Results 1 to 23 of 23
Thread: DIY Wheel Speed Sensor Replace
    La$ Vega$, Nevada
    Left / Right Foot
    Hi there....
    Does your "DSC" , "ABS" and/or "Brake" Light illuminate ???
    Do you feel a funky motion on your brake pedal????
    Chances are...you Wheel Speed Sensor Needs replacing.
    & Today I will teach you how to do so...
    So lets get started!
    You Will Need:
    Some Hex wrenches, Some Dielectric Grease....and of course some Wheel Speed Sensors!
    * Alright...so when your cluster looks like this..its time to do something about it.
    * Pop the wheel of your choice off...For TODAYS example....we will be doing BOTH FRONT wheel sensors... Jack the car up....and turn the wheel FARTHEST to the side you will be working on. This will give you the ULTIMATE clearance you need to work!
    * BEHIND the wheel hub...you will find ONE, 5mm Hex bolt. Undo the bolt....and you might have to wiggle the sensor a bit to ajar it loose...No pressure...just take your time. You some pliers if you have to!
    * Next......Follow the sensor wire up a bit..you will find that is its snuggled into place out of harms way...simply remove from the holding bracket.
    * Once you remove the sensor from below....you will find that YEARS of road grime have accumulated. REMOVE will wire brush.
    ( So fresh and so clean clean! )
    * Once you have taken care of down below. Its time to TOTALLY remove the sensor. Locate the junction box housing BOTH the Brake Sensor AND Wheel sensor plug. Pry the tabs to open the box.
    * Locate the DARKER colored connector. THAT is your wheel speed sensor.
    * The connection is held in place by a REALLY small tab. Chances are..after YEARS of road grime..and water..and dirt...it will prolly just CRUMBLE away like mine did. So PLEASE PLEASE PLEASE be gentle. Worse case scenario ....You will have to order NEW connectors all around. ( Like someone else I know! )
    * Simply disconnect...and insert the NEW sensor. Make sure you have a good connection with a "SNAP" Then before you replace the sensor on the bottom..place a dollop of dielectric grease to smooth things over.
    * Now route the cable accordingly..Place your Wheel back on....and guess what....
    You DONE!!!!!!
    The OLD Sensors....CRACKED and brittle EVERYWHERE. No wonder the ABS light kept flickin on and off!
    Anyhoo.....I hope this solved SOMEONES problem....
    Keep it on the real
    Your Savvy E38 Tech Gal,
    Miss BimmerLV
    XOXO
    Insta: @Ella.Emanuelle.Rose
    1998 BMW 740iL - M62 - Projekt "Allyssa" ( Nicht Aktiv )
    2001 BMW 750iL - M73 - Projekt "Hanna" ( Aktiv )
    2001 BMW 740iS - M62Tü - Projekt "Lea" ( Akitv )
    V12 Klubmitglied <3
    IcemanBHE's Avatar
    IcemanBHE is offline ¿pǝpɹɐʇǝɹ noʎ ǝɹɐ
    Wichita,KS/FortCollins,CO
    (4x7)+8=36
    Rochester, NewHampshire
    92' e30, 91'e34, 2k e38
    91' E34 535iM, 92' E30 318iC "vert", 00' E38 750iL "highline"
    Desert
    Just 1 E38, for now
    Iirc a way to test the sensors is to jack up the car and start it, then put car in neutral. Spin each wheel by hand and see if it sets off the sensors. If the sensors light up on the dash that means the system is detecting "slippage" and the sensor is working. If it does not light up that means it's faulty. This may be more for traction control than ABS not 100% sure.
    Quote Originally Posted by AquilaBMW View Post
    Some say he can remove a Jesus Bolt with his pinkie and that when he drives down the road, E65's are his personal escort around Vegas. Some say to look into his eyes is to see the Nirvana or E38 knowledge and that when he walks into dealerships, Service Managers quit their jobs. When he goes shopping, car prices drop. Others say that non-operational car start for him. It is claimed in Tonga that he is a BimmerWhisperer. Some say that he does not need a test drive to set up his coilovers, he adjusts them telepathically and after he installed KIDO, McLaren started using them and won 12 straight Formula trophies. He considers 2014 cars old as he is already testing 2015 cars on the track and cars 2001 and older are classics to him. Some say when cars suffer cardiac arrest, he is able to revive them with an electrifying touch. BMW cup holders work for him, and when he walks by VANOS clunks cease to exist. All we know is he is the Sig!
    Jul 2010
    BIMMERLAND, California
    2001 BMW 740i Sport
    This is weird!!?? Mine just started doing this after I washed my car today? Drove it like for a while to BMW Long Beach to pick up my Roundel that was stolen last Sunday during mass. Yes, I know I bought at the dealer. Got it for $23 and it's really nice.
