My OEM radio in the car died so I got the alpine cde-121
I followed the directions and connected it but it does not work the power goes on but there is no sound, I have 1 wire (black/white) which according to the BMW diagram it is the second 12v+ wire but I have no idea where it goes, I can connect this to any wire and then the sounds works but the cars acts funny I feel like I am missing something big can anybody help, I did not use a harness I did the old fashion (spilt and clip) the wires together
Wow.Just wow.
Stop connecting wires together when you don't know what they do. Black/White is the GAL speed wire.
Have you looked to see if you have an amplifier and if you need to turn that amplifier on?
E36 DICE MediaBridge BT and iPod support Photo location of the cabrio drain holes. Custom heated seats and lumbar support retrofit. Glovebox charging sockets and cupholders. E36 PDF Schematics UK Aftermarket E36 OBC bulbs Convert rear lights from non check-control to check-control DIY BMW E36 MFSW retrofit pictoral DIY All BMWs UK cheaper source for electrical connectors, Farnell, RS BMW INPA success E46/E39 onwards E36 vert mood lighting DIY BMW E36 puddle light and inner handle illumination DIY. E36 convertible flat bungee tension strap fix DIY BMW E36 PDF manualBMW E36 vert water in motor of tonneau area fix.
No amp, which I know off? I have a (black/white) wire free, a (white) wire free and (grey/red) wire free and (brown/ white), thanks for responding this has been so frustration, we rebuilt the engine with no problem, but it is a problem Best Buy would not touch the car b/c of the age
The schematic is in my sig. Check the radio page. It tells you all the colours and what they do. You need to look in the car to see if you have a factory amp.
It's in the trunk somewhere, unless you have a cabrio, in which case it is behind the rear seat foam on the passenger side.
The colour codes are
RT Red
SW Black
GN Green
BR Brown
GE Yellow
WS White
VI Violet
GR Grey
BL Blue
Found the amp and the right wire all works great, thank you so much for your help
So the radio works got all the wires correct but the Cd player does not work nor does the aux port for the ipod...any ideas
Also my abs. Unit dies was told $1200 to replace where is this unit located so I can get a part number and get a replacement thanks...
