Results 1 to 25 of 43
Thread: BMW Scanner 1.4.0 on Win 7 64 bit
    Norway, Oslo
    2004 E46 320D
    Hello guys.
    I have ordered a interface for the BMW scanner 1.4.0 from china. But it seems that the drivers are just compatible with 32 bit OS. Have someone got this working on win 7 64 bit ? and tell me how ?
    Is it possible to maybe install it on a VM ? but how to do that ? :/
    325i Cab 91 e30 *sold*
    316i 95 e36 *stolen*
    320D 04 E46 M-Tech *New*
    Why choose a BMW ? Because you deserve it =)
    Norway, Oslo
    2004 E46 320D
    Nobody that have the win 64 bit drivers ?
    May 2010
    Chicago, IL
    2002 M3C
    The only thing that doesn't work on W7x64 is NCS Expert. Everything else is the same.
    W7x64 is backwards compatible with x32, but not with 16, which is what NCS Expert is...
    I did a dual boot with a blank XP on my old laptop just for that program.
    Norway, Oslo
    2004 E46 320D
    I installed this program on a friends laptop. that is 32 bit windows. and that works well. On my win 7 64 bit. it is not possible to install this driver at all do i have to run a dual boot with maybe a xp or something in 32 bit ?
    This is the error i get when i install it.
    Syracuse
    2001 330ci
    BMW scanner 1.4 works on 64bit windows 7
    I got this to work on two of my 64bit window 7 machines, if you need help getting it to work let me know
    Cheers!
    Canoga Park, Ca
    E36 325is
    I need help getting it to work on my windows 7. can you help? please! lol
    Syracuse
    2001 330ci
    sure! what is your OS? 32 or 64bit?
    here is what I did to get it to work on my car and computer....
    So the first thing is to download this driver:
    http://www.ftdichip.com/Drivers/CDM/..._Certified.zip
    then extract it, I like using 7zip never have a problem with it.
    Next you have to go to device manager:
    1. Click start button, right click on computer and hit manage. (Sorry if you already know how to do this, just going step by step in case you dont)
    2. Click on Device manager and scroll to Universal Serial Bus controller.
    This is the weird part, I did it on two computes, for one of the computers this next step caused on of my usb ports to stop working, so its a gamble, however on my other computer nothing weird happened.
    3. Next chose one of the USB Root Hubs and right click and then Update driver.
    4. Then browse my computer for driver software
    5. Choose let me pick from a list of device drivers
    6. Then chose "Have Disk"
    7. Browse to where you extracted the above file and select ftdibus and hit ok.
    8. From the list I choose usb serial convert A and click install
    9. Just click ok through all the prompts win7 throws your way.
    10. Turn off your internet, then plug BMW scanner into car and then into computer. Win7 will say it cant install device
    11. Go back to device manger and find BMWscanner that should have a yellow ! next to it. Right click, update driver and install the same driver you did for the first usb hub. It might error out. Open up BMWScanner software and it should know show up that drivers installed and connected to car!
    If you need any help just let me know, hope it works for you too!
    Raleigh, NC
    13' 535I XDrive
    Great info! worked just fine for me too. Thanks.
    May 2012
    AZ
    2002 BMW 325CI
    So i loaded it on windows 7 64 bit and this is what happend.
    then I plugged the cable into my car and plugged it into my computer and this is the error I get.
    any ideas on how to fix it? it seems like the program is running fine. the drives seem to be good for the USB port, but maybe not for the device itself? for whatever reason it doesn't like the cable.
    May 2012
    Vrable
    E38 TDS
    here you are - 100% working driver for Win7 64bit
    http://uloz.to/xssDoKA/bmw-scanner-1...iver-64bit-rar
    Jun 2012
    Brookeville
    2002 330i
    Quote Originally Posted by keny077 View Post
    Thanks for the link.
    It does load correctly, however, then there is a virtual serial port that pops up that I cannot find the correct driver.
    Has anyone else seen this?
    Sep 2012
    Sweden
    E46
    Quote Originally Posted by tkrotchko View Post
    Does anyone know how to fix this problem? That virtual serial port also pops out for me too (Win7 doesn`t find drivers for it). I tried that "serial convert A" trick but all I got was faulty USB-port.
