COMPLETE PARTOUT FOLLOW THIS LINk--------->>>>>>> http://forums.bimmerforums.com/forum....php?t=1781662
The title is clean and clear. Chassis has ~170k miles on it, but practically everything is brand new.
At 16psi the car made 444whp, at 18-19psi it made 493. This was on a Dynojet. Needless to say it's quite a sleeper!
The bad:
I have resoldered all the solder points on the speedo head and the cluster board, however the speedometer still intermittently functions. The body as you can see is not all that great, there is a large but fixable dent in the quarter panel; but there is no rust, something you don't see in e30's very often. The interior isn't great. The dash has all the normal cracks, the left rear doorpanel is badly damaged, and the front passenger doorpanel has a few knicks as well. The carpet is died black, was originally tan. Also no glovebox, the one I have the hinges are busted up on it. I may have one for it semi-soon. The blower motor switch used to work on the lower settings, then it got to where you had to push it in and finagle it to work, now it only works on level 4, so it needs the switch. The sunroof does work however the handle is broken(typical),
however I've never liked sunroofs so it doesn't bother me. The handles are cheap to replace though if it does bother you.
The good:
Chassis
· Brand new fuel tank
· New sending units
· Brand new fuel filter
· All new fuel lines
· Miata seats
Suspension/Wheels/Tires
· AKG Urethane Subframe bushings
· AKG Urethane Trailing arm bushings
· AKG Urethane Differential bushing
· AKG Urethane Front control arm bushings
· H&R Race springs
· Bilstein sports shocks
· Ground Control front camber plates
· Ground Control rear upper shock mounts
· Brand new front lower control arms
· E36 steering rack
· kalib0y 75mm wheelstud set
· 5mm spacers in front
· Esm-003 17x8.5 et25 wheels
· 235/40/17 Nitto NT-05 tires
Brakes
· Brand new front and rear rotors
· Axxis Ultimate front and rear pads
· Brand new parking brake shoes
· Stainless steel brake lines
· ATE Super Blue brake fluid
Engine
· 96 M52 bottom end
· 93 M50 cyl head
· M52 cam trays/lifters
· S52 M3 camshafts
· M52 vanos shims and main tensioner
· All new seals/gaskets
· Brand new timing chain guides
· Brand new water pump
· Brand new aluminum thermostat housing
· Brand new thermostat
· Brand new drive belt
· Cometic .140 MLS headgasket
· ARP headstuds
· M50 Intake manifold
· Low temp fan switch
· SPAL pusher fan
Drivetrain
· M52 dual mass flywheel
· F1 Racing Stage 3 clutch
· G260 transmission
· White325is transmission bracket
· Revshift e30 24V swap motor mounts
· Revshift transmission mounts
· Brand new guibo
· S2.93 LSD differential
Turbo
· Good & Tight M50-E30 turbo manifold
· Tial 44mm wastegate (external dump)
· Precision 6262SP turbo
· -3AN oil feed tapped from VANOS feed bolt
· -10AN oil return
· CX Racing 24x12x3 intercooler
· Aluminum intercooler piping with silicone coupler and Tbolt clamps
· Tial 50mm BOV
· 4" K&N Filter
· Stainless 3" exhaust
· Magnaflow stainless muffler
Management
· Siemens Deka 60lb (630cc) injectors
· Walbro 255lph in tank pump (hardwired with relay and 10guage)
· Blowthru mass air flow sensor
· Roadkill tuned 413 DME
· PLX M300 wideband o2 sensor
· Brand new narrowband o2 sensor
· Hallman ES Manual boost controller
Ice
· Kenwood CD player with Ipod/Aux front inputs
· New Alpine speakers front/rear
Some may think I'm crazy, and that's ok, but I am asking $8,000 or best offer. It would be next to impossible to replicate this car for the same money, and worst case I will part it out if I get no interest.
Back into a BMW, this time a track rat....and it won't be BMW powered and no, not a V8 either!
Couldn't help myself, boosted e36 m52 street car in progress also!
If you were closer I would love to pick up something like this.
GLWS
Shipping is only 5-600 bux...
If my M3 sells quick then we may have to look into some shipping quotes.
If only i had 8k, I'de trade you my s13 in a second.
Im in richmond, so were close If you want I can pm you my details of payment. Looks like you did a mighty fine job
If only I had an extra $8,000 I'd throw it your way. I'd love to have something like this. GLWS
Thanks for the kind words. Zurichone go ahead and pm me
Pm'd you
Replied. Bump.
If you decide to part the turbo setup it is the exact setup I am looking to build ATM in my S52 E30.
Thanks, I'll keep you in mind if it gets to that point.
Bump!
I appreciate it, bump and GLWS
what exhaust housing .ar did you use on the 6262? any dyno graphs?
i was considering this turbo for my m52..
Trade for a 95 M3 Avus on coils?
85' Turbo M50 E30 | 95' M3 Nitrous, Coilovers, DJ Autos, UUC SSK
It has a .82a/r vband housing. I tried to get he graphs for a while but Keith@TTR has been to lazy to do it for me lol.
Thanks Dan, but at the moment I'm just looking for cash.
Great car. Fair price.
It reminds me of my E30.
What a sick set up at a amazing deal.
I can vouch that this car is in great mechinical shape and was built properly.
RK tunes
Absolutely stunning, would buy in a heartbeat if I had the money. Or if I knew I could handle all that power......haha
How much to ship to Sweetgrass, Montana?
2005 Jetta MKIV TDI GLS: Malone Stage 5, VNT 17/22, Eurojet SMIC, TDIParts I/c piping,TT 2.5" DP w/ custom side exit catback, 3 bar map, NSP Indigo Gauges, Ventectomy.
Ty for the kind words.
CG pm'd.
Up
Holy sleeper. That's pretty sweet.
Past Builds:
S54 E36 Compact Build|Thread|IG|@_goldfinger|
Current Fleet:
Z4 M Coupe - Black Sapphire Metallic over Black
Orxan, really sorry, your message somehow slipped through the cracks. Check your pm's
