Does anybody no where I can get the software? I did the manual swap and got these stupid tranny codes to get rid of.
You will have a lot more luck in the diagnostics section. A lot of INPA expertise there...
Do you have a OBD1 adaptor? Only the DME and EGS are OBD2 enabled.
E36 DICE MediaBridge BT and iPod support Photo location of the cabrio drain holes. Custom heated seats and lumbar support retrofit. Glovebox charging sockets and cupholders. E36 PDF Schematics UK Aftermarket E36 OBC bulbs Convert rear lights from non check-control to check-control DIY BMW E36 MFSW retrofit pictoral DIY All BMWs UK cheaper source for electrical connectors, Farnell, RS BMW INPA success E46/E39 onwards E36 vert mood lighting DIY BMW E36 puddle light and inner handle illumination DIY. E36 convertible flat bungee tension strap fix DIY BMW E36 PDF manualBMW E36 vert water in motor of tonneau area fix.
Mines OB2
You may be OK if you only have errors in the EGS to deal with.
If so try my INPA guide here.
SO you have to have both cables in the 20 pin under hood and the one under the dash at same time?
