Page 1 of 5 12345 LastLast
Results 1 to 25 of 104
Thread: The OKI E30
    Louisville, KY
    T67 M3
    The OKI E30
    Beep beep beep
    Find a spare subframe
    take it apart
    Get that junk outta there...
    hmm don't have wheel bearing tool at home. PERFECT!
    more junk
    reinforce time
    toe all outta whack no problem
    grind your welds fool
    Quote Originally Posted by MikeLenoch5 View Post
    Growing up, I thought Mercedes were superior to BMWs, because that's all my parents had and I didn't know that the E30 existed. Now I know the truth.
    Previous vehicles: (87' 528E 5spd) (Two 89' 750IL's)
    (E36 318is) (E34 535i) (E34 M5) (E36 M3) (Two 87' E30 vert) (E30 Touring)
    Louisville, KY
    T67 M3
    Damn steering rack leaking all over my carpet
    I see you
    YAAA
    you too
    put all that stuff back
    HEY axles are done
    Northern KY / Cincinnati
    e36 Track Car
    What class are you building for?
    Regards, Nate.
    www.DriveFasterNow.com
    Louisville, KY
    T67 M3
    Parts make you feel great
    Went with the milled hub
    And just like that
    POWDERCOAT
    straight from a model car kit
    insertion complete
    BAM
    Doesn't need much
    Started some rust prevention/repair
    HAHA wtf old axle?
    Used to sing on the highway
    [ame]http://www.youtube.com/watch?v=Xa5SU2J2a-k[/ame]
    good axle condition
    [ame]http://www.youtube.com/watch?v=xC6pp3p2iBg[/ame]
    Quote Originally Posted by TOOLEAN View Post
    Spec E30
    Gotta get the HPDE's out of the way first. After that it will be time to Cage and do a lot of chassis work.
    louisville ky
    And so it begins.
    Quality BMW service "street, track, race"?
    Email: ZakspeedRacer@gmail.com
    1999 BMW 318Ti/M Hellrot Msport DD/Fun car
    1/2 1987 BMW 325is/M Future Spec e30 (track prep'd)
    1994 530It/A Alpinewise III Traded out
    1988 BMW 325ix/M Diamond Schwartz Recently sold :/
    1986 BMW 325e/m Bronzit Beige Metallic
    Get Involved!
    www.bluegrassbimmers.org
    OKI BMW Facebook group
    BMWCCA Member# 436428
    e36 Track Car
    You are off to a great start, I am not to far away if you ever need anything. Got to caution you though, some of the stuff you are doing is not legal in se30. Make sure you read the rules before you weld anything.
    Regards, Nate.
    Louisville, KY
    T67 M3
    Ah you should come down to one of our monthly meets! OhioKyIndiana is OKI SO come on down!
    Atlanta GA
    97 S54,94 M-Technic,SE36
    Nice!!!
    Louisville, KY
    T67 M3
    Gotta get that gas tank out cause the tabs that hold it ARE COMING OFF!!
    Steel brush that stuff get the brake lines out..
    No thanks
    heres the upstairs view
    welded and rubbered
    rebuild those calipers and put some paint on them that will melt off in 5 min
    bubble flare
    MOre to do
    e36 Track Car
    Are you putting in the Late model fuel tank/pumps? HIGHLY recommended.
    Regards, Nate.
    louisville ky
    Hmm I've heard its better but not sure why? Theres nothing really wrong with external. Plus you have to have the late model tank which I think won't fit. Correct me if I am wrong I am ignorant on this one, but do help me understand what the benefits are.
    Get Involved!
    Louisville, KY
    T67 M3
    Got the RSMs but can't use das boots anymore. Also need to get the correct bolt plates for a hardtop, they sent convertible halfies by accident.
    Got the new filler neck tube and lines
    Retainer clips
    Cut a little carpet out to do a small rust patch
    PIIIIISSSSSSSSS
    One thing at a time. Start with transmission tunnel into floor rust repair.
    More to come:
    Here is shop owner building kitty heaven
    And here is E60 M5 exhaust if you don't know what it looks like, they took 4 iron workers lunch boxes to make the mufflers.
    Louisville, KY
    T67 M3
    Bought some supplies, wanted to see if the cheaper tube was any good vs the 3M seam sealer.
    Time to cut out a new section of floorboard that the tranny mount metal can weld to..
    Clean up the weld surfaces
    Drill holes to weld bottom metal to new floorboard metal.
    hammer time
    view from underneith
    Weld parameter and grind
    Spray and seam seal.
    The hole behind the accelerator has been welded
    So now on to the front corners behind the front wheels where the jack points are
    Cut jack point out
    Bend some metal
    Thats it for now.
    Bonus Material:
    Outside the shop: Me in black zach in white
    Monthly Meet
    brighten that up so you can see better
    See ya next week
    e36 Track Car
    Update the fuel system or you won't be able to run longer events without fuel starvation, ask me how I know. :-/
    Regards, Nate.
    louisville ky
    Which style tank you have?
    Get Involved!
    Louisville, KY
    T67 M3
    Yeah we are going to have to address that soon. I assume you had the old tank and had the issue then put the new tank in and problem solved? Need more input on this.
    e36 Track Car
    Sent PM.
    Regards, Nate.
    Louisville, KY
    T67 M3
    Thanks AKG...
    Louisville, KY
    T67 M3
    Operation rust fix is coming to a close i think. then more fun stuff next week.
    left off with hole in each corner of floorboard where jack pads are.
    took this metal
    thats one
    Zachs welding is getting better.
    Pictures are fun, it looks like it happened fast. Actually that was a day.
    more next week....
    Greenville, NC
    '98 z3, '98 328is
    That's great work man. Thanks for all the pics. Keep them coming!
    "If Anderson Cooper is gay, then I'm secretly a liberal." Stephen T. Colbert
    328is Project
    Louisville, KY
    T67 M3
    You get the idea,
    that, plus 2 final small holes needed to be welded.
    Then sprayed entire underside of car with heavy duty degreaser and power washed.
    not heavy enough and more duty. gonna need to let it sit over night and may need to brush or flapper
    Louisville, KY
    T67 M3
    power wash, scrub, power wash, scrub, seam seal.
    almost time to paint
    Filler neck painted
    floating?
    need to get
    Oct 2007
    ny, ny
    e28 m5 e30 4.4T e36 325
    updates?
    Louisville, KY
    T67 M3
    Large break over. Back to work
    all seam seal and patch panels painted from before..
    20 degrees outside...
    More to come...
    Louisville, KY
    T67 M3
    Fuel and brake lines need to go in, lots of looking at old brake lines and even messing with fuel feed and return, looked to be labeled wrong would not fit so had to swap.
    Brake line starting point under brake booster, without a lift... forget about it.
    Order UP
    Bottom plates didnt sit flush, so after impacting they did...
    upon looking closely, there appears to be a bowing effect to the top of the bushing when torqued against the car... We opted out of the washers as they were thick enough to not allow the aluminum sleeves to enter the body.. The ground off part is typical to allow room to adjust the eccentrics.
    It looks like the bushing is sagging under the pressure..
