Circuit Motorsports is proud to provide BimmerForums Members with BC Racing Coilovers!
BR Series
ER Series
BC Racing BR series coilovers are perfect for street driving, drag racing, and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and the patented concave lower locking ring keeps it locked in. They are dual-height adjustable, which means you don't sacrifice shock travel when you lower the car, since spring preload is completely separate from ride height. We can provide them with the OTS spring rates, or you can choose a softer or stiffer setup, it's up to you. We make it extremely easy for you to customize your suspension for your car.
We also provide the option of pillowball mounts front and rear, or rubber mounts front and rear, your choice. Rubber mounts provide an extra barrier between your suspension and chassis, reducing NVH. Pillowball mounts will be a little noiser, but they provide better feedback through your chassis and a stiffer mount for those of you looking to track your cars.
Here are the specs:
BR Series:
-Mono-tube shock design
-30 levels of damping force adjustment
-Separate Full length height adjustable
-Pillowball or Rubber upper mounts
-One year warranty
-Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
-Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
-Patented concave lower locking ring, to prevent unseating
-Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
-T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
-Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
-High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
-2 step coating process utilizing nickel and chromium plating to prevent corrosion
-Newly developed lubricant oil in all shock cartridges minimizes aeration and cavitation.
-An additional bearing beneath each pillowball mount provides a smooth action and prolongs the life of the pillowball itself.
-Each BC damper is individually dyno tested before leaving the factory, making sure each damper is matched to within 5%, ensuring an equal balance in handling. OEM standards are 13% in comparison.
We have BR Series kits that will fit all these BMW platforms:
-E30 3 Series (4 & 6 Cylinder)
-E36 3 Series & M3 (ER Series Also Available)
-E46 3 Series & M3 (ER Series Also Available)
-E90 3 Series
-E92 3 Series & M3
-E93 3 Series Convertible
-E34 5 Series & M5
-E39 5 Series & M5
-E60 5 Series & M5
-F10 5 Series
-Z3
-Z4
-120i/i30i
Check here for the availability of camber plates and top plates : http://bcracing-na.com/downloads/BC_...ATION_LIST.pdf
We believe in "Affordable Performance", so we are giving these to you guys at the awesome Intro price + Bimmer members get a free inclusion, PM us for details! These are a great deal at this special price and you can't get this kind of quality coilover with these features anywhere else, especially under $1k.
BC Racing Coilovers Used exclusively by Chelsea Denofa in his E36 BMW Drift Car. He has many podium finishes and multiple wins including the "Extreme Drift Circuit Chamionpship"!
Want to adjust your damping on the rear coilovers without tearing apart your trunk? Get Extenders! These little cables attach to the adjuster knob and can be punched through the trunk liner to give you damping access for super easy adjustment!
"Keep Attacking..."
Site - www.circuitmotorsports.net
Email - sales@circuitmotorsports.net
Phone - 407-325-2176
Address - 2427 Forsyth Road Unit P Orlando, FL 32807
nice! what's the spes for those ER series coilovers you have shown above also? pm me details for an E39 540i with the M suspension...
thanks,
Mark
IT'S A DRIVER'S MACHINE THE ULTIMATE!!19" Staggered SSR GT03's on H&R Sports
pm me a price for e46 sedan. thanks
Tristan (Circuit Motorsports) is a great guy to deal with and the BC products are excellent also, I run them on my M5 and other customers cars and we have been very pleased with them. Great product!
Could I get a quote for these shipped to 60564 for a 2008 328i sedan?
A few Pics of customers cars with BCR's installed:
"Keep Attacking..."
Please pm me a price for both kits for a e36 m3.
Sent from my PC36100 using Tapatalk
same here, pm me price for both kits with 500/650 springs
AZ 51 STEP GRAD.
All PM's sent guys
"Keep Attacking..."
Could you pm me details and possibly pics for the e30 set? Along with a price? Thanks.
Also are they stock tube lenghts or shortened
Jacques Cousteau could never get this low
Also interested in prices for 95 M3. Both sets. Thanks.
Ordered a set today for my 98 M. Should be getting it in a few days
PM's sent guys
"Keep Attacking..."
Please PM prices for both sets for a non m e36 please!
PM's sent guys
"Keep Attacking..."
pm me a price for e36 323is 1999 for both sets thanks
PM's sent
"Keep Attacking..."
PM sent regarding a set for my M5.
1987 E30 cabrio | Bumper swap | H&R Sport | Koni Yellow | Eibach Sways | BavAuto strut bar | Cardinal seats | MTech2 wheel | Armrest | Smoked Hella Smileys | 5k HID | Stromung | RS003
2000 E39 M5 | Stoptech brakes | Refinished OEM wheels w/10mm spacers | Powerchips Gold 91 | Timmay Tips/muffler delete | Functional brake ducts | DICE MB1500 Slimm diffuser | Cubic black trim w/alcantara boots
PM's replied Gents
"Keep Attacking..."
received mine yesterday and will be going on this weekend
https://www.facebook.com/#!/pages/Mo...51876744885651
They do sweet burn outs too...
Technica Motorsports Nexen Tire BC Racing Turbo E36 M3 Drift Purple Burnout 9 by ATLFocus Photography, on Flickr
How much for an E39 530i?
Could I get a price for e90, 2007 328i please with Pillowball mounts and extender as well. Shipped to 97006
