I know CES sells them, but who is using them. Input and thoughts on the products. I feel that there isn't much info shared on this topic. Sure used stock parts are cheap, but I'm sure it can get annoying replacing them often if you try to go to the track.
― George Orwell
i use both drive shaft and axles. my axles are basically same as a e36 m3 they use same inner and outer joints, just shorter (mcoupe length)
1991 bmw 325I <e30>
First 8 second full body BMW with BMW independent rear suspension in the USA
8.69 @160mph in a 1/4mile on slicks.
drag radial tires record holder9.53@148. Also a world record holder for bmw overall 60-130mph 4.2 seconds.
Bistein sport susp,turner sway bars,3:25lsd,m52 AEM INFINITY stand alone. MORAN 2500cc injectors E85 ,front mount 33x12x4 intercooler, 5lug conversion M3 front,Mcoupe rear Dss axles/driveshaft ATI Proglide.
2003 Ford Expedition
1998 M3
1986 Mercedes Cosworth 190e 2.3 16v 5speed (sold)
― George Orwell
i put them in in the spring driveshaft is steel.it vibrates a little above 80 mph..
1991 bmw 325I <e30>
1998 M3
― George Orwell
I can geel everything vibrate pretty bad at 150.the faster u go the worse itis.
B.
1991 bmw 325I <e30>
1998 M3
The vibration is partially due (from what i've been told) from the tranny being at a 5 degree angle compared to the driveshaft.. it's not a straight line like you would think.
A word of Internet Forum wisdom: Disregard any advice that begins with "I've heard..."
97 M3/4 - S54, TRM Coilovers, UUC SSK/Sways/LTW Flywheel
The driveshafts can be balanced fairly easy by using hose clamps and rotating them.
Put it on a lift, lift the rear up, take the tires off and add hose clamps at the front and rear of the ds. Have one person in the car accelerating and the other person making adjustments. You can add weight in between the hose clamps by using washers.
Yes I'm wondering how the new CES/DSS aluminum DS is working out, and if they have done this kind of testing. Paging John of CES
― George Orwell
Would JB Weld work?
Do some precision spin balancing.
That may work. Its seems like not many complaints on the axles. Boris how long have you been running the axles?
― George Orwell
I think they have plans to install one on a shop car. That was a couple months ago, so maybe its already happened?
| 1997 Estoril M3 - TURBO - || GT35R | 8.5:1 forged internals | ARP stuffs | SS Oring Block w/ elring | Fully balanced & blueprinted 3.3L S52 | Nick G Tuning || 46mm Precision gate| 62# injectors | Dual Walbro's |Goal: 600+ whp pump gas reliable 10 second car.
-2007 335i Sport Package
Once again paging John of CES to share some of the vast amounts of knowledge here.
― George Orwell
I have a Chromoly DS and it vibrates above 40mph. I tried clocking the shaft like they say to do, and it helped a little. I actually took it off and I am letting a friend use it, because it didn't make sense to me to use it for daily driving......
I would like to see a video on the hose clamp technique...sounds interesting!
TEC-3R, T4 GT40, WISECO, EAGLE, SUPERTECH, O-RING'D "FRANKENSTEIN" STROKER.
Can you lower the transmission a bit to reduce the angle placed on the driveshaft?
I cant speak for the axles. But their driveshafts are garbage. when I brought mine; they claimed that it was perfecty balanced. Mounted mine up; over 80+ mph the shit will vibrate. Contacted DDS about the issue; then they claime that its an installation issue. Go figure. Do yourself a favor stay away. Long story short its messed up my rear diff and tranny seals.
Waste of money.
I spoke with John a few days ago.
1) The old DSS driveshaft vibrated due to the construction of the flexable joint. No matter how balanced the driveshaft was, the design of the joint would inevitably lead to vibration. I dont think I have heard of any of these things functioning without vibration
2) The new DSS driveshaft that CES has been working with DSS on has been constructed. Last I heard it made its way onto the shop widebody car and was tested up to 80 mph with zero vibration. He wasnt able to test it any furthur.
I believe they are making two versions: Steel and Carbon fiber....not aluminum.
Oh and I forgot to mention that the shaft vibrated like crazy when I first installed it (i put the slip joint twards the front of the car) then I turned it aroumd and put the slip joint twards the rear of the car wich helped the vibration alot.
B.
1991 bmw 325I <e30>
1998 M3
So what you're saying is that it seems they have have a new and improved e36 variant, but the e30 / coupe body type DS is still the same?
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
1991 bmw 325I <e30>
1998 M3
Sorry to chime in so late.. Yes, we have a new DSS driveshaft that we worked with Frank at DSS to fix the vibration issues that were existing in the old Driveshafts due to the slip joint. I have another post that details all this info on what was done etc... etc... We designed the driveshaft for our 750 diff conversion upgrades, and will also offer ones that will work with the stock e36 diffs as well. It utilizes a cv joint in the rear now, and is still a one piece in design. I have not had a chance to extensively test the driveshaft yet, but small blasts up and down the road by the shop have shown no vibration issues that were existent at even those speeds in the old design... FYI: The info on our website was taken directly from DSS which is outdated about it being aluminum... Our new website will be online hopefully very soon... so apologies the old site has not been updated in a while... The unit we have now I believe is either chromoly or steel, and a carbon fiber version is also in the works as long as fitment is not an issue since the clearances very tight in the tunnel and the carbon shaft is a 1/4 in wider on each side... I will post more updates when I have time.. Just so busy guys so apologies again for not being on top of the forums right now...
I make one piece drive shafts. I have sent them all over contry. Not one person has EVER given me ANY imput so I've taken it as a win! However I used one in my 99 m3 while being NA and did a pull to 145 and it was smoooooothe and I don't make axels so I run th dss 1000hp in the same car with 0 issues! I also didn't make my drive shafts with adapters its true oe install with slip joint in rear and only 1 way to install...
BAM!!!!!! We may have a winner.