    Sep 2012
    WESTON
    2002 BMW 330 CiC
    Okay, newbie here with very limited knowledge of computers, a little more knowledge of cars. First question - where do I plug the cable into the car? Thought I saw my mechanic plugging it in under the dash, but I don't see anything. Thanks
    The Netherlands
    BMW 330CI DropTop
    Quote Originally Posted by sgoetz628 View Post
    Some BMW's have them on 2 places. (depends on the year)
    Sep 2012
    WESTON
    2002 BMW 330 CiC
    Quote Originally Posted by Beemer187 View Post
    That was it. Looked right past it the first time. Thanks!
    Just wondering now, meanwhile I'm unfamiliar with the electronics - is there any damage that can be done by just plugging everything in? I would certainly turn off the wifi first.
    Thanks again
    Narragansett, RI
    '01 330CIC, '00 Ford Exp, '95 Volvo 850
    can someone link me to which software you are using? I saw another site showed a link, and the product was only $32, but shipping was $25!
    maybe I found the link. Is this really $650?
    Dec 2012
    Ukraine
    1997 BMW 728 sedan
    Cal1319, thanks a lot, it works! )))
    For the first connection I chosed "usb serial convert A" driver, and for the second "usb serial port" - and all is fine!!!
    Thank's again!
    Feb 2013
    Peterborough, United King
    BMW e46 320CD 2006
    hi, I've got a BMW e46 320cd 2006 and I wanted to plug in the "scanner" to detect what's the problem with my engine and why the engine light is still "ON" at the dash board. I'm not a professional in this so be pacient, please. I have brought "BMW READER"
    (BMW CODE READER SCANNER E38 E39 E46 E53 E83 E85 DIAGNOSTIC TOOL X3 X5 Z4)
    but it didn't come with any drivers or software ect. I know where to plug this in but when I've downloaded the "bmw scanner 1.4.0 it ask me to turn the ignition on and click continue. Which I did. Then after that it came up with an error, that there is no drivers.
    P.S.
    I'm running windows 7 Ultimate 64bit
    what do I have to do? Can someone help me please?!
    Nov 2013
    Elmsford, NY
    2002 BMW M3 Convertible
    does anyone know if this cable works for BMW Scanner 1.4?
    http://www.one-stop-electronics.com/...&product_id=16
    FOLLOW US ON INSTAGRAM
    @The_Mom3ntum_Group
    PERFORMANCE: ECIS Intake with RE Silicon boot, Euro
    Headers, RE Rasp Term, TopSpeed Muffler, AA Tune, RE Stage 1 Clutch, RE SS Clutch
    Lines, RE FCABs & RTABs, Bilstein PSS10s, Custom CSL Brakes Upgrade, Stop
    Tech SS Brake Lines
    TBC.....
    IcemanBHE's Avatar
    IcemanBHE is offline ¿pǝpɹɐʇǝɹ noʎ ǝɹɐ
    Wichita,KS/FortCollins,CO
    (4x7)+8=36
    It will not.
    Oct 2003
    Ocean City, MD
    05 M3 03 Range Rover
    I'm getting super frustrated, I have tried everything on this post to get this 1.4.0 scanner working on my windows 7 64 laptop and it just wont work at all. Any other suggestions? I've downloaded the 2 drivers from both the posted links and neither work, and nothing on the disc included with the scanner worked. If only i still had my old laptop with XP on it! Thanks in advance for any help!
    2005 Individual Dakar Yellow M3
    Gruppe M Titanium Section 3, Black front/side Grilles, Dakar front reflectors, Escort Passport 9500i, gominigo front tag bracket, WeissLicht Tag lights, Dynavin, Powerflex RTAB's, BBS CH's, Carbon Fiber CSL trunk/rear diffuser/front splitters, AFE SuperStock
    R.I.P. 1995 M3
    R.I.P. 1996 328i
    SOLD 1985 325e
    SOLD 2001 330i
    May 2009
    SAint John, NB
    08 E92 328xi
    Not to re-kindle an old thread ... I got this working just fine with the instructions above.
    Can this same ODB2 adapter and cable be used with any other software ? Or only the PA Soft 1.4.x stuff ?
    Sep 2003
    Birmingham, UK
    BMW 850 and E55 AMG
    You must right click on the icon and run in XP sp3 Compatibility.
    I've been installing and uninstalling for an hour now until I tried that.
    Giftschrank Projekt
    Mar 2006
    Corona, CA
    E46 ZHP | AA Turbo E36
    Damn...life saver. Thank you. Worked like a charm for me.
    May 2014
    los angels
    bmw e46 2007
    you can free download this software,here is the link:http://down.careucar.com/bmw-scanner...er-locking.zip. I download it and it can worked very well. It help me solve many problems.
    Kindly Note: Please connect the device to your car before you open the software.
