SAE Corrected
90 Degrees F
Pump + Meth
What is this on?
Dynojet, it says it @ top of the sheet
damn. love it.
Nice numbers! What type of fuel system are you using, stock fuel lines with intank walbro?
Me too.
Stock fuel lines to the fuel regulator, then to -6 lines to the fuel rail, then back to stock lines. In tank walbro with a boost-a-pump.
I think it has more in her. Nick G doesnt want to push it without being able to view knock activity. He wasnt able to do that on his dyno due to wheel spin.
97 M3 - 8.94@164 - 8 sec street machine, all BMW driveline, factory ECU
02 M3 - 9.74@145 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
16 M3 - 9.3@151 - Built motor/twins
15 M3 - 9.2@162 - Built motor/single turbo/Ecutek
BMW SOB's turbo E30 - 8.72@158.39
follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
Nice!!!
Don
Now that's a nice graph
Nick Glantzis
2005 330i ZHP auto with Technique Tuning turbo kit (currently For Sale)
Thanks Don.
Yes it . Thats what good tuning gets ya!
Thanks Eric. I still havent forgot about the bracket. Once I pick the car up in a week or so, Ill ship it back to you. Thanks again for the help
I believe John at CES attempted another run when the temps died down to around 60 ish. The car was well on its way to making more power, but we had some issues that cut the run short. Hopefully we can get a run or two in with some cooler temps.
damn thats fantastic
Very nice!!!
This is my signature....
Wow, I think that is my fav power curve yet. Wow. Please, more specs.
What's the A/R on the turbo. Precision turbo I assume? Journal or BB? Boost pressure on this run. 93 octane? Water injection?
I will be tuning/dynoing a Franken Radowski built 3.0 motor on a pt6776 journal bearing. Just breaking in the motor right now, and it just wants to go like crazy. We will see what we can do with the out of the dark ages wintec4 software for the tec3r. So far, its infinitely better than the old 3.x software was.
Wow, this give me hope for some good numbers.
1999 M coupe, Black/Kyalami Orange, Sunroof Delete; GT4088R turbo, 610 WHP @ 22PSI Pump Gas; 2.79 Gearing; TCK D/A's; Forgelines 19x9 et38 w/265 30's; 19x11.5 et19 w/305 30's. Brembo GT Brakes; Race Logic Traction Control.
1971 Datsun 510: High Compression VG34e, CAI,Fuji Blue, GC C/O's; system, Penultimate Rear Crossmember R160 lsd 3.70, cv axels; CCW LM16's 16 x 7.5/8.5 w/215 40 and 245 35 T1R's.
Those were some great #'s LK! Very pleased that we are seeing these numbers with a stock ecu and Nick G. 80# inj. tuning. We are going to adjust the hfs meth kit to come in a little less between 4-5K rpms so that we can lean out the a/f's there a bit since they dip into the low 10's, and then have it come in a bit stronger towards the higher rpms to keep a/f's under 12.0 up top.
The car boosted a peak of 23.5 psi, with boost avg at 22-23psi throughout. 93 octane pump gas and 50/50 water/meth. Meth comes in according to IDC and I believe Luke is running the largest jet that comes with the kit.
It can probably be pushed a little more on pump, but Nick would have to make sure the car doesn't see knock with more boost. Had the pleasure of doing some test runs on the street, and all I can say is the car pulls like a freight train right to redline... Boost response is excellent on the street. Crazy fast car!
I've also attached a dyno graph of our stg3 60# inj. AA tuned turbo car with the old t3 aa manifold setup running 21 psi with a gt35r turbo for some comparison 100octane + meth... and another comparison graph with SM3's 4094r kit boosting 17psi with a 60# Nick G. stock ecu tune, 93 oct + meth.
Best Regards,
The CES Motorsport Team
Im like 300 RPMs slower than a 35....not to worried about that.
50/50 by volume
I wouldn't expect it on the 35R. But I would guess that the 35R had a smaller AR and might have been on a 3.2 also.
Yeah, nothing to worry about, I was just curious. Looks like it'll be a very fun car. I'm running the same turbo with a .68 AR (for now).
Makes sense. I wouldn't be surprised if the 35R had a smaller AR also.
Any comments on Luke's/SM3's vs George's 4088 set up? I imagine the tunes are similar.
Attention TURBO LOVERS, Great book -----> How to turbocharge and Tune your Engine
Favorite Automotive Tuning Articles on the Internet: Engine Tuning Articles
My Car: Custom Build Lotus Super 7
Amazing work by all parties involved.... that thing is a beast!
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
