I will be replacing the thermostat tomorrow morning on my 1990 535i, but I couldn't figure out how to align the thermostat. I see the arrow on the thermostat itself, but can't seem to figure out where the arrow on the thermostat housing. I only thing I see is the letter "A" on the thermostat housing. Thanks in advance guys.
what?
Align the thermostat? It only fits one way.
Cooling system-thermostat housing - BMW parts catalog
There is an alignment mark on the thermostat. The parts guy at BMW told me to make sure it aligns correctly to the thermostat housing. He showed me the arrow on the thermostat and told me it must be aligned.
That's true. If there's an arrow, it points straight up (straight up, not straight towards the top of the engine). If there's a mark, it should be at the very top. This is to assist bleeding. It's not going to affect thermostat operation any other time, and it's not really important on an M30 like it is on an M5x engine.
And on that subject, you can bleed both sides of the thermostat of an M30 without ever starting it. Procedure is to remove a bolt from the therm housing (an unused sensor position) fill the expansion tank until coolant comes out the bolt hole. Put the bolt back in, and fill until coolant comes out the bleed screw (open the bleed screw before you start filling). After that, you start the engine and warm it up, bleeding every so often.
9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
2001 740i OrientBlau M Sport, purchased March 2023
1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
4/99 323is/5. Titansilber, 211k miles. Straight body project.
past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
SÜNDE REISEN
