Page 1 of 6 123456 LastLast
Results 1 to 25 of 131
Thread: BFG Rival Launch Event
    Minneapolis, MN
    '97 M3, '02 330i
    Lots of other stuff out there. Maybe Tristan will chime in with his thoughts too.
    Just returned from the BFG Rival launch event in New Orleans at the NOLA track. That was just about the most fun I've had at any event like this. All the fun of a SoloPro school, with none of the work! Sitting on a plane with a 3-hour flight, so read on for the big brain dump. If you "TL;DR" folk want to skip to the end, it's cool.
    The stats, per BFG themselves:
    - 15 sizes ranging from 15" to 20"
    - Designed…AND MADE...in the USofA
    - Same compound all the way through
    - 7/32" tread depth off the shelf. (They haven't tested shaving)
    - Asymmetric, non-directional
    - Unapologetically optimized for DRY pavement
    - Supposedly still good in damp/wet but not so good for standing water
    - Angled sides on the tread blocks to load better across the surface of the tire
    - < 265s will have two grooves. 265+ will have three.
    - Super-stiff sidewall insert plys (verified on unmounted tire…more than Dunlop and WAY stiffer than an RS3)
    - New plies across the face to resist ballooning at high speed.
    - Tread compound goes a long way down the sidewall so you stay on the good stuff
    Session 1: STI medium autocross
    We started the day driving bone-stock STIs on a medium-sized autocross track on asphalt. We got two runs on the BFGs, two runs on Hankook RS3s, two runs on Toyo R1Rs, and then two more on the BFGs. Kevin Dietz mentioned that he thought the car with Rivals on it felt like it had aftermarket springs. I agree. The car was MUCH more responsive than the RS3s and on another planet from the Toyos in terms of feel and feedback.
    Two other things became immediately clear: The Rival recovered from mistakes MUCH quicker than any street tire I've ever driven. Stock STIs are nose-heavy and have quite a bit of understeer, so this was easy to test! As soon as you fixed the problem (too much steering, too much brake, too much gas, whatever), the car got back on line almost instantly.
    Second, the wear. The tires were new at the beginning. Everybody kinda chuckled when we saw the Toyo on a Subaru. We knew it would be bad in that situation. But after ~30 runs, the tires were not only missing a bunch of tread on the shoulders but were graining BADLY across the whole width. The RS-3s were starting to display their usual disappearing sipes on the shoulders and slight feathering on the tread blocks. Just as you'd expect. But the BFGs showed almost no visible wear. Couldn't believe it.
    We were monitoring tire temps pretty closely between runs. No pyrometer, but I'll claim my hands are actually relatively well-calibrated for a 100-140 degree range. (trained barista… ). It was a cool morning and nothing got SUPER hot. The Toyos were probably in the 130-140 range and the shoulder was hotter. The Hankooks were notably cooler across the surface, maybe 120ish, but the shoulder was pretty hot…maybe still in the 140 range. The BFG had 50% more runs on it, but it was still cooler than the Hankook. Maybe 115? But the shoulder was only a little warmer than the main part. The tire clearly distributes the load better across the whole tire.
    Session 2: MX-5 Cup on Skid Pad
    This was in MX-5 Cup cars from Skip Barber. We compared the BFG Comp 2 (their "Ultra-High Performance" tire) and R1S to the Rival. Not too much to report here, except how stable the Rival was and again how wide the traction window was. There was a significant ridge running down the middle of the skidpad, and the Rival handled it with much less drama/correction than either of the other two tires. They had iPads in the car and I sustained about 1.15 on the asphalt. But that's not terribly meaningful.
    Session 3: E46 M3 on large autocross
    Here's where my mind was blown. Stock E46 M3s. Two runs on Rivals, two runs on RS3s, and one final run on the Rivals. Mostly a fast, flowing course with good transitions, a couple decreasing radius turns into really slow corners. I know BMWs on Hankooks, and I'd shaken off the winter cobwebs on the STIs. The hosts had made it clear they didn't expect us to baby the cars, so I was ready to see what these things could do. Then Hayward Wagner pulled out a couple stop watches as we watched Ann and Andy Hollis take the first runs...and it was game on.
    It was difficult to tell whether the BFG had more ultimate lateral grip. If you set up the corner right, the Hankook seemed like it still had great grip and dug out of increasing radius sweepers well. The BFG was maybe a little better in longitudinal grip, had MUCH better initial feedback, and required less "leading" the car. We didn't have any proper slaloms, but there were some good transitions and I think the Rival will be easier to slalom, which is a complaint I've always had about the RS3.
