Page 1 of 8 12345678 LastLast
Results 1 to 25 of 192
Thread: e30 m60 V8 swap and restoration
    Reinholds, PA
    85 344i, 89 535i
    Teaser pic to start the thread off :
    This is a project I've been working on since Oct 2011. The car is an 85 325e, which I bought 12 years ago when I was 15 - it was my first car. I've had a few other cars in that time, but this is my baby. It's a part of me. Many people say they love their cars, I take it to another level of emotional attachment.
    So over the years, I put 200k miles on the car. It had 100k on it when I got it. Coming up on 300k, and I found some serious rust. Very serious. So begins the restoration. I have a much more extensive thread here:
    http://www.r3vlimited.com/board/showthread.php?t=225093
    But I'll try to summarize it a little bit in this thread, with mostly pictures.
    I didn't even know how to use a welder when I started this project, and had no idea how to do metal work. I bought the tools and taught myself, and took the tips/advice of friends - thanks everyone!
    About a month into the restoration, I decided to do an m60 swap. I had previously had an m50 in it, so I wasn't new to engine swaps, and figured I could tackle an m60 swap too. I'm currently in pretty far over my head, but it's coming along nicely, and I'm learning more then I ever thought I could know. I'm not scared of tackling anything anymore.
    Keep in mind, you'll see some pretty amateur work in this thread. This is not meant to be a "Now, THIS is how you do it" thread. It's a "Watch along as I struggle to bring my baby back to life" thread.
    The car in it's final glory, right before I tore it apart:
    The rust that I initially found that caused me to park the car (I can't believe I thought this was all there was)...
    Decided to cut the entire front wheel housing off. It's held on by spot welds. A few hundred of them.
    And here is the strut tower housing, with about 80 spot welds drilled (I'd say there's another 10-15 very difficult to reach ones left before it's ready to be removed).
    85 325e m60b44 6 speed / 89 535i/5
    e30 restoration and V8 swap
    The finished product!
    Nov 2009
    Tórshavn, Faroe Island.
    E36 323i
    read the entire thread over at r3v, good stuff.
    Reinholds, PA
    85 344i, 89 535i
    Chassis measurements, anyone?
    Started filling in the huge hole I made in the firewall
    Picked up a new wheel housing from BMW
    Since the wire harness grommet hole and pedal mount are two areas that would be nearly impossible for me to replicate, I found a donor.
    Donor:
    Pedal joint replacement:
    Making floorboard patches:
    Well, if I can use a welder, I can do an m60 swap. So I went and bought this. m60b40 from a 94 740il, 134k miles, came with a bunch of new gaskets and stuff.
    Drivers floorboard finished up:
    Reinholds, PA
    85 344i, 89 535i
    New wheel housing plug welded and stitch welded into place.
    Proof I didn't mess up to bad: strut tower bar fits (it did not fit before this, the tower had collapsed quite a bit)
    On to the passenger side:
    Cowl area fixed
    Removed battery tray
    Rewind time 5 years... I was t-boned by some idiot not paying attention. Totaled the car. I didn't want an r-title, so I let the guy give me all the money he had and didn't report it to insurance. A whopping $700. So I'm a teenager with a bashed in car, with no money. My uncle welded on a new quarter panel for me, but it was a cheap/rushed job, and it wasn't done correctly. Fast forward to current - the bondo is cracked, wavy, the panel is rusting at the seam. Might as well address is.
    Mo rust!
    Gone...
    Front strut tower support welded back on
    Passenger side patching
    Welded up some more nastiness in the cowl area
    Reinholds, PA
    85 344i, 89 535i
    For the first time in three months, she's standing on her own feet again
    Made some brackets so that I can remove the core support. It was welded in from the factory, makes engine removal a bitch!
    More rust! Yay!
    Fixed:
    Time for some custom work. The m60 leaves no room for a brake booster, I decided to try to fit the e34 remote booster linkage into my e30.
    Reinholds, PA
    85 344i, 89 535i
    Back to the 1/4 panel:
    Goodies for the engine arriving
    More 1/4 panel work:
    New shoes:
    More 1/4 panel:
    After a coat of fiberglass filler:
    Had a friend make some subframe spacers:
    Engine mounts:
    Hell yeah!
    It's close. Really close.
    Check out all the room I have to make the headers fit!
    Even more 1/4 panel:
    Oct 2008
    Auburn,Alabama
    E-36 325I 1993
    good lord
    killing the cancer one weld at a time
    Reinholds, PA
    85 344i, 89 535i
    And this is where I am today, 2/16/12. Still a ways to go, but not bad for 4 months! I'll try to keep this thread updated as the car progresses.
    Sammamish, WA
    95 Hellrot M3/02 MY Z06
    Very Cool!
