BMW tools for loan: RTAB, FCAB, Vanos/timing, Peake scan/reset, SRS
I’ve accumulated several BMW tools over the years from owning several BMWs and I’m offering them to loan. They’re a rip off to buy for a one time use, so here’s an opportunity to get the job done with the right tool.
-Vanos/timing tools
-RTAB (rear trailing arm bushing) tool
-FCAB (Front control arm bushing) tool
-Peake SRS tool
-Peake scan tool
-e46 M3 valve adjustment kit (shims, pick up tool, micrometer, 32m wrench)
The details of each tool are listed below
-RTAB tool. Loan includes both the removal tool as well as the installer tool. $25 outgoing shipping/handling. You are responsible for return shipping. $100 fully refundable deposit required in case of damage.
-FCAB tool. Loan includes both the removal tool as well as the installer tool. $25 outgoing shipping/handling for 7 day loan once tool arrives. You are responsible for return shipping. $120 fully refundable deposit required in case of damage.
Works on: e30, e36, e46 as well as 60mm on earlier 323 & 328 models.
-FCAB Lollypop Tool. This tool allows you to remove and reinstall the FCAB into the lollypop/bushing carrier without the use of a 6 ton shop press. Loan includes both the removal tool as well as the installer tool. $25 outgoing shipping/handling for 7 day loan once tool arrives. You are responsible for return shipping. $100 fully refundable deposit required in case of damage. Works on:
E30, E36, E46 (60mm only on 323/328/M3, and Z3 lollypops.
-Vanos/timing tools: See picture for specific engine applications. Loan includes camshaft locking block, sprocket turner, crankshaft lock pin, camshaft tensioner lock pin. $25 outgoing shipping/handling for 7 day loan once tool arrives. You are responsible for return shipping. $120 refundable deposit required in case of damage.
-The other Vanos tools (32 mm open wrench, fan clutch holder, & 17/18 MM modified sockets are available for an extra $10 shippping/handling (requires the next size larger flat rate shipping box). No additional deposit required if loaned with other tools.
For the following motors (will not fit an s54):
-M42
-M44
-M50
-M52
-M54
-M56
-S50
-S52
-E46 Rear Differential Bushing Tool: $25 outgoing shipping/handling for 7 day loan once tool arrives + $100 fully refundable deposit. For non-M vehicles only. This tool allows removal and installation of the bushing. You are responsible for return shipping.
-Peake R5/FX-3 (scanner & reset tool): $25 outgoing shipping/handling for 7 day loan once tool arrives + $130 fully refundable deposit. You are responsible for return shipping.
http://www.peakeresearch.com/fcx3.htm
-Peake R5/SRS-2 (airbag tool): $25 outgoing shipping/handling for 7 day loan once tool arrives + $130 fully refundable deposit. For 2001 and older vehicles only. Outgoing shipping is $5. You are responsible for return shipping.
http://www.peakeresearch.com/srstool.htm
-AB03 Adapter: Comes with the loan with one of the above loans. Allows use of above tools with older style under hood connection.
-e46 M3 adjustment kit: $50 outgoing insured shipping/handling for 7 day loan once tool arrives + $550 fully refundable deposit. You must replace shims with OEM units from the dealer prior to sending it back. You are responsible for return shipping (around $15 with insurance). If you only want the shim kit and pick up tool, subtract $10 from the shipping/handling cost & subtract $150 from the deposit.
2011 BMW M3 6MT
2011 Ford F250 King Ranch
1969 Toyota FJ40
2011 BMW 128i (wife's car)
Vanos tools & OBD1 adapter currently out for rent
2011 BMW M3 6MT
1969 Toyota FJ40
Evening bump
2011 BMW M3 6MT
1969 Toyota FJ40
RTAB/vanos are out, everything else is still available. PM me to put your name on the list.
2011 BMW M3 6MT
1969 Toyota FJ40
Vanos tools are back and ready to rent.
2011 BMW M3 6MT
1969 Toyota FJ40
Do I need a special tool for rear, upper, lower, inner, outer control arm bushings for rear suspension? Does the rtab tool work for those bushings as well?
Been going against the grain since I was a sapling.
For the rear (RTAB) you'll need a different tool than the FCAB's. Not sure about the others. At a minimum, you'll need 2 tools. Maybe someone else can chime in on the other bushings & their respective tools.
2011 BMW M3 6MT
1969 Toyota FJ40
The bentley manual simply states to push old ones out and new ones in with a shop press. So I guess I just need rtab tools. Are the rtab tools available this coming weekend? I will have all my bushings by Friday.
PM me for current availability
2011 BMW M3 6MT
1969 Toyota FJ40
New tools added to the rental list - see post #1 for details.
FYI: I'll be on vacation from Tuesday 6/14 - Sunday 6/18. I will be able to return all PM's and get tools out Sunday/Monday 6/18 and 6/19.
2011 BMW M3 6MT
1969 Toyota FJ40
So will the ABS tool reset the airbag light on a 2003 E39 530i? If so, I"d like to rent it.
RTAB & FCAB tools just came back and are available for rent again. I'll be out of town from Tuesday 6/22- Sunday 6/26 but could ship the tools tomorrow before I leave if someone is interested.
2011 BMW M3 6MT
1969 Toyota FJ40
Almost all the tools are back now and ready to ship out. I tried to PM everyone on the waiting list, please let me know if I've overlooked anyones name who previously contacted me.
2011 BMW M3 6MT
1969 Toyota FJ40
I have a few RTAB tools and Peake tools ready to ship out...
2011 BMW M3 6MT
1969 Toyota FJ40
FCAB and lollypop tools are back. I should have an RTAB tool back soon too...
2011 BMW M3 6MT
1969 Toyota FJ40
Almost all the tools are back & ready to ship. PM me for details.
2011 BMW M3 6MT
1969 Toyota FJ40
I can't seem to pm you. please contact me, I am interested in the vanos tool.
I will probably need the vanos tool set in a little bit.
Can you throw in the 18mm without the fan stuff?
Where in the bay are you? Do you ship only?
Lots of tools have come back...
2011 BMW M3 6MT
1969 Toyota FJ40
You have a PM.
Lots of tools available...
2011 BMW M3 6MT
1969 Toyota FJ40
Bump... many tools are available
2011 BMW M3 6MT
1969 Toyota FJ40
Almost everything is back with the exception of the vanos tools
2011 BMW M3 6MT
1969 Toyota FJ40
