In about 6 months I want to change over my interior in my 98 4/5 from dove grey to black. I have everything but the dash (current dash is dove grey)and want to replace it to match the new interior.
1. Is it worth replacing to match the new interior?
2. Any tips or things I should know before I do this?
3. Aside from the radio and steering wheel are there any upgrades I should look at making?
4. Does anyone in the tri-state area wanna help me with this that I will gladly pay for?
Thanks!
1. If you'd like a black dash then yes it is
2. Rear as many DIYs as you can find, go slow, and make notes of where each bolt, screw, and nut came from as you go.
It's a fairly tedious process in the E36. HERE is a great diy that I used when pulling the tan dash out of my car and replacing it with a black one.
3. Sounds like you're on the right path
It's not that bad of a job, just a lot of small nuts and bolts here and there. Only advice I have for you is if you need to do anything with the heater core or blower, do it while you're in there.
The hardest part is just removing and tightening the 4 bolts/screws at the top of the dash under the windshield vent trims. Pickup a right angle screw driver from harbor freight and a really short Philips screwdriver. You should be fine after that. Everything else is a breeze.
Question: Is it worth replacing to match the new interior?
Answer: If it is important to YOU, yes.
In my book (see my sig) personalization is priority. I am the proud owner of a 1995 M3, WITH tilt steering. Is the range of tilt worth the effort? H#LL no! Was the effort worth the value of being different? You bet.
My advice- buy some extra fasteners, and plan to clean up the mess of wiring back there (zip ties etc), a can of spray paint for any rusted tube steel etc-- I re-worked my HVAC foam connections while I had my dash apart, ran wiring for future gauges, and added aux wiring circuits for future misc. electrical doo-dads. Also added insulation to HVAC lines (for the heck of it).
Great stuff, thanks guys. I think it'll be good to just clean everything out and replace some old and beat up parts.
This will be apart of a complete (well almost complete) transformation. Looking at new wheels too! Just don't know what I want yet. New cat back and upgrade the front sway (took the rear out after I wen to coil overs). I'll post pics when complete.
I think those M-Parallel wheels look pretty sharp on your 4-dr! I had them on a 94 325i vert and thought they looked darn good. Quite different from the usual M3 wheel varieties. Good luck on dash replacement; sounds like something I would not/could not even begin to think about.
1999 M3 vert, Rogue SSK, Conforti intake, SS replica catback, UUC adj rear control arms, Eibach springs, Konis, Beyern rims, cross-drilled Zimmermans w/Akebono Euro ceramic pads, ASC delete, Bosch Euro lamps, ZKW Euro foglamps
I thought about replacing my dash with a black one from tan in one of my e36's. I was going to replace it either way, so I sprayed my dash, glove box, everything associated with the dash with interior paint to see how it looked. People think its OEM.. Just a thought it you dont mind not having a Authentic color dash and would rather not go through the hassle of removing and replacing. Also, its cheap!
I wish I had actually snapped some pictures of the dash, never thought to. I recently sold the car. The dash still looked as good as the day I sprayed it. I did it 3yrs ago and it survived the FL heat with no problems. The hardest part was prepping around the windshield so I wouldnt get over spray on it. I took off the kick panels, glove box, anything attached I sprayed separately. If I had another e36 with a dash other than black, I would definitley spray it. I believe I used a satin black.
Well heres you can see some of the parts I painted from my thread selling the car. Car was my DD, dont mind the seats lol.