    John
    '95 Hellrot M3 w/Dove
    AA Euro HFM Stage II (w/21# Injectors & Software) W/Gen III Exhaust - URI Crank Pully - FDM w/3 Row M Coupe Rad - 3.23 LSD - Vogtland Club Spec/Koni SA - UUC Red w/Enforcers - TMS Shims/Rear Camber Bars w/QA1 inners/Sways - VMC F/TMS R End Links - X-Brace - Perf Ultimate/SS Brake Lines - GC Tower Mounts/RTAB Shims - ZKW's w/5000K Hid - Fog Delete - Alpine 9847/Pioneer TS-C130R Kevlar Components/Pioneer PRS-X340/Stealth Box's/Wired Zune 120GB - OE LTW CF Sills/Glove Box Plate - Staggered Black M-Spoke II's w/235/40 (front), 255/40 (Rear) Nitto NT05's - Rolled Fenders!
    ***Got a '95 M3? (actually pretty common on all years! Even happened to Racer Seth Thomas! ) Check Your LSD! http://forums.bimmerforums.com/forum...d.php?t=390209
    Feb 2004
    Los Angeles | CA
    95 M3 Turbo, 07 650XChlg
    Wow! Extensive and excellent work.
    WTB: E36 ZKW Headlights, ACS Rear Diffuser,E36 M mudflaps front + rear
    Oct 2008
    Wilkes-Barre, PA
    2015 BMW M235i
    Wow man.. awesome work. Keep it up!
    2015 M235i 6MT
    Sep 2008
    Sacramento, CA
    '95 Accord, '63 C10 (X2)
    Looking good! I love restoration threads!
    CA
    '82 Euro 635CSi
    Wow, I mean, I've seen build threads before, but never have I seen one where someone essentially rebuilt every part of their car. Awesome work, can't wait to see more.
    Sammamish, WA
    1997 M3, e30 318i (vert)
    Great work man!
    Serious question though: Driving this thing around, won't you always have that little voice in your head saying that your in a car that has practically been cut into a hundred different fairly structural pieces and then welded together?
    Maybe I'm just over thinking it, but still. Curious to hear thoughts on this.
    Hafnarfjordur, Iceland
    Brilliantrot E39 M5
    Goodjob
    I've heard that E30 guys that are swapping M62B44 engines in there cars are using headers from a X5
    Reinholds, PA
    85 344i, 89 535i
    Thanks guys!!
    Quote Originally Posted by Jboss12 View Post
    Good welds are stronger then the metal pieces they are connecting. The unibody is just a bunch of stamped steel panels spot welded together. I replaced a lot of that metal with thicker metal, and seam/stitch welded it. It should be much stronger then when it left the factory. One thing is for sure, it will be MUCH stronger then it was before I did this work, when every seam in the car was rusted and/or non-existant...
    Quote Originally Posted by bErio View Post
    Goodjob
    Yup, e53/e38 4.4 headers are about the same.
    Already acquired But they still need heavily modified. It's basically just a good starting point.
    Sammamish, WA
    Quote Originally Posted by JGood325 View Post
    Thanks guys!!
    Ahhhhhhhhhh good point, kind sir
    calgary, alberta, canada
    1988 325is
    nice work!
    Jul 2003
    Hong Kong/Dongguan, China
    2010 W204 C200 Cgi
    I don't care what anyone says, these are the things that threads are made of. Hats off to you man.
    Benz forums have shown me that there really are stupid people AND stupid questions.
    Nebraska
    1989 Geo Metro
    That is a shitload of work. Well done. I would have just bought a different car...
    Los Angeles, CA
    now.... THIS is a proper build thread!!!
    love it!!
    DUDMD's Avatar
    DUDMD is offline BMW Maniac Supporting Vendor
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Great build, I love the M60 engines.
    I have a couple of questions:
    Are you keeping the ASC+T system or going to remove it and go with a non-ASC intake boot?
    If you need a manual M60 chip that will run perfect in a 404 (non-EWS2) DME, send me a PM.
    Performance Tuning and EWS Delete for MSS52/MSS54/MSS54HP/MS41/MS42/MS43/ME7.2/M5.2
    Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43, MS45, ME9.2 and more.
    Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
    Reinholds, PA
    85 344i, 89 535i
    Quote Originally Posted by DUDMD View Post
    Nope, going to run non-ASC with the proper boot. FYI, it's possibly just to remove the ASC throttle plate and use the housing as-is, I did that on my m50 car until I bought a proper non-ASC boot. You can even leave the throttle plate in... but it looks like a restriction to me.
    PM sent regarding chip.
    Flaming river steering u-joints. 17mm 54 spline -> 3/4" shaft. You can see how much thinner it is, providing the necessary clearance for the exhaust manifold:
    Also did some work to the firewall, since the master cylinder is shifted to the left, it can't use the same firewall hole. I welded in a plate with a hole cut out to fit the master cylinder grommet. Was a PITA, with how cramped that area is with the wheel housing in place. The hard line clears the brake linkage movement where it is.
    Sep 2002
    Atlanta, Jawja
    E36 | E55 Wagon | W126
    Quote Originally Posted by Volf View Post
    Yep, agree 100%.
    Geordie Johnston - E36 Collector.
    Im disgusted AND impressed
    PRICE CUT on ALL FABRICS