    Kooljess 2001 740i Sport (Society of 7's) (OO=[][]=OO)
    http://www.wix.com/oppasbimmer/society-of-7
    Desert
    Just 1 E38, for now
    Water alone should not set it off. Sounds like there is insulation damage to the sensor itself.
    Jul 2010
    2001 BMW 740i Sport
    Quote Originally Posted by sigtwenty View Post
    Great!!! It's not what wanted to hear. OK, question. How many sensors does the car have? I am assuming one up front and one in the back.
    May 2010
    Las Vegas
    05 LS430 UL + 12 FIT SPT
    I'd like to change it out on the 740 but I dunno which one is bad...does your fancy software you carry around in your car tell you which is bad?
    Maybe we can make a pit stop on the 740 tomorrow
    750IL SOLD....I'll miss you!
    Desert
    Just 1 E38, for now
    If the comouter has access to the ABS system it should say.
    ABS has a sensor on each wheel in the front and back if they are 4 channel systems.
    La$ Vega$, Nevada
    Left / Right Foot
    Quote Originally Posted by kooljess View Post
    Car Has FOUR Sensors. ( ONE for EACH Wheel )
    $170.00 Each!
    Quote Originally Posted by C8V6C View Post
    Yes, The fancy software that I carry around in my car, can tell which sensor is bad
    "Fancy Software"...Funny
    Last edited by Miss BimmerLV; 04-03-2012 at 07:10 PM. Reason: Automerged Doublepost
    V12 Klubmitglied <3
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    Quote Originally Posted by Miss BimmerLV View Post
    $170.00 Each!
    But I don't have "fancy software" or a PINK screwdriver.
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
    Desert
    Just 1 E38, for now
    Where did you get your sensors from???
    La$ Vega$, Nevada
    Left / Right Foot
    FCP Euro....OEM Brand
    V12 Klubmitglied <3
    Desert
    Just 1 E38, for now
    Wow. Did you use the 15% off code??? Autohauz has them for 113$ I think.
    Del Mar, CA
    91 850i, 01 740i, 06 760
    Saw this on my local Craigslist (for Miss BimmerLV).
    http://sandiego.craigslist.org/esd/tls/2940574214.html
    $170.00 Each!
    Mar 2004
    Tyler, Tx
    Quote Originally Posted by BMSman View Post
    She is slow to react on these, I found this one at local Sears store - has pink drawer liners and even pink keys....
    Aug 2009
    Buena Park, Ca, USA
    2001 740iL, 1951 VW
    $79 at Max's.
    Madison, WI
    1998 BMW 740i
    I purchased cheap sensors on E-Bay for around $43 or so, and of course they dont work. I am now looking to purchase OEM. Where is the least expensive place. I am looking at Pelican for $114.25, but will continue looking. Both my SPeedo and Cruise doesnt work. I tried switching them around, but still no dice. What does the passenger side rear control The Trifecta of lights have been on well before this. Funny thing is my speedo worked prior to changing out, but I thought I would just do them all with new. I destroyed my connector getting them out and had to trash them. Are new connectors hard to put on for someone with medium mechanic skills, but no soldering skills?? I broke the front drivers side sensor off inside and had to drill it out. Could this be causing issues, as the new one didnt fit as well in the socket, but I think I was able to get alot of it out.... thanks for putting up with my questions.
    La$ Vega$, Nevada
    Left / Right Foot
    Bumping.....Cuz Im Doing This Tomorrow....Its Funny Working From My Own D.I.Y.'s !!!!
    V12 Klubmitglied <3
    Apr 2006
    N Miami FL
    00 E38 750IL 92 E31 850
    Sig is right.....your insulation is breaking down and wiring is exposed.....new sensor/s required...
    92 Dinan Stage III 850 Twin Turbo (1 of 4)
    625 Hp on 93 pump gas @ 14 psi 660 ft lbs torque
    Feb 2013
    The Motor City
    1997 750 IL
    Regarding the price. I'm willing to bet that more than 50% of the bad wheel sensors coming off these cars could be "refurbished" since the only real problem is the wires. If you were careful you could probably clean up the wiring and put some heat shrink tubing on it and call it good.
    ---- Processing Individual ----
    Z1XX Upholstery
    Seats front and back in Epingle / leather englishgruen,
    As Schl.Nr. B9EG.
    Front seat backrest in Montana Englishgruen (No. 8 174 861)
    Other interior equipment as for Volleder Nappa englischgruen,
    Schl.Nr. P5EG
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Added to DIY section. Discussion thread will remain here.
    Jan 2016
    Wallingford, CT
    2001 740il
    Harness side connector
    Where can I source a harness side connector? Mine crumbled when prying it apart.
