Hello,
anybody know what is the p/n for I-bus connector for E36?
I have CD43 bussiness cd headunit & I want to connect to OEM BMW CD changer or DICE...
but my car is not cd-changer pre-wired, and I want to buy that wiring to my bmw local dealer.
thanks
BMW Fanatics & OEM Fetish
| E36 M43B18 | E28 M20B20 | E30 M40B18 | E30 M20B25 | E34 M20B20 | E36 M40B18 | E34 M50B26 MST | E36 M50B20 | E34 M50B25 | E36 M52B25 | E46 M43TUB18 |
The iBus is a single wire located in a loom containing other signals such as audio, power and GND.
Are you asking for a CD changer retrofit harness?
For the DICE, you will need E46/E39 CDC harness, the connectors are 3 pin power/GND/iBus and 6 pin audio in Tyco MQS.
E36 DICE MediaBridge BT and iPod support Photo location of the cabrio drain holes. Custom heated seats and lumbar support retrofit. Glovebox charging sockets and cupholders. E36 PDF Schematics UK Aftermarket E36 OBC bulbs Convert rear lights from non check-control to check-control DIY BMW E36 MFSW retrofit pictoral DIY All BMWs UK cheaper source for electrical connectors, Farnell, RS BMW INPA success E46/E39 onwards E36 vert mood lighting DIY BMW E36 puddle light and inner handle illumination DIY. E36 convertible flat bungee tension strap fix DIY BMW E36 PDF manualBMW E36 vert water in motor of tonneau area fix.
I've checked my car wiring, my CD43 headunit working properly. Sadly, my car is not pre-wired for CD Changer option. so, I can't find the 3-pin and 6-pin which I must have to connect to Dice wiring/connector ( I-bus wiring connector, CMIIW).
how can I connect my Dice to my CD43 bussiness cd headunit? did I need another cable? or just need to buy an I-bus cable to connect from my back side of cd43 to dice cable harness ( which need 3-pin & 6-pin connector from I-bus) ?
may I know what is the BMW partnumber for the I-bus cable that I need?
Or any better idea??
thank you for your help.
You want to buy E46 CD changer retrofit harness.
You can buy 5M (trunk mount) or 1.5M (glovebox mount; navigation cars) harness.
Connectors:
http://www.bimmerforums.co.uk/forum/...ectors-t73387/
CDC AUDIO
http://www.realoem.com/bmw/showparts...64&hg=65&fg=10
You need power/GND/iBus (3 pin MQS) plus audio (6 pin MQS).
oke thanks
Hay tommyhw
Did it work or not i am looking to install the dice in my car but i don't have the 3pin & 6pin connector (i have the pi bus the big plug) http://i27.servimg.com/u/f27/16/47/09/24/connec10.jpg
that is what i have please help me, my cd changer is dead
my radio looks like yours from the back with the 10 pin plug
Is there anyone have an answer?
Guys help!
I need USB/AUX
is there a way to cut and make the wiring myself ?
