Does anyone know if I can take a regular Vag-com cable it and make it work for DIS/GT1? I know it's already been posted somewhere, just kind of search Impaired today Also will it still work for Vag-com and Carsoft afterwards? I have the USB style cable. Oh and for ALL the programs, would a OBD2 to roundel connection work / or be a better way to go?
For Sale: (E36) Trans ECU, OEM amber corners, Stock Mirrors, stock amp,E46 Amp, Need to Use an SRS Reset / E36Code puller? E46 Programming Module PM me
Wanted: E46 Post facelift Carbon Fiber Hood. Have and E36/46 problem..MSG ME. I would be glad to help you out!
Want error free LED License plate lights for less? Go here: http://forums.bimmerforums.com/forum...4#post21079814
Check the Diagnostic Software forum. They have all the info on connectors and software.
On a post 1996 car, only some modules support a VAGCOM lead.
You can access the DME and EGS under the steering wheel.
With a 16-20 pin you can get additionally a could of others, such as the HVAC.
If you want the ABS and possibly the Airbag, you will need an $85 ADS adaptor fed by a factory fitted serial port.
E36 DICE MediaBridge BT and iPod support Photo location of the cabrio drain holes. Custom heated seats and lumbar support retrofit. Glovebox charging sockets and cupholders. E36 PDF Schematics UK Aftermarket E36 OBC bulbs Convert rear lights from non check-control to check-control DIY BMW E36 MFSW retrofit pictoral DIY All BMWs UK cheaper source for electrical connectors, Farnell, RS BMW INPA success E46/E39 onwards E36 vert mood lighting DIY BMW E36 puddle light and inner handle illumination DIY. E36 convertible flat bungee tension strap fix DIY BMW E36 PDF manualBMW E36 vert water in motor of tonneau area fix.
Ive seen some designs for converting the Vag-com to an ADS....So that's what Im looking for. Just not having allot of luck with the search button today. Also does anyone Have INPA?
Would love to see that link. It might be possible - there are a couple of hurdles to overcome, on in EDIABAS itself and the other in the hardware.
Here's some I wrote.
http://www.bimmerforums.co.uk/forum/...nwards-t74608/
http://www.bimmerforums.co.uk/forum/...rfaces-t85191/
http://www.bimmerforums.co.uk/forum/...h-inpa-t85971/
Well Luckily my Vagcom cable has the FT232RL chip inside of it. So I just need to solder 7 and 8, and then load the software. Amazingly I got DIs/GT1 to run on win 7 x64 by using XP MODE (a free MS VM that includes XP) and VMware 8.5
Soldering 7 & 8 is only necessary for cars without the round socket under the dash. You will notice pin 8 isn't even populated on your 16 pin socket.
When you use your 16-20 pink adaptor, the three pins TxD TxD2 and RxD are shorted for you.
