Hi there, I'm wounder is any of you guys retrofit the PRE facelift Hella Xenon with the Bi Xenon projector?
Thanks,
E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
PANAMA, CIUDAD DE PANAMA
I know at least one person who has, mostly cause I did it for him, but he will have to post up himself the details instead of slacking and failing to post up the pictures and stuff.
>'97 528i, 200000 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'65 & '74 MG Midgets BFC OT Lego Club #48 Manual conversion in process!!!
thanks bro, one question, what Bi Xenon are those?
The work looks good, I'm wondering how the oem glass lense affects the light output of the new projectors though.
BMWCCA #389756
e39 Touring SOLD.
I likes!
I need to do this to my 2001+ headlights, badly...!
thanks bro, locks very good....
I asking this because in my old facelift OEM Hellas I have the Bi xenon, but now I'm put the pre facelift and I want the bi xenon...
thanks, I will see if I can do this with the Audi RS6 Hella Bi Xenon, if not, I would buy the FX-R in unmitza
Is the fx-r unit generally easy to mount in there or did it need a bit of drilling or other work? What if anything needs to be done to wire the unit so the low/high-beam cutoff toggles? Is it still possible to use the original high-beams along with this setup? [Obviously I am bi-xenon illiterate....]
Yes, need a little drill work
You need to connect the Bi Xenon wires in to the high beam wires
Yes, you can always use your originals high beam, because you only need to split the OEM high beams cables to connect the Bi Xenon cables, so when you turn on the high beam, you will turning on the high beam and the Bi Xenon at the same time....
FX-R projectors for the win.
Good stuff.
Is the fx-r the best projector choice/fit for this application? Those pics (thanks!) seem to show everything required as far as custom-fitting goes....
I would say it is, def not the best projector out there but for the price can't complain. FWIW this is far from a DIY thread (for which I apologize), but I figured I'd at least show whats hidding inside the prefacelift xenons - front cover, back cover and metal frame that holds the low/high beam. Once you remove the low beams projector, just drill 4 holes and use some long screws and metal spacers (home depot/lowes stuff) so the new projector sits further out (remember fx-r are shorter than OEM hellas)
would any other projectors fit with less modification and do you retain the vertical adjustability in case you lower the car?
