of conditions that will cause over correction on a turbo motor. The correction assumes the temp will mean a denser charge, but the turbo density will be limited by the waste gate to about the same as normal. Probably the most accurate thing would be to compare your SAE to his Raw numbers, but you can't do that on the same graph with the Dynojet software.
    The other thing you could do is compare raw to raw, and say that this is what these two cars do today under these conditions. Tomorrow may be 20 degrees warmer and everything will change.
    /.randy
    Jul 2012
    Hayward CA
    1999 540i 6 sport
    Quote Originally Posted by Cyrix2k View Post
    Yes it was sea level. Sorry still getting used to replying.
    Jun 2006
    Frederick, MD
    Quote Originally Posted by rad540i View Post
    I few things. A) This is the best case scenario. The correction factor is valid for NA motors so yours should theoretically dyno the same no matter the temp or altitude. However, the correction does not hold up with FI motors particularly with altitude. Because you are under 1000 feet, it will make the 335i appear slightly down on power compared to what it actually makes (but not by much). B) I think your results are approx correct. The 335 is around 400#s less than the 540, and they run almost exactly 4/10ths faster in the 1/4 at low altitudes. C) This further verifies the M62(TU) is underrated and the S62 overrated.
    Jul 2012
    Hayward CA
    1999 540i 6 sport
    Quote Originally Posted by rf900rkw View Post
    His raw numbers are as I posted and mine corrected is 268whp. I raced my other friend with his stock e90 335i auto and walked him on the freeway. He had 1 passanger and I had 3 in my car. 335i is really fast when tuned also I'll post some videos since I just bought a gopro.
    Jun 2006
    Frederick, MD
    Raw as in uncorrected? What are the uncorrected numbers for both? That will be a good comparison since they were dynoed back-to-back.
    Jul 2012
    Hayward CA
    1999 540i 6 sport
    Ok thanks because I didn't know that. 335i do have better 1/4 mile times because their launch is better. When you run them on the freeway over 90mph they struggle as their peak power doesnt matter any more because it declines after 5.5k rpm. Am I allowed to post videos of racing on this forum?
    The dyno that I posed are uncorrected for both.
    Quote Originally Posted by Calicoastin View Post
    Thank you.
    May 2005
    Meriden, CT
    '03 540i/6 M-tech
    you can't post a video directly to the forum.
    post to youtube or other hosting site and post here... if youtube doesn't delete it you should be good to go to post here I think... I think.
    Just be sure to say you are in mexico, lol.
    Jul 2012
    Hayward CA
    1999 540i 6 sport
    Haha or computer generated.
    Mar 2005
    Bayside, NY
    2003 Dinan SC 540/6 M
    In for the Video!!!!
    Dec 2007
    Great Dismal Swamp
    So you are saying your car did identical numbers STD and raw at 55F? Something is.... odd.
    /.randy
    Jul 2012
    Hayward CA
    1999 540i 6 sport
    Please define raw.
    Quote Originally Posted by MartinV View Post
    Hopefully I'll get few runs on Friday. Just so busy at school.
    Its gona be 540i vs e46 m3 vs g35 vs 335i vs camaro ss