    But the #1 thing for me was the breadth of the peak and the ability to recover from mistakes on the Rival. I've also always had some trouble entering decreasing radius corners on the RS3s. I blew several corners in each car (some intentionally…some not so much!). The RS3 behaved as I remembered. Once the front tires let go, they're gone, leaving me feeling like I'd just totally blown the run as I try to suppress a string of four-letter words and pray I don't hit the outside wall. Overcooking a corner on the Rival still required some corrective action, of course. But as soon as you got the speed down or straightened the wheel, the car *immediately* came back into shape. Just about the time the four-letter words started to surface, the problem was already fixed and the other half of my brain was kicking myself for not being on the gas! It felt like losing one or two tenths instead of five or six.
    We worked the M3's HARD. And we were the third of four groups to do so. I was hitting the rev-limit in two places and intentionally stuffing it into corners to see what would happen. The brakes were already smoking when I got out of the Rival car, and I was only the fourth one in it. (For the record, they were already soft when I got in…despite what anyone else claims! I blame it on Andy and Junior…) Shortly after that, they faded completely and the car was driven away to cool off. But once again, the RS3s were warmer with shoulders that were much hotter and had disappearing tread. The Rivals were starting to show wear, but still had a smooth surface, with almost no feathering and just a little shoulder wear.
    Session 4: FR500S track session
    I've not been this giddy walking up to a car in a while. Or this terrified. Full-blown, race-prepped spec racer Shelbys. Three with Rivals, and three with Falken Azenis. Yup…Falkens. That was a bit of a head-scratcher. But <shrug> it's a big loud Mustang with a cage and a wing. Where do I sign up?
    Less than two laps on each tire. I really wish I could say anything useful at all. Unfortunately, I hadn't studied the layout at all before the event, and I quickly discovered this track has ZERO elevation and NO good landmarks. We weren't given a warm-up or cool-down lap, and my instructor's headset (which seemed plenty loud in the pits) was barely audible over the V8. Call 'em excuses if you want, but I was in no position to see what the tires could do. I spent all my energy trying to find the next braking zone and apex before I got there, which was surprisingly hard. I started pushing just a little on my last lap on the Falkens, but even that wasn't much at all. It was all over much too quickly. Boo-hoo.
    It seems like a really fun track that flows well…you just have to know where it goes before you get there. But I can say that those Mustangs are really sweet. Surprisingly easy to drive, despite being a big car with a big V8 on 245 street tires! Sure, it had plenty of power, but it wasn't overwhelming or difficult to modulate. If I'd known the track, I might have been reasonably comfortable with the car in just a lap or two. It seemed very forgiving, it looks bad-ass, and it sounds amazing. Want.
    Relevant Notes:
    STS/STC PIXIE DUST?
    This will be interesting to watch. I still think it is possible that the Toyo R1R might be the tire to have here. The Rival will be offered in 15" sizes. A 205 and one other, IIRC. But it remains to be seen whether it will work as well on a ~2000 lb car. It will almost certainly be easier to drive and less mushy than the R1R or the RS3. But faster? Hmmm…no way to know. Everybody seemed to agree that the answer wasn't obvious. BFG said they had a B-Spec Honda Fit and a Spec Miata that they had been using for testing. But it is pretty easy to see that 15" tires are starting to go the way 13" and 14" tires went some years ago. The market is clearly in 17"-20" tires on 2500-3500 lb cars. So that's where the R&D budgets are being spent, and that's what we drove today.
    WHAT ABOUT THE OTHER NEW TIRES?
    Dunlop Direzza Z2: We didn't get to drive the Z2 because there supposedly weren't enough available yet. At risk of being incredulous in the face of amazing generosity, that seems hard to believe. A bunch of TireRack folk were there, and I've been seeing lots of form posts from folks who have received their first order. They couldn't find three sets to bring? ORLY?
    I have some conspiracy theories as to why we didn't drive on them, but it really doesn't matter. We'll have to wait for the final answer. BFG claimed that "some experienced drivers" ran both tires on an MX-5 Cup car yesterday and the BFG was a full second faster than the Z2. I know Andy Hollis was one of those drivers, though I don't know if those were his lap times. Andy did tell me that he thought the BFG certainly was better on track. The Dunlop felt more edgy and less confident at speed. He did not reveal whether he also got to autocross it.
    Bridgestone: Apparently NOBODY has seen a single, in-the-flesh Bridgestone yet. There are some who say it may not be worth waiting for. Obviously I have no clue.
