Always FUN TO DRIVE - Build Thread & Tech info - 79 320/6 track car build thread -- Videos of track car -Adam in car Auto-x video - Start-up video - 4/2011 Adam's TOP BMW time San Diego BMWCCA - 4-5-15 Dyno break-in run new M20B25 - Exhaust Thread - Link
Charlie Scott (chad e46) /thread
Now I love that! What size are those bbs's?
16x9 et 1 16x10 et -1Originally Posted by Chubbz
So perfect
This at a minimum... I would argue that front control arms should be above parallel. If you start with parallel, they'll be less than that once suspension compresses.
Ultimately, handling is about having good suspension geometry which is what determines how the roll center relates to the center of gravity, how weight transfers, and how well the car can maintain the maximum contact patch through a corner. What are the adverse affects? As control arm angles go below parallel, the roll center of the car gets lower and further away from the center of gravity, significantly increasing body roll. Body roll increases the amount of time it takes for weight transfer to occur (weight transfer is what plants a tire), and also reduces the contact patch (or makes it more difficult to achieve maximum contact patch) in a turn.
If you are serious about real handling to carry speed through a corner, not just the allusion of handling due to a low center of gravity and stiff suspension, you will be concerned about suspension geometry. You can slam your car and have the feeling of "good handling", and it can be fun to drive that way on the street, but it will not be fast or be capable of pulling the same g's compared to a car that is well balanced and has good suspension geometry.
The difference between a guy who wants stance and one who doesn't is the importance they place on the real performance of their vehicle vs the look. Different strokes for different folks, if you disagree, get over it. I like the stanced look (with minimal stretch, that is) and really want to go lower with my car and eventually will. The adverse affect on handling will be just fine for 99% of the driving I do. However, at the same time I intend to do some major subframe work to counteract the adverse affects as much as possible. For the 1% of the time my car actually needs to handle well (autox or a track day), it will get raised back up to have better suspension geometry.
As it is now, my rear subframe is already raised 1" over stock. This greatly improved straight line traction simply due to better trailing arm angles..
Just my $.02. I'm certainly not trying to start an argument, just stating the facts on lowering a car. If you want it low, I say go for it. It looks good. Just understand that beyond a certain point it is not a performance modification. It's just a modification.
Thank you so much for actually explaining this. But for me, low is the way to go. I auto x maybe once a year, the rest is spent daily driving....sometimes spirited. Btw, love your car amg auto x vids.
As a reference for those interested in handling, this is what Dinan considered the ideal ride height for handling. It sits higher than most lowered E21s, and even at this height they modified the subframes to improve the geometry.
Well, dinan knows what they are talking about....but I can't get past that gap honestly
Not all roads are glass smooth. A nice twisty washpan back road will be the real test. Dinan knew that.
Once again, i'm not arguing that fact, I just don't like it
damn, meant washboard
some folks however swear by their daily use of bump stops.
Thankfully around here, there's no use for bump stops.
how about some added luxury?
camber?
chubbz, just messing with you. love the neeks car look just like everyone but, I favor the Dinan philosophy for suspension tweaks. too each their own as has been said. good luck with your "new" e21 as i can feel your excitement. looking forward to pics of you tearing her apart to upgrade per your specs.
I don't see where you're going with this?
and you think i do? here's another guy with a slammed car.
I've got Billys all round and the '82 323i is lowered about 2.25" below stock or more. G-d it hit just about any bump in the road. I have to say the static drop is best and with the 15x7's on the car, it almost doesn't slip out on tight corners.
I still drive daily with no commute...
The Hazard is All, Praise the Hazard!
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
They don't, THAT'S why I asked. I figured if he did, how he got them to work.
Just because i'm fairly new to the forums doesn't mean i'm clueless. I simply asked questions and get insulted and made out as an idiot, which I don't appreciate. If this is what it's about in here, I'll gladly step away.
i don't believe he said he has billy coil-overs, but that he has billys all round. if indeed he has a coil-over front struts, well then that's fairly easy to make using VW inserts, some treaded collars and shortened strut tubes.
maybe you should take less of a i know more then you attitude and ask a question using full sentences. we, unlike most forums, are a pretty helpful group, but you seem to be irritating the masses.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
Tom. In no way do I feel like i did or said anything to irritate anyone, nor did I use the approach that I know more than anyone. All of my posts are grammatically correct and should be easy to understand. If posting "this thread has shown me how little you know" is a helpful response, then count me out. I don't take disrespect lightly.
And the only reason I asked about the billy coilovers was because of the drop he accomplished.
