BIG UPDATE!
picked up a engine hoist this morning for $40, managed to fit the whole thing in the trunk my of mustang.
got it home and assembled, started yanking the motor
fought with it for about 2 hours, but finally -
nice empty engine bay
Motor mounts from thailand
driftmotion underdrive pulley kit
ls400 fan clutch
deleted the inline regulator since the 1jz comes with a regulator on the rail
7mgte fan with ls400 fan clutch
motor came in today.
bolted on the new mounts
me and a friend deleted the ac, installed a 2jz waterpump, did the timing belt and the pulleys.
motor is now in the car
wiring is about 60% done, it turned over yesterday and started routing fuel lines.
bye bye bmw harness.
cool swap! cant wait to see it completed! Also how much in total do you think this swap cost and on a difficulty level of 1-10 how hard is it?
I probably have about 5k into the swap so far not counting a lot of the little things ive sold. Difficulty level id give it a 4. I have a friend whos done this swap before do all the wiring.
That trans mount usually doesn't work at all, right?
Nice work indeed. Questions?
1. Why use the Ls400 7m fan combo?
2. Any fitment problems with any of the mounts?
3. Do you have more wiring pics or info? That seems to be the main part so far for me.
4. Are you keeping the twins?
mine worked pretty well. it seems they refined it because the guy who is helping me wasnt expecting it to fit either but it did. we were only unable to get 1 bolt into the crossmember.
answers to your questions:
1. i was told i had to use the ls400 fan clutch to fit the fan - well it doesnt fit so we have to figure something else out.
2. mounts fit great, motor went in easy as pie. you have to remove the oil filter housing to get 1 bolt for the driver side mount. we did use 2 spacers on the driver side to leve out the motor.
3. a friend of mine is doing the wiring, he did the wiring on the red m3 with ccws that was on here a while back.
4. keeping the twins for now. gonna throw in some usdm 2jz 440cc injectors and crank the boost up.
440's 2j injectors sound like jdm's. Don't forgot about injector independance.
built 1.5jz, big fuel+76mm-billet. 9 second dream https://www.youtube.com/watch?v=RtVqp3O1RDQ
So the USDM 2jz's had 550's that were low impedance that must use the resistors.
Be careful with the boost. Army was telling me about his stock twins and small mods that didn't last long. I'm still on the fence whether to keep stock twins or go with single.
BTW, could you move to a single and still use stock ecu with 440's
yes, usdm 550's are low-z. jdm 1j and 2j are high-z wiring. So to use usdm's 550's in our jdm wiring, you'll need the resister box. Driftmotion.com sells it.
440's are jdm drop in's. if thats what op' refers too.
Thanks Army.
OP what needed to be done for the fuel lines? Do they matchup or mods needed?
Im gonna hate to see the Saab go, however I can't wait to start this swap.
fuel lines are extremely easy. delete the inline reg and plumb with rubber line. then run the factory rubber return to the hard returrn off the 1jz regulator.
feed was a little trickier. the 1jz uses a plastic hardline with a rubber sheath on a banjo bolt for the feed. i pulled the rubber sheathing off, cut down the plastic hardline to about 2 inches, then hose clamped the factory feed line over it.
Looking good, I hate that trans mount though. Such a pain when I had to pull the trans to get everything to line back up properly. I'm talking to a few of my guys up here about getting a revised trans mount that'll put everything at the proper hight and line up with all the factory holes. Whatre you doing about a driveshaft? Don't use peters springs in baltimore...
i am picking up a 1993 325is within the next week or two that already had a 1jz into it... so my swap should be easier! i am subscribing to this thread.
Kiely wants me to try out some shop that did Arman's ls1 240sx so i am going to give them a try.
lower radiator mount done.
final wiring.
was able to snag the correct fan clutch last night thanks to clay@bimmerzone. mucho gracias. Hope to have the front end buttoned up this week.
Whats wrong with the trans mounts? im about to drop mine in soon after i finish the rebuild, would like to know what to expect before i get there
MODS
1JZ, BC 264 cams, BC TI Springs and Retainers, Ferra Keepers, Arp Head Studs, Arp Main studs, Arp rod bolts, Custom Emerald Performance Dual Plenum intake, 70 mm TB, SC6169 T3 Turbo, full 3 inch SS exhaust, Ar5 Transmission, 60lb injectors, Walbro 400 fuel pump, GTR intercooler. Porsche Turbo Calipers, Gutted Tein SS coilovers with Koni Race shock inserts , Tein Pillowball Camber Plates, UUC Swaybarbarian bars....needs more mods and a tune!!!!
Cool swap, i totally approve of these kind of swaps in these US M3s.. since their motors were never TRUE S-serie....
Viktor Agnar Falk Gušmundsson
Signature idea, courtesy of 5mall5nails
THATS SACRILEGE, YOU CANT PUT A TOYOTA INJUN IN A BMW!!!
Looking good brother, made some good progress on the beast, looking forward to updates!!
Only concern i have is the driftmotion bottom pulley, that replaces the harmonic balancer.... im not confident about these things, the harmonic balancers are there for a reason. Id have a good read about them before turning key mate!
Have fun!!
-Dan
The belt will not fit because its to suit that underdrive crank pulley, so if you use a standard balancer or standard sized balancer, the standard belt will work.
I believe there is no difference in diameter with the driftmotion alt/wpump/psteer pulleys and standard.
Belts are like $30, i wouldnt make the decision based on that. In saying that, a lot of the aftermarket harmonic balancers are underdriven too, so that belt may be suitable if you went that way.
I deleted the AC, stock belt was too long. Didnt feel like shopping for the correct length. But i must say, the motor does not have a SINGLE bit of vibration to it under rpms.
whos doing your wiring harness ? or did you buy allready done one?
i got these parts for sale
front corner light for a 4 door E36 $20plus shipping
headlight eyebrows $20 plud shpping
M3 OEM radiator $100 plus shipping
M52 cams with trays high miles $150 shipped
M3 front calipers $150 plus shipping
18x8 offsed 35, front 18x10 offset 40 rear bsa motorsports wheels $400 plus shipping
obd2 valve covers $50 plus shipping
intake manifolds $50 plus shipping
estoril blue doors of a 96 M3 2door $200 plus shipping each
rear glass $50 plus shipping
rear trunk lid $150 plus shipping
new 1/4 is 800 ft away ))
Doh! You might jump in and get it done! If you sold your harness with your motor I have a few OBDI harnesses with the DLC and X20 still in place.