    Final Thoughts:
    TRACK
    For anyone doing street tire racing on the track (Chump, Lemons, HPDE, etc.), this tire seems pretty much a no-brainer. The heat tolerance, wear characteristics, and extra sidewall stiffness make the car faster, more consistent, easier to drive, and probably cheaper to run. I've run both the Z1 and the RS3 on track and the RS3 was clearly faster, especially after 10+ laps. Considering the RS3's 140 tread wear rating isn't even legal for most street-tire classes, I find it hard to believe this tire won't be the best choice.
    AUTOCROSS
    For autocross, I cautiously predict that the BFG will be the tire to have for most cars. The feedback from the people who drove on cold tires was extremely positive. For me, autocrossing the RS3 vs. the BFG in the STI, and especially in the E46 M3 on a bigger/better course, was eye-opening. Of course, I haven't driven on a Z2 yet, and I didn't get to run the tires completely cold. But whether the Z2 is faster or not, it is 100% clear there will be a new standard set this year.
    Marietta, GA
    95 M3, 87 535is
    Thanks for the super detailed write up. Hopefully we have a solid comparo between the Z2's and these in the coming months.
    Nov 2012
    Charlotte
    1996 BMW 328is, 2004 RX8
    Great write up, my ZII's came in last week so i'm currently waiting the official test as to which ones are faster. Since I have 2 sets of 17's I might pick up some BFG's as well and do my own test. Since at some sites last year in my RX8 I was faster on the R1R's (Blytheville, Peru) and at Nationals I felt the RS3's were faster.
    One thing I learned last year was I had to change the settings completely to get the most out of each tire. While the Toyo's made the car very pushy I was always stiffening up the rear and softening up the front after each run. While the Hankooks I had to soften the rear to help the car from being overzealous.
    I know they were tested on stock cars. ZII vs BFG, but I still need to see if on a car where you can change compression/rebound as well as swaybar settings, if I would be able to get more out of the ZII. In my case I do hope the BFG is faster since they offer contingency and I may use the ZII as rains.
    Neal I didn't even realize that this was you. Howdy!
    Mar 2001
    H-town, TX
    95 m3, 03 X5, 06 X3
    Nice post! Good to hear that a US company is stepping up to the ST wars. I am definitely interested.
    Hopefully their supply chain is much better than Hankook/Dunlop.
    #71 SM
    04 Silver Grey M3
    95 Arctic Silver M3
    03 X5 3.0L Titanium Silver
    07 GX470- Silver
    Molon Labe...
    Excellence is a habit, not an act.
    MD
    99 M3 / 95 325i
    Wow, thank you for the write-up. I'm looking forward to the pricing..
    -Chris
    Nov 2012
    Charlotte
    They are up on TireRack now. 255/40/17's are $230 while the 245/40/17s are $189
    http://www.tirerack.com/tires/tires....7GFR&tab=Sizes
    Aug 2011
    Lowell, MI
    VW TDI
    Doesn't the 7/32 tread depth make these ineligible for ST use though?
    - Brad
    Dublin, OH
    '95 M3, '17 Civic Si
    excellent feedback, sir
    Bloomington, Illinois
    2011 E92 M3, 2007 335i
    Thanks for the feedback.
    Now in E92 M3 ZCP -- Absolute beast
    Dublin, OH
    Quote Originally Posted by BJO View Post
    BFG is just as American as Budweiser is American (they're both originally American but now and for some time already owned by European companies)
    LOL, US Company
    Jun 2002
    California
    01 MCoupe, 10 535 SW
    Quote Originally Posted by das borgen View Post
    LOL, US Company
    Michelin if I'm not mistaken...
    Oct 2008
    Boston, MA
    2008 BMW Z4 M Coupe, 2001 BMW 325i
    Yes, Andy Hollis posted on his FB page that the BFG g-Force Rival tested out 1 second quicker than the Direzza II at NOLA. Coming from the SCCA and Pro Solo Champ on back-to-back test makes this a must-read for anyone considering the g-Force Rivals and Direzza ZIIs: http://www.onehotlap.com/2013/01/bfg...-thickens.html
    '08 Z4MC, Interlagos Blue, Black int, CF trim, H&R springs, TMS camber kit w/ -3 deg, 245/275 Nitto NT01 on D Force LTW5 wheels, 245/275 Dunlop Direzzas
    '01 325i: Orient Blue/black, SP, M stress bar, UUC sways, TMS camber plates, TMS rear sub reinf kit, ECIS CAI, Shark, Borla cat-back, Dunlop Direzza 245/40/17 on 17x8 O.Z. Superleggeras
    HPDE instructor, Boston Chapter Autocross Co-chair, Boston Bimmer columnist www.boston-bmwcca.org/bimmer/online.aspx
    My performance driving site: www.OneHotLap.com
    Minneapolis, MN
    '97 M3, '02 330i
    Quote Originally Posted by klodkrawler05 View Post
    I've never heard of such a rule...
