Page 1 of 23 1234567891011 ... LastLast
Results 1 to 25 of 567
Thread: Build yourself an S50B30 clone for cheap!!! DIY
    Feb 2009
    Arizona
    1998 e36
    3.0L beast
    Cheap S50 would be M50 engine with M54B30 rotating assembly plus S50/S52 camshafts and you got yourself a 3.0L beast. All parts fit just fine, no machining required.
    Here is my video explaining the details:
    or link
    https://www.youtube.com/watch?v=YtP-A6-8eLg
    Mar 2010
    NJ
    325iC
    So is he engine in a chassis and running? This shit looks pretty epic man, thumbs up
    Fresno, Ca, USA
    1993 BMW 325i
    install that baby and dyno that monster.... great work...you should start thinking about building some and sell them...heck, if it makes more power than s50/52, i'll pay 2k for it...
    Feb 2009
    Arizona
    1998 e36
    updated the first post with new video
    Sep 2008
    Reno, NV
    92 E36 325I
    Great build...and ballsy for reusing rings, bearings and even seals . Out of curiousity when you sand the block deck with sandpaper and water, were you not afraid of the immediate occuring of rust? water into cylinder walls?
    Feb 2009
    Arizona
    1998 e36
    questions answered in new posted video
    Dublin, OH
    '95 M3, '17 Civic Si
    FYI, you are correct OP
    M54B30 crank = S52 crank (forged)
    notice I underlined the B30 part...other M54 have a different crank
    good work
    also, at 10.5:1 CR, 87 will work fine with no detonation..........VR6 engines have seen over 300k miles on 87oct at 10.5:1 stock compression ration
    Jul 2011
    Lehigh Valley, pa
    too many
    nice writeup.. im gunna think about it... what kind of power u making now
    Nov 2010
    Cape Coral, FL
    1993 BMW 325i
    So you put m54 pistons in an m50 block?? Which crankshaft did you use? Why didn't you just use the m54 block?
    I didn't even know this could be done. This is sick..
    Rock City, illinois
    98 M3, 03 M3
    Wow nice right up. Maybe on my list of what i want to do with my car.
    Feb 2004
    Plano, TX
    '96 328; '85 4Runner
    Quote Originally Posted by Kody View Post
    The M54 is really hard to fit in an e36.
    Sounds like he bought a core m54 short block that was in good shape, removed the crank, rods & pistons and installed in the m50 block. Then cleaned up and resold the leftover m54 block.
    David M.
    '96 328 Sedan
    Marysville, WA
    1993 BMW 325iS
    Oh my god... If I had the money and skills to do this, I would. Interesting DIY, must keep this in mind.
    Mar 2008
    Chicagoland
    96'328I 99'328I 92'325I
    How much was the block? I can't find one for less than $1000.00
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by cjsdad1 View Post
    http://forums.bimmerforums.com/forum....php?t=1714300
    Oct 2007
    Brighton, MA
    E36 M52B30, M54B30
    any different in terms of performance if using S50b30 86mm inner assembly compare to M54B30 84mm?
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Could this also be done with an M52B25 or M52B28 block?
    Semper Fidelis
    H&R /// Koni /// Powerflex /// AKG
    My 3.46 LSD Build Thread
    Oct 2007
    Brighton, MA
    E36 M52B30, M54B30
    yes
    Quote Originally Posted by orangehatter View Post
    Des Moines, Iowa
    1993 BMW 325is
    Hey, I've been reading about m50 strokers for quite a few months now. Compared with the lack of information about m50 strokers out there, I really respect this project (especially for being on a budget like this). Really, really awesome work man, thanks for sharing it.
    Dublin, OH
    project time, Evan?
    I'm always game
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Quote Originally Posted by das borgen View Post
    project time, Evan?
    I'm always game
    If I had a second vic to drive while the 323is was down, then yes...
    Semper Fidelis
    Mar 2010
    Kentucky
    92 325i
    can this be done to NV motors?
    Rock City, illinois
    98 M3, 03 M3
    Quote Originally Posted by revmoo View Post
    Yeah it can. Just don'e expext as much power as a Vanos motor becuase they could have the S50/52 cams.
    But NV is so much better....lol
    Sep 2010
    Lexington, VA
    1993 BMW 325IS
    I think the M52B28 has a wider bore, but as far as I know the M52B25 is exactly the same bore and stroke so it should work.
    Edit: Just looked it up, M52B28 has same bore but longer stroke than M50B25/ M52B25, so this should work for all of them.
    Okay, new question, does an M52TUB25 head fit on an M50TUB25 block?. I'm wondering if it is possible to do make a 3.0 stroker with dual Vanos, but keep that good old bullet/ turbo proof iron block.
    TX!
    2009 BMW 335i E90
    Wow, glad i caught this, very simple and cheap.
    North Alabama
    1998 BMW 323IS
    Tag
    Ffr
    A hundred years from now it will not matter what my bank account was, the sort of house I lived in, or the kind of car I drove. But the world may be different, because I was important in the life of a child.
    for Zach, Everett, and Lilly
