http://www.bmw-planet.com/diagrams/release/en/index.htm
http://wds.spaghetticoder.org/en/ (Requires IE Browser.?.)
Just an FYI...I can access the site in the quote above using FireFox on my work PC and on my Mac @ home.
On my PC...the diagrams that appear small & illegible...can be expanded by pressing the Ctrl & the [shift]"+" buttons...and can reverse the expansion by pressing the Ctrl & "-" button. I can move the diagrams by click & holding the left mouse button...then moving the mouse (or trackball) in whatever direction I need to move.
On my Mac (using FireFox) is similar...except I think I can use the scroll wheel on my trackball to expand the diagrams.
And if you have a mouse with a wheel...you may be able to use the wheel to expand the diagrams that are too small to read.
Hope this helps anyone that gave up because the wiring diagram was too small to read.
I will apologize and retract my statement. Spaghetticoder used to run the same java and frames based WDS as BMW-Planet.com and the WDS I have inhouse. That version did not play well with anything but IE. BMW-Planet had a blurb about it. It appears Spaghetticoder is now running something different.
/.randy
Damn, James is still around... Damn 54ODell is still around
If I may you might want to refer to this link instead:
As it shows the other versions for other markets too.
HTH
Yes I had to rewrite all the index pages of each section in order for WDS to play well with pretty much any browser on BMW-Planet.com
BMW pretty much hardcoded the HTML pages to work with IE only.
I had some help on the way as Firefox 3.x when it came out would not work anymore.
Now it is all good, have not heard any complain since.
Neither of these links appears to be current anymore. Does anyone have a lead on wiring diagrams which are still available?
"In theory, there is no difference between theory and practice, but in practice there is."
