Guys,
I tried putting on the Eruopean Ellipsoids awhile back (ZKW) and the back of the ZKW would hit the RMS intake tubing (The one from the K&N air filter to the Vortech supercharger). Osh wanted like $200.00 and a day or 2 with my car to custom make me a tubing that would allow me to fit the Ellipsoids. I just wanted to know if any of you had the same problem, or know anyone that actually got it to work and how? I'm willing to purchase a new custom made intake tubing, just not for $200.
Another question. The K&N filter supplied by RMS had a part number of B050A6. Do you know where I can purchase a new one as mine has a small tear it in? Or do you recommended a differnt brand/type like the foam types?
Thanks,
Josh
1998 M3 RMS STAGE 2 SC - NICKG TUNED BBS RXII 18x8.5
GROUND CONTROL RACE COILOVER (325/450) GROUND CONTROL CAMBER/CASTER PLATES
Some people modify the back of the ellipsoid in order to clear the intake pipe. I would probably look into this before paying $200 for the new intake pipe.
You can remove the small electric motor for adjustments... and make adjustments only manual...
Voila... it will be enough space
CRISTIAN
Powered by: M3 S50 US Special, OBD 1, Euro Radiator, Euro Oil Cooler, Iridium NGKs, Plasma Coils
Bored & Stroked by HIOP: 3203cmc, Low CR Pistons, Bigger Cams, Headers, Free Flow Exhaust
Supercharged by RMS: 12psi, Stage 3 Software, Aftercooler, 42lb Injectors, 3.5" HFM
410hp/503Nm, 0-100Km/h ... 4,6s; 0-200Km/h ... 14,8s. Read my story, Update: DYNO TEST V-Tech
our euro lights dont have motors for adjustment.
I got a reducer pipe to clear the lights. RMS included it with the install. I *think* the regular pipe will clear if you remove the backing plate from the lights.
RENNtech 168mm Pulley and Tune | VRP Carbon Fiber Airbox | JP Shorty Headers | Eisenmann Race Exhaust | RENNtech Digital Lowering Module | 19" HRE 547R
459 RWHP, 522 RWT
Hey, Youse Guys.. Get your priorities straight... Do you want to SEE, or do you want to Go Fast!!!
___________________
Paul E
'11 AW 135i ; Sold: '99 White M3 81k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold & stock cats); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust, clutch; Fikse FM-10s; Koni Suspension; Stealthboxes
http://s11.photobucket.com/albums/a173/boostm3/
My InPros wouldn't fit. First I ensured that the air filter was as far back as posible. Knowing that many others had fit ellipsoids with their Superchargers, I started cutting. First to go was the factory adjustment knob. The farther in the lights went, the more I had to trim. But, what the heck, they are only InPros. I continued trimming, heating and bending until they fit. When I was done, I was left with a hole where the factory adjustment knob used to be and a dent with a hole in the back cover. It's just a matter of time until the weather finishes what I started. I never liked my InPros anyway.
CRISTIAN
My car has a reducer to clear the euro lights. Probably the exact same setup that Charles has. The one thing is I am told the reducer will cost you some horsepower. How much i don't know. You can see the reducer in the pic. It is a just a piece of rubber to coonect the smaller pipe fromthe air filter to the larger pipe going to the S/C.
96 M3 320rwhp
85 325e (sold)
80 320i turbo (sold)
Where's your HFM?Originally posted by nicholas
it's down right behind the filter
459 RWHP, 522 RWT
I used a tube from a Dinan CAI and it worked for me.Originally posted by GTR-M3/4
Guys,
Thanks,
Josh
Go to a Diesel Truck Muffler shop and get a tube with a 70-90 degree bend. It should work.
Bill P
Thank you for your replies. I'm just going to wait till someone actually designs an intake pipe that will work perfectly w/out hp/tq loss. Do you guys remember what to use to clear up the haze on the plastic headlights?
Josh
