Hi gents...
I just received my scanner do-hicky...
and I am having the same IKE & DME connection issues as most. I have an 5/98, 740iA L , So I use the a Female OBD II to 20 Pin Adapter for under the hood. But still no connection to IKE or DME ;(
It doesnt say a production date on mine. It seems they keep switching up the layouts of these things...
Anyhoo....I keep seeing where you need to bridge pins 7 & 8... I took some pics of the inside..
Are Pins 7 & 8, bridged in the photos ?????
Thank You for all your help!!!
xoxo
4 & 5 are bridged, there appears to be no connection to 7.
Got mine from Xcar360. Mine is doing the exact same thing. If I reinstall all software and drivers and somehow get this sorry-ass software to start, it says "error-hardware is not ready". Key is on, amber light on adapter is lit. Is my cable/adapter shot? I've had this thing less than one week. It worked great when I first got it. I was running on and old laptop with XP. Tried to use it on my netbook by downloading from Pa soft website (no CD drive in netbook). Now it won't work on the XP laptop anymore. I even tried a second XP laptop I have. Could the Pasoft software have damaged the actual hardware somehow? I've wasted so much time on this stupid crap.
Anyone with any suggestions, please help. I have reinstalled drivers from Xcar360 CD on my XP laptop many times, no improvement.
I have an issue, I can see all my modules however I code my module to do the convienance windows close but it doesn't work. I tried it with my key an nothing.
Also can anyone tell me how to sync the miles from the car to the instrument cluster using BMW scanner 1.4.
I'm using the bmw scanner v1.4 with an E39. When I recode the one touch option to NOT open or close the sunroof I click write and it confirms with an OK. When I test it out and hold unlock all four windows and the sunroof still open. Same with close, all close. I've unchecked the sunroof option and written to memory multiple times now and it never takes. Any suggestions? Thanks!
Hey Guys,
I have a 98 Z3 (M52/E36) brought the 1.4 scanner and 20 pin adaptor I am getting "Connection Error IKE" only seeing DME and EWS? Check the plug 1/2 and 7/8 are soldered.
Any idea ???
Should i unsolder the connections because I'm using the 20 pin adaptor
"Light travels faster than sound thats why some people appear smart until you hear them speak"
1998 BMW Z3 2.8 - Afe intake, Samco ASC Delete Boot, BBTB, M50 Manifold, S52 Cams. Conforti Software, TMS Pulleys, EMP water pump, Billstein HD/sport struts/shocks, Racing Dynamics Strut brace.Projectors with 6k lumenux HID's. Magnaflow High flow Cat.
i change confort module, (ZKE) i think and now my rain sensor and headlight washer doesn't work. with bmw scanner i can activate rain sensor and headlight washer? thak you!
Does it work well enough to be able to do DME<>EWS pairing?
For those having issues with 'Connection to IKE', see this : "E38 / E39 / E36 / E46 Dash may require the use of a speed generation tool to ENABLE writing the IKE EEPROM by Diagnosis. See digrams below for connection."
http://www.resettools.com/bmw_scanne...&category_id=0
Does that help? WTF is a 'speed generation tool'?
ok, thanks. i buy bmw scanner and i solve the problem. now i want to solve another problem, when i connect the bmw scanner in say that i have 168000 km on IKE and 220000 km on LCM, how can i change LCM km to 168000?
Check this out.
http://forums.bimmerforums.com/forum...98&postcount=8
i solve. thank. you. i activate also in ZKE arming doors closed - optical, disarming optical and DWA. Now it take an error on alarm module because i don't have alarm. If i desactivate DWA, error disappear but don't blink when i open and close the doors. Any solve for this?
No that's normal, just ignore the DWA error or install an alarm systemOriginally Posted by cosmyn
i don't know why i can't clear these errors, with heated washer nozzle, it say open circuit, i buy new ones and .. error is still there,error is with red, and with driver belt tensioner, resistence too hi, error is with yellow.
i make photos but i don't know how to upload here.
Red means the fault is current, which means your car still has a problem and it's coming from another part. So if you replaced the washer nozzle, then the problem must be somewhere else down the line, bad fuse, bad wiring.
I have a few yellow ones that appear, that cannot be cleared as well. Why? probably because the fault keeps coming back just long enough to trip the error, but isn't constant.
Hi gentlaments,
I bought BMW scanner 1.4.0 and installed sucessfuly But I cannot read DDE module every other module is readable. Any sugestions ???
