Motor Part outs
PM with any inquiries.
PayPal preferred.
Buyer incurs all transaction relatedfees.
Shipping insurance is optional.
Top End Engine Components
Cylinder Heads
S52 Head - Sold.
S52 Head - in use... pm if serious.
S50 Head - Sold.
m50tu Head - Sold.
m50tu head - sold.
m50nv Head - pm.
OBDII Valve Cover - $100
OBDI Valve Cover - $115
OBDII "M Power" Engine Cover - $125
OBDI "M Power" Engine Cover - $125
OBDI "BMW" Engine Cover - $25-45
Camshafts
S52 Cams - Sold.
S52 Cams - Sold.
S50 Cams - Sold.
M50tu Camshafts - $25
S52 Trays & Lifters - sold.
m52 Trays & Lifters - $40
Vanos & Timing Related
Vanos - $125
Vanos - sold
Vanos - sold
Vanos Solenoid - sold
Camshaft Timing Sprocket -
Exhaust Cam Sprocket -
Intake Cam Sprocket -
Vanos Chain - $20
Timing Chain - $25
Chain Tensioner - $35
Bottom End Engine Components
Complete S52 Short Block - $1500 obo, pm.
Iron Blocks
S52 Block - $400
S50 Block - pending.
m50tu Block - $100
Crankshafts
S52 Crank - sold
S52 Crankshaft - $400
S50 Crank - sold
m50tu Crank -
m50nv crank - $50
Pistons
S52 Pistons - Sold.
S52 Pistons - pm.
S50 Pistons - Sold.
m50tu Pistons - $35
Oil Filter Housings
S52 - Sold.
S52 - pm
S50 - Sold.
M50 - pm
M50 - Sold.
S52 Oil Pump - $150
S50 Oil Pump - $125
m50 New Style Oil Pump - pm.
m50 Old Style Oil Pump - $45
S52 Oil Pan - sold.
S52 Oil Pan - sold.
S52 Oil Pan - sold.
S52 Oil Pan - sold.
S50 Oil Pan - sold.
M50 Oil Pan - sold.
M50 Oil Pan - sold.
Engine Accessories
A/C Compressors
PM for availability/pricing.
Alternators
pm for details/availability
Valeo - Sold.
Valeo -
Bosch - Sold.
Bosch - Sold.
Bosch -
Power Steering Pumps
LUK - $55
ZF - pm.
Water Pumps
Used Stewart (5K mi) - $150
OEM w. Metal Impellar - sold
OEM w. Composite - sold
Pulleys
Water Pump - $15
Crankshaft A/C Pulley - $20
Idle Control Valves
Plenty take your pick! 25 ea.
Electrical
Intake & Exhaust
Intake Manifold
M50 - 100
S52
Exhaust Manifolds
OBDII (broken studs, new to pop them out and run bolt/nut like aftermarket or get new studs. I can slam the old ones out if needed.) - $35 pair
Fuel & Ignition System
OBDII Fuel Rail - sold
OBDI Fuel Rail - sold
21lb Injs - 45
17lb Injs - 35
Spark Plugs NGK
Spark Plugs Bosch M3
Spark Plugs Bosch 325
Coils - Sold out at the moment.
How much for the entire s50. Would you send it built or parted out?
How much miles on it.
I want to buy S5x , and swap into my 90 325i
can you give a price for that ?
PM sent.
how much for the m50 head(vano's), and is it straight?
― George Orwell
Sent you a PM. Wouldn't go through. Said your box was full.
I'm interested in the s52. Email me at loupis2@yahoo.com
Thanks in advance,
Greg
hi im steve i live in hamden ct im interested in a couple parts s52 complete motor can u give me a call 2038047155
I need a few things not listed.
1. Power Steering Hose Steering Rack to Power Steering Pump
2. Power Steering Hose Steering Rack to Fluid Container with Cooling Coil (trumbone?)
3. Coolant Expansion Tank with sender
Pm me prices shipped to 17073, PA
Thanks for your time!
~FernandoOriginally Posted by 1995M3LTW
Need one (1) S52 piston w/rings, the "small" type... got it?
Instructor - NASA MidAtlantic, Chump - Racer
Team Constitutionalists Racing LIFE-LIBERTY-BEER
DELETE SOME MESSAGES> Dang maybe. can you get me a quote at least? Were are you located? What would you think a good trade would intale. I have alot of the engine still, and etc. like no other. < PLEASE
injector prices are crazy high..17 and 21lb go for like 50 bucks..
Pics of the s52 pistons and rods?
Any sort of S52 short block material around, preferably still assembled.
Cheers
Can't put that in s52 block with s52 crankOriginally Posted by BimmerDude3
PLEASE tell me you still have the s50 head, money shifted last night, and now mine is done, i am located in Westerly, RI.
Will buy head asap if so...could you give me a call/text at 401-626-6909
How much for entire M50 motor need it asap
looking for m50 motor and zf driveshaft.
How much are you looking for each?
Hi, interesed in S52 cams. Wil you able to ship internationaly?
I'm form Kazakhstan. Will cover all shippingcosts via FedEx or DHL.
Im looking for m53b28 obd2 to put in my 99 323is. Do you have it? 203-427-7916
Any S52 short block stuff appear yet? I remember you said you'd get back with me further down the line, just checking in again.
Do you have the M Power valve cover available from the S52, if so would you ship internationally? Thanks.
i got $500 plus shipping on that S52 head (CAST# on mine=1738400)...PLEASE!
hi,
do you still have the complete s50 engine? if so how much shipped to az 85087 thanks eric
ericjohansson@live.com
