SMALL UPDATE ON PAGE 2
Hey guys, been lost between work, the car and new g/f. Here's the start to now line up of pics.
car will be run on E85 shooting for 450rwhp for now. Spare built engine is in the works(700HP-ish plans)
Mods list:
Turbo hardware:
Precision 6262 T4
SPA Cast manifold
Tial MVS wastegate
Tial 50mm BOV(black)
eBay intercooler
2.5" hot side pipe
3" cold side pipe
3" turbo intake pipe
stainless hardware for mostly everything
3" or 3.5" stainless exhaust with borla xr1 muffler
M50 throttle body with Turner adaptor
Fuel hardware
Denso 1020 fuel pump(340lph)
Bosch 1000cc injectors
Aeromotive FPR
KRC fuel filter
-8an feed lines
-6 return
OEM rail modified
Clutch/flywheel
GripForce F1 stage 4 sprung with billet steel flywheel
late on M5 diff and axles and new drive shaft
Cooling and oil cooling
E46 aluminum rad
Custom fan shroud and 2700CFM electric fan
Custom aluminum expansion tank
modified M52 528i aftermarket thermostat housing with 80deg C thermostat
19 row oil cooler
S54(E46 M3 engine) oil filter housing with 10an oil cooler lines
Engine managment
MegaSquirt 3X using OEM harness and will retain all OEM functions including fuel tank valve venting, rpm functions, dsc and traction control) FULL standalone not piggy backed
AEM UEGO AFR gauge
Autometer gauges
I'll add more later on.
BTW EVERYTHING IS BEING DONE BY MY FATHER AND I OUT OF THE BACK YARD, WELDING INCLUDED
On to the pics!
FACEBOOK CHANGED THE PIC LINKS SO HERE IS A LINK TO THE ALBUM ON FB SO YOU CAN CHECK OUT THE PICS, SORRY ABOUT THAT!
Album 1
http://www.facebook.com/media/set/?s...1&l=f71739af05
Album 2
http://www.facebook.com/media/set/?s...1&l=37bf91fd76
'02 E39 530i/5sp Topaz Blue/Black Interior - MegaSquirt3x - Garrett GTX3582R turbo - E85 fuel - Apex FL-5 - 265/295 tires - Custom Porsche Brembo BBK - 600whp @ 22 PSI
'15 E84 X1 35i M Sport Alpine White/Coral Red Interior - H&R Sports & Bilstein B6 - Velgen VMB5 - 265/305 tires - ETS FMIC - MPI Charge pipe & DME Flash - 3.5" down pipe
First!!!! :d
2001 BMW 540i E39
Lots of mods and more to come...
under construcion... http://forums.bimmerforums.com/forum....php?t=1204241
Fuel pressure regulator installed
Exhaust VANOS and cam sensor harness re routed
My father and I working on the fuel line install
Lines installed using OEM brackets(slightly modified)
Fuel filter installed in place of OEM one. All lined secured.
On to the cooling system(system is now BULLET PROOF) -16an(1" ID hose ends and line for the coolant hoses)
This radiator is meant for an E46, but now fits the E39 perfectly lol
Installed with fan shroud I made, all aluminum thermostat for 528i(M52), shortened down also to fit hoses.
Some close up of the fan shroud welding
Mount for the radiator(excuse my not so perfect aluminum tig welding)
Lower mounts
pass side
drivers side
Turbo mounted for finalization of the motor mount
Motor mount, completely made of stainless steel(yes a bit over kill)
M50 throttle body with extension welded on
Thats all for now, it's raining like hell outside now.
Left to do: hot side charge pipe, intake pipe for turbo, oil catch can, make new power steering lines for M50 power steering pump, make a DISA block off plate which will also serve as my vacuum source, mount wastegate and lines with boost controller, finishing assembly of my standalone ECU(MS3X), install clutch/flywheel, finish exhaust system, install fuel pump, send out parts for coatings and lay out engine harness into OEM location and wire to MS3X connectors and fire her up and tune!
After it runs: M5 brakes being installed(slotted centric rotors) with custom brake ducting & going to re barrel/new lips/powder coat my wheels, going to do a 9.5" or 10" up front with either 255/35/18 or 265/35/18 and 10.5" or 11" rear with either 295/30/18 or 315/30/18 stay tuned!
LINK TO FULL ALBUM & you add me on Facebook too if you'd like.
Dang,
you're making some rocket work of this one.
BANG it out.
Remember, PM me if you need anything for the shop, friends, family, etc...
Killin' it
This is powerful. Many are viewing this while weeping tears of joy.
― George Orwell
thats almost as good as porn, excellent work man
Thanks man! Appreciate it!
Been a bit MIA haven't I. Working A LOT at work and the new gf is worth spending the time with, heck she helps me out with my welding by holding parts and all! Even wants to work on the car! Can't loose this one. haha
This is the kind of thread this place needs. Love it and looking forward to seeing it run.
Also I dont know what motor mounts you will be using but you can consider these
http://forums.bimmerforums.com/forum....php?t=1724349
2003 M5 LSx l 6 Spd Manual l 4.10 LSD
Build Thread
The chassis must always be regarded as a means to an end and never as an end itself
Dude wtf motor mount - is that solid? Thats incredibly heavy lol.
Cool though!
LOL jesus 20 lbs lol. Its cool looking but holy expensive and heavy wow
Great job looks awsome
Why would 20 lbs be an issue in a 3500 lb car? If anything the biggest concern would be ensuring an ideal weld between the two parts of significant difference in thickness. That said if you have access to CNC machines, why not make the entire mount out of a solid piece of aluminum?
Build Thread
Great work! I will say, tough... when looking at the work on the radiator and T-stat, my first thought was you'd better be running some stiff motor mounts. You'll be flat amazed how much movement stock mount give when you start throwing gobs of torque at them.
/.randy
I wanted to, just this is what material we had there at the time. The mount is going to be actually bolted together then welded up. I may just have this mount scanned and then cut from a soild peice a at later time in case anyone else wants to turbo an E39 i6.
Thank you! Yup, I will prob end up with Z8 mounts or some poly ones. The upper hose is very short (2" IRCC), the lower one is like 6-7" long.
Last edited by JackEatsEmoKids; 10-29-2011 at 09:26 PM. Reason: Automerged Doublepost
Jack I have a pair of essentially brand new Z8 mounts. If you do decide to go the Z8 route PM me your addy and I will send them out to ya.
Build Thread
I got them for $0 which is what I will charge you. If you don't use/need them just send them back.
Build Thread
Soo jelly. I want a 530i like that.
Keep us updated. I friggin love your car.
which black lines and fittings are those?
Love the fab work, looks great!!!