My car BMW E46 320D M47
Got an SES light on the way to school today. Started the car up perfectly fine. Engine ran smooth as butter as it always does, with no idle problems whatsoever. A few minutes in, when the car was heated up to operating temperature, the engine starts to shake ever so slightly. Nothing violent, just a little vibration. Idle starts to drop a bit , then go up, then go back down. No stalling. SES light comes on. I've never gotten an SES before, and the car's been pretty well maintained (so far, in about 11 months/ 5-6K miles, I've done new brake pads, oil change with 5w30, new air filter, new cabin air filter, new spark plugs (BKR6EQUP), new battery, new voltage regulator, VANOS seals, VCG, overhauled cooling system, new belts, pre-cat o2 sensors, and cleaned MAF. Manual transmission fluid replace, differential fluid replace, power steering fluid replace, clean ICV, and replace upper & lower intake boots are coming soon, and I'll be overhauling my suspension shortly. CCV and DISA will be done either next semester or during the summer). Since I had a quiz today (and because I can't manage to miss class), I wasn't able to turn around so I sucked it up & continued to drive to school. About 6-7 minutes later, the SES light goes away and car goes back to idling well with some very slight roughness. Overall, though, it was pretty decent. What the hell? I'm thinking, okay, hopefully it doesn't come back anytime soon (because obviously it would come back, but I don't want to deal with it right now when class is about to start), but I'll still scan the car at home later on in the day and fix whatever is wrong. Well, the way things go, the SES light came back about 10 minutes later. I was able to make it to school, but I'd say barely. The engine wanted to stall, and it was an even bigger nuisance driving uphill and having to apply more gas to get the car to go up or else it'd stall (due to a major loss in power and acceleration). I was at about 1/4 tank of gas. As of right now, I'm just going to take one of my parents' cars to school next week and the week after that - until the problem is resolved. Thank goodness it's Friday.
Scanned the car via PA Soft (v1.4.0.9) and under DME, here's what I had:
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME -> E4/F1 - Oxygen sensor controller, bank 2, deviation too great, deviation rich
E3/F1 - Oxygen sensor controller, bank 1, deviation too great, deviation rich
F2/B5 - Misfire, cylinder 5, misfiring with cylinder cutout (Misfire CARB_A), misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
F1/B5 - Misfire, cylinder 4, misfiring with cylinder cutout (Misfire CARB_A), misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
F3/B4 - Misfire, cylinder 6, misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
EE/B4 - Misfire, cylinder 1, misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
F0/B4 - Misfire, cylinder 3, misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
Shadow-memory:
5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
3F/14 - Control unit self-test 3
34/02 - Solenoid valve, exhaust flap, short circuit to negative or open circuit
Cleared them, and resulted in these:
DME -> Shadow-memory:
Wasn't able to take the car out for a drive after that, though. Anyone have any ideas?
'02 325ci 5MT
I take pictures in the San Francisco Bay Area.
www.eluisphoto.com
Soldering pins #7and #8 solved the problem.I found that pin #7 is the DDE module terminal and #8 other modules.
And one question what is " shadow memory " ??
This where the errors scaned with Bmw Scanner 1.4.0 . Only IKE erorrs where RED I cheked Outside temp sens and it was cut off And the thermal will have to be replaced lol
DDE -> Shadow-memory:
2F/10 - Speed sensor, crankshaft
65/08 - Charge-air-pressure control
52/04 - Electric fan
05/88 - Needle-motion sensor
10/02 - Power supply
13/08 - DDE main relay
72/16 - CAN Bus
12/08 - Terminal 15
2D/06 - Electronic car immobilisation system
26/08 - Air-mass flow sensor
IKE -> CE/C1 - Outside-temperature sensor
11/C4 - Thermal oil-level sensor
LCM -> 16/01 - Turn lights switch / wire, short circuit to ground
17/01 - High beam / headlight flasher switch, short circuit to ground
ZKE -> 3B/21 - Interior light: Short circuit
# SCAN END
This looks to me like the lambda solenoid is not working and thats why the engine is not working properly.
I got mine in the mail yesterday ( after 3 weeks) plugged it in, and was able to recode my preferences without a problem.
It taught me that I'll have to install an audible Siren/Buzzer for a few bucks and all is well.
Thanks for the info.
Hey I have the problem where it said error ike but both 1and2 pins together and 7and8 are also and I still get the error my cars a 97 740il do ineed the circle port to get everything to show up ?
Or how else can I make everything work ?? Plz help
Sent from my iPhone using BF.com
