car 323i 99 AT 253K+ miles.
So, after coming home form work yesterday I deiced to tackle low+high+fog lights coding with ncs expert
changed in GM
Code:
FH_ABSCHALTKRITERIUM
ece
FH_ABSCHALTKRITERIUM worked, moved on to the LSZ
Code:
PROGRAMMPARAMETER_LSZ_1
ece
PROGRAMMPARAMETER_LSZ_2
ece
PROGRAMMPARAMETER_LSZ_3
ece
PROGRAMMPARAMETER_LSZ_4
ece
PROGRAMMPARAMETER_LSZ_5
ece
PROGRAMMPARAMETER_LSZ_6
ece
PROGRAMMPARAMETER_LSZ_7
ece
PROGRAMMPARAMETER_LSZ_8
ece
PROGRAMMPARAMETER_LSZ_9
ece
PROGRAMMPARAMETER_LSZ_10
ece
PROGRAMMPARAMETER_LSZ_11
ece
PROGRAMMPARAMETER_LSZ_12
ece
us
PROGRAMMPARAMETER_LSZ_13
ece
us
FL_UND_NSW_NICHT_GLEICHZ had no effect, and after coding also got corner delete from the above changes tried many combination of us or ece PROGRAMMPARAMETER_LSZ_6 plus had no noticeable effect on the lights but if 1-5 are not the same lights would always be on low+high functioned, dial switch or fog button has no effect . only in ignition position , lights off in ACC. so i may have to do something els if I still want SIDEMARKER_US to work but that is not the intent of this post.
So today i move the car to start work on fixing the sunroof (shade clips ordered) moved car to better location and notice transmission error and CEL get code with inpa and 146 CAN Moment interface and 8 Signal air flow meter, DIS only showing .3v from MAF put 1v on the MAF harness and inpa responded as did the car (near stall) at this point looks like the MAF is dead.
So has anybody ever run into and issue like this after coding I doubt it's related but the timing seems suspicious, I did recode car to a old config had no effect and info from navcoder shows
Code:
2/3/2012 12:04:24 PM.078: 80 09 BF 13 10 01 00 00 00 00 34
2/3/2012 12:04:24 PM.078: IKE --> GLO : IKE sensor status: Trans_Emergency_Program Motor_Running
Any further insight is appreciated
