Hello
So my MULF bluetooth module died and I ordered a new one, installed it, everything is good apart from all the voice stuff being in german :P
I know it can be coded to change the language and people have said to use something called MOST optolyzer. But I assume that SSS can probably do it. Can anyone point me in the direction of some instructions on how I would do this with SSS.
Regards,
Aleks
Before you give up, I would try finding out the software number of a US version an flashing with winkfp.
Thanks mate will try. The funny thing is that the part number I used to buy the part is the same and works on the getbmwparts.com website as well
Apparently the guys I bought it from thing that it might be changeable with autologic, It will be pretty much impossible to find someone in AUS with this software. We will see what happens after I have finished updating everything with winkfp.
Oh, then have you tried NCS expert?
I have hence the other post with the error SYS-0005: OBJECT FILE NOT FOUND.
That's what I get when I click on the MULF module I get that error. It looks like some sort of file is missing I was hopping I could click processes ecu and it would give me a dump and there might be language settings ^.^
But I have no idea what file it needs to avoid this SYS-0005 error. There must be like some sort of module description file somewhere.
I tried re-flashing the the software with WINKFP to the same part number as in inpa UIF under vin it was coming up as ???? and nothing changed (Apart from it having the vin in the UIF and not ??? anymore ). But I did waste a good 2.5 hours :P
German it is :P
OMFG PEOPLE IT CAN BE DONEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
First of all I think lots of people owe an appology to bimmernav, I cant count how many people have been abusing him over this issue and the whole time he has been saying it can be done, and it's just the BMW mechanics that suck.
Well he was right
Here's my story:
Before I even start, people, don't use SSS/progman for anything, the software is a joke. Winkfp, ncsexpert are much better alternatives.
I have a 2006 325i Sedan. My bluetooth module died (Non iI\-drive car) . I used realoem found the part I need, ordered it etc etc Fitted the part everything was good, except when I pressed voice recognition it started talking to me in german. ((
I looked through countless threads with everyone saying, this can't be done, bimmernav ripped them off blah blah etc. To this today, I though it was over and I would just have to get use to it in German.
But then
I thought I would give NCSExpert one more go since, I updated a lot of files from V41 daten stuff. Anyways this time I clicked on the MULF module, dumped the TRC file, opened the TRC file and guess what is the first line.
sprache
deutsch
So I save the file over the man file, change the deutsch to
sprache
englisch
Do the code.
Press the voice button and the most beautiful words come out. Please add telephone ahahha
For those of you reading this that are going how do you setup ncs expert and use it. I really can''t help. I'm ultra noob at it as I just started using it and I had to keep flicking back and forth through the doco as I was doing this.
BUT THE MAIN POINT IS:
IT CAN BE DONE )))))))))))))))))))
Also it would be great if someone could have a look and tell me what any of these other options are as I don't speak german :P Is there one to say sync phonebook contacts as it currently isn't syncing with my iphone 4. But I have a feeling that's just because the iphone has the latest firmware and apple has screwed something up.
SPRACHE
englisch
BT_UFN
wert_01
EMERGENCY_NUMBER
wert_01
SYNCML
nicht_aktiv
AUDIO_SETUP_2
wert_01
DPD
wert_01
TEL_BUCH_ASYNC_CONTROL
most_async_channel
UNICODE
nicht_aktiv
DUN_EIN_AUS
aktiv
SORTING_VARIANT_2MULF
standard
PHONE_TYPE_JAPAN
nicht_aktiv
MIC2MOST
nicht_aktiv
RESPONSE_ON_HOLD
nicht_aktiv
RING_TONE
wert_01
BT_OBJECT_PUSH
nicht_aktiv
BT_BEDIENHOERER_C12
nicht_aktiv
CONTACT_LIST_C12
nicht_aktiv
DISABLE_NOKIA_WA
nicht_aktiv
INCOMING_CALL_LIST_C12
nicht_aktiv
MULTI_PARTY_CALL_C12
nicht_aktiv
SMS_EIN_AUS_C12
nicht_aktiv
SVS_EIN_AUS_3
aktiv
PHONEBOOK_NAME_DISPL_ORD
last_first
If you still want to syncronize the phonebook try to change the comand SYNCML into AKTIV.
Regards
Hi Guys,
Sorry to bring up such and old thread. This weekend I'm going to try changing the SYNCML to AKTIV as mentioned by darwinland and will update the results.
Regards,
Aleks
Bad news, it didn't work. Tried it both with and iphone 5s and nokia 1020. Oh well no contacts for me
Would you not also need to change CONTACT_LIST_C12 to aktiv?
__________________________________________________ __________________________________________________ __________________________________________________ ______________________________
Save 5 Euros on the purchase price of a Genuine Carly for BMW adapter by entering voucher code ZAG6FX into your shopping cart when purchasing from the Carly Apps website.
I don't know that's why I'm on this forum :P I'll go try it now
YAYYYYY IT WORKED !!!!!
Thanks everyone for your help. I hope this helps someone in the future. CONTACT_LIST_C12 to aktiv fixed my issue. I don't know if the SYNCML needed to be enabled as well. But they are both enabled now and all my contacts from an Iphone 5s have downloaded to the car.
Also to give some background if anyone comes searching for this:
Car: 2006 BMW 325i non-idrive model.
Problem: Contacts not syncing to the car. When people call their names come up and last dialed also names come up so it was getting the information but not displaying in the phonebook. All you could see was a directory of letters with no names.
Solution: Using ncs expert, selected the MULF module I installed about two years ago (I believe it has software from 2008 though). I re-encoded the car changing SYNCML and CONTACT_LIST_C12 to aktiv.
Regards,
ALeks
Hi
I have the same problem, contacts not syncing, what module has the CONTACT_LIST_C12 and SYNCML options? can't find the options on my C-APP module?