    Quote Originally Posted by AC Coupe View Post
    Right. So not a "US Company" for some time. But one of Michelin's three headquarters is here, and these tires have been designed, tested, and built here in the US (as have the R1/R1S, IIRC).
    BFG has always been associated more with the US than elsewhere. But I was talking with one of the guys who said they really position the BFG brand as a "single purpose" brand. For example, BFG has been doing a ton of stuff in off-road and rally for a number of years. The Rival is designed purely for top performance on dry pavement, and compromises most other things like wet traction. Meanwhile, the Michelin Pilot will always be the "ultimate all-around" performance tire.
    Neal
    Aug 2011
    Lowell, MI
    VW TDI
    Quote Originally Posted by SUVETR View Post
    I just double checked the 2013 rules to be sure I wasn't crazy.
    14.3.C Tires:
    Tires must have a minimum UTQG treadwear rating of 140 and a minimum molded tread depth greater than 7/32" as manufactured.
    - Brad
    Oct 2008
    Boston, MA
    14.3.C Tires:
    They are listed as 7/32, which would make them illegal, correct?
    Aug 2011
    Lowell, MI
    VW TDI
    Quote Originally Posted by brave1heart View Post
    correct, because the wording specifics they have to be greater than 7/32 not equal or greater than.
    if the tread depth was 7.1/31" they'd be fine
    - Brad
    Nov 2012
    Charlotte
    Don't worry, they will change the rule to "Must be at least 7/32 to be eligible."
    Minneapolis, MN
    '97 M3, '02 330i
    Yeah...considering BFG is sponsoring the entire National Solo program for 2013 and is the "Official Street Tire of the SCCA", I have to belive the tire will be legal.
    Nov 2012
    Charlotte
    Neal, any word on if they will provide contingency for the Match tours? Or just the Champ tours and Pro's..
    Mar 2011
    Chicago, IL
    1993 325is
    There will be some politics to it that may prevent this from being all that swift. It may come down to the plus of having a good relationship with BFG compared to the minus of looking like they're playing favorites for BFG.
    Also, regardless of a 7/32 designation clarification, at least 6 sizes must be "available" by 4/30. Looks like tirerack shipping to us "available" will get 8 sizes in time. Hopefully the other new crop will be fast enough for this year's availability. The good question on that is what is good enough for "Available"? When TR starts to get their shipments confirmed to be coming to their warehouses? Or when TireRack can get them shipped to us? One of the Rival sizes says availability 5/1. One definition makes it unavailable in time, the other not so much. Hopefully that's moot.
    As specified elsewhere too, "manufactured" is a key word there. Doesn't matter what your measurement says, it would matter what the mold is set to.
    Feels like I'll be driving on ZII's this year, then buying another wheel set to have Rivals next year for direct testing, repeat 2015 with the next great tire...
    Palm Harbor, Florida
    2000 M Roadster
    Problem is one of the more popular sizes,255/40 17 is not available until mid april.
    Mar 2011
    Chicago, IL
    1993 325is
    That's a problem only for the events that you would want that tire. It's not a problem for the year as a whole or it's overall eligibility. Even the tires that you wouldn't be able to get til May would be eligible. It's not a carcass by carcass rule, just a rule for the eligibility of the lineup.
    Heard a relevant point of discourse... Most machinery is metric. Very well could be set to 6mm, but for marketing purposes shown as 7/32 instead of 8/32 (6mm is 7.56/32nds)
    Minneapolis, MN
    '97 M3, '02 330i
    Quote Originally Posted by TopGear8 View Post
    They did mention they were talking with the SCCA and Evo about it, but nothing official yet.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    here is a picture of the tread depth done at the track today. They are legal tread depth.
    http://i291.photobucket.com/albums/l...treaddepth.jpg
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
    Nov 2005
    Kansas City
    1976 2002, 1998 328is
    Excellent report, sir! Thanks.
    Avus 1998 328is, No. 191 STX
    Orientblau 2000 323i Touring
    Malaga 1976 2002
    SHAZAM, GOMER, LOOK AHEAD.
