Been driving stick for years now but have only been driving my 2008 335i for about 6k miles. Total the car has 36k.
At first I just figured it was me getting used to the clutch, but by now I should have it.
Any ideas why shifting from 2nd to 3rd is so difficult?
How fast do you let your foot off the clutch? The MT has a very annoying CDV (Clutch Delay Valve) which releases the Clutch and a constant rate no matter how fast you dump it. This is to prevent the clutch from wear and tear but for a seasoned shifter, can prove annoying. Try rolling your foot off the clutch a little slower than you usually do and see if that helps.
I thought shifting from 1 to 2 is the hard part , now i have got used to the CDV and everything is smooth.
I agree to the above post, you need to take off the clutch a bit slower.
13 Audi S4 / 6spd / Glacier White/Black/ supercharged
10 Acura TL/AT/ Palladium metallic/spoiler
sold --09 335 coupe/6 spd/monaco blue /sports/navi/bmw assist/ipod connector/ BMW SSK/ UUC Corsa exhaust/ BMW Performance powerkit V1
I'll never get used to it. Every morning, like clockwork, my daily commute starts with me pulling off my court with my car having a mad seizure. Rest of the day is smooth sailing, but man that first shiftOriginally Posted by boss2k
I would say that I shift pretty fast. It is just hard to believe that I feel like I have to "force" it into gear.
I know the release valve is pretty inexpensive but what is the typical install costs?
Sometimes I find shifting into first is hard from neutral on my 2006 325i 6MT Sport such as when stopped at a light. Does anyone else have that?
I end up shifting into second from neutral and then into first.
Rick
Same problem. But I keep trying to get it into 1st. I'll have to try going into 2nd and then 1st.
Hey Guys,
Remember also that the clutch has to be depressed only about 3/4 to the floor to shift smoothly. I had been experiencing harder shifts after I bought the car because I was unaware of this feature. I would recommend this if you aren't already doing so and slowing your release down a bit as suggested by Max....
