I bought the car with the top not working. I want to use the push button to raise and lower the top. So before I ask another question I need to get the wires for the micro switch connect. The top was replaced and looks like the wires to the micro switch were cut. I need to know which wires connect to the wire with the black connector and to the yellow connector? I see the two small cut wires sticking out. I would also need to know where I can buy the connectors.
A look below and you'll see what wires were cut.
The connectors can be bought from BMW, and it looks like the wires are all different colours, brown is always GND.
E36 DICE MediaBridge BT and iPod support Photo location of the cabrio drain holes. Custom heated seats and lumbar support retrofit. Glovebox charging sockets and cupholders. E36 PDF Schematics UK Aftermarket E36 OBC bulbs Convert rear lights from non check-control to check-control DIY BMW E36 MFSW retrofit pictoral DIY All BMWs UK cheaper source for electrical connectors, Farnell, RS BMW INPA success E46/E39 onwards E36 vert mood lighting DIY BMW E36 puddle light and inner handle illumination DIY. E36 convertible flat bungee tension strap fix DIY BMW E36 PDF manualBMW E36 vert water in motor of tonneau area fix.
the yellow conector is for the lid switch. Goes on the brown wires. Without this the lid and trunk can be opened at the same type. Some one baypassed the safety for not opening trunk + top lid at the same type.
If the black connector has 4 wires, its the wire for S1 and S2 switches
You can either buy the connector or just solder them to see if it works. Otherwise there is no point spending money on connectors (tho they are very cheap)
Any way to see a picture of this?
