After seeing all the requests as to how to replace a battery on a Comfort Access only key FOB I thought I would take a few pictures and explain how to do this.
First of all take the key out of the key FOB. You need to squeeze the FOB at the middle in the back where the key ring is located and pull. Once the key is out look for a small slit where the key used to be. Looking from the end of the key FOB you will see a small slit close to the top of the key FOB. Insert whatever you wish that will fit like a coin or small scewdriver and pry gently pry up. The cover will pop off and expose the battery (CR 2032). Replace the battery and then replace the cover.
That is about it.
Look at the pictures to back up this explanation.
. Please remind me in a week or so to tow it to the DIY section. I will leave it here for now just in case anyone wants to post any followups.
Current Car (delivered 20/10/21): 2021 G80 M3; 6MT; DravitGrau/Kyalami Orange/Black Extended Merino; Permium Pkg (ZPP); 826M bicolor wheels; Black M Compound brakes; Sunroof (yes no CF roof)
(more pictures here)
Previous Cars: 2018 F30 340ix 6MT Msport(Dec 2017 - Sep 2021); 2013 F30 335ix 6MT Msport (Nov 2013-17); 2011 e90 328i 6MT ZSP (Aug 10-Nov 13); 07 e90-323i ZSP (May 07 - Aug 10); 97-318ti ZSP (Feb 97 - May 07)
"Mit der Dummheit kämpfen Götter selbst vergebens", Friedrich von Schiller -- "Life is simple, people make it complicated", Me (About me)
Will do...
