Originally Posted by
Evil Spoonman
Well I said this was for another thread, but I lied. There are a huge number of principals governing good airbox design. It is my opinion, by looking at the design, that BMW actually designed their airbox to filter air well, not keep noise down.
Don't we want our engine to last a long time? It is actually important to filter the air going in to it. Most people who know something about intakes swear by a good paper panel filter. They simply filter the best. One of the ways a CAI will offer more flow is to filter much less well. You compromise some flow here for cleaner air. I think this is a fair compromise for the longevity of the engine.
Does the M/S52 really need all that much flow? The displacement is not especially large, if it is getting enough air then the increased flow of CAI wouldn't really help anyways. There is such thing as 'too much flow' as well, something around 200 ft/sec is too much. BMW's engineering of this intake is quite good, I imagine the pipe size is pretty ideal.
Consider valve resonance. Pressure waves moving back through the intake system created by air momentum reflecting off of the valves when they close. These will reflect off what they hit. This can be the back of the intake plenum (determining runner length to some degree), the throttle plate, or the next surface which will be the air filter. Pressure waves not only disrupt airflow, they confuse the MAF which cannot tell the difference between air moving 'back' down the intake system, or air moving up it. It only knows how much air is moving over it. The funny little handle on the stock airbox has a purpose. It is a helmholtz resonator designed to reduce the force of these pressure waves as they enter the airbox. This way they do not reflect back up the intake and confuse the MAF readings further.
The position of the MAF and its environment determine how well it reads. The short straight run of pipe between the stock airbox and the MAF is therefore not for show. It is to ensure that the reading is correct, and that little kink that most CAIs have will cause disruption and confuse the reading. I am not certain of this, but I have read that the angle of the MAF within the pipe makes a difference as well. Ten o'clock is the commonly quoted 'correct' position, which is just about where stock placement is and I believe it. The stock airbox acts as a secondary plenum to a degree, this can be both good and bad for a MAF-based system (as opposed to MAP). There is a bell mouth at the entrance of the intake port out of the stock airbox, this is good.
Where to draw air from also counts. You CAN select places that are worse than stock. Drawing air from directly behind the radiator stack probably isn't a good idea, nor is it smart to draw from too low. The road surface gets hot and radiates heat very heavily. Pulling from the brake duct or similar will probably result in a higher temperature air than ambient. The stock location looks pretty darn good for an intake.
In short, BMW designed this thing pretty well. I'm sure if you removed some of the design constraints you could make it better. Who has the R&D budget to do this? BMW does, but I haven't seen anything else that looks too promising. Certainly most of the home-brew and commonly available intakes are not designed properly.
Note that heat soaking of the intake components can matter, and should govern materials selection more than wrapping the intake system or something. Wrapping it with reflective material or protecting it may help slow down heating of the intake piping, but if you run for long enough (probably not that long) it will eventually become heated anyways. Better to select a material that does not readily transfer heat, something like nylon or the sort of plastic the stock manifold is made of.
