Page 1 of 6 123456 LastLast
Results 1 to 25 of 143
Thread: HVAC Nightmare: Heater Control Valve
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    Searching the archives (keywords: "heater control valve"), I see those afflicted by a hot-air-all-the-time HVAC problem. Well, now I have it too .
    In my case, it's hot air at the left (driver side) defrost/footwell. All other controls function normally.
    Archived posts say: replace heater control valve. Fault code readout confirms: left side heater valve. So I replaced the HCV with a new one. No change. Other posts say disconnect batteries to reset IHKA controller. Did that. No change. Fault code remains: left side heater valve.
    What the....?
    So I tested the new HCV. Using 12 volts, the solenoids ground just fine. In fact, my old HCV does too!
    I'm beginning to suspect this is an electrical problem with the A11 control module, NOT a hardware problem. The ETM shows A11 pin 21 controls the left solenoid. Apparently, it's simply not receiving a ground signal from that pin.
    Archived posts indicate some of you had this exact same problem but no one reveals how it was ever resolved. This is my worst nightmare: an HVAC problem buried in uncomprehensible and outrageously expensive circuitry.
    Frankie
    Texas, USA
    frankies-bmw.com
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The heater matrix (both sides) is always hot - even when no heat is demanded, it is the mixing flaps that control the heat into the cabin. The mixer flaps are moved by stepper motors under control of the IHKA unit. Disconnecting the battery re-initialises the flap positions so that was worth a try.
    The question is whether the mounting points for the stepper motor is damaged or the IHKA is not demanding the motor to move. The most common fault is that the mounting gets damaged.
    My BMW Repair YouTube Channel
    Greater Seattle Area
    '93 850Ci,'01 X5
    Frankie, I have the same issue as you. The next step I was going to try is to replace the IHKA controller itself 64 11 1 392 082, if that doesn't work then the sword 64 11 8 390 015 then try the limit switch, 64 11 8 367 838, all of which are not cheap to replace!.
    Good Luck,
    Chris
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    both of you need to read Timm's post again....
    Oct 2007
    Middle TN
    Too many/Not enough
    Good luck....I have a 91 M5 and a 91 850 both with the same issue. On the M5 I clamp off the heater hose to the interior in the Summer. On the 850, it slowly and eventually transitions from heat to AC or from AC to heat.
    Current Garage:
    91 e34 M5 - spoiled & demanding 27 y/o -glanzshwarz
    91 850i/6 -another spoiled & demanding 27 y/o- schwarz-gone but never forgotten
    06 325i - undeserving, spoiled & demanding 27 y/o daughter's DD-hellrot
    03 MINI Cooper S JCW -spoiled & demanding, yet deserving wife's DD - Chili/Panther
    05 X3 3.0i -family workhorse - diamond schwarz
    12 X5 3.5d - torque monster - space gray metallic
    86 GMC Cabellero - Old Faithful 32 y/o DD BMW Support Vehicle
    08 Cub Cadet 19HP 46" hydrostatic- yard vehicle
    88 Schwinn Sierra - 1WD Off Road Vehicle
    e31 & OHC BMW CCA #385540
    Dec 2003
    SJ, CA
    '00 Z3C, '70 XJ6
    The IHKA controller in the console was the culprit in mine. I broke down the circuitry and found where there was a supply voltage issue so that it wouldn't ground and close the heater valves. I supplied voltage to the pin and all has been 100% for the past four years or so.
    Sorry, since it was so long ago and I didn't document it, I can't recall exactly what the fix was. But it is possible! I had never seen it mentioned before on the boards at that time either, but I knew that there was an issue with the e32s so I plugged on anyway.
    Good luck, I would replace the IHKA controller or start digging into wiring diagrams
    2.8 Z3 coupe + 6 speed || 200kW electric 1970 Jaguar XJ6
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    Likewise, mine was also the console unit - replaced and all is well.
    Bryson, wanna fix my old one? 8-)
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    The heater matrix (both sides) is always hot - even when no heat is demanded, it is the mixing flaps that control the heat into the cabin....
    This makes sense....it's how a water faucet works.
    But then, what's the purpose of the heater control valves? That is, if water flows all the time and the blend flap controls the output air temp, why the need for a valve?
    Presuming the valves are for some other purpose than to regulate vent temp, why do I have a fault code that reads: left side heater valve?
    So...please confirm my understanding:
    1) Heater control valves are either fully open or fully closed (no intermediate positions) and therefore do not regulate vent temperature, right?
    2) The aux water pump, then, must come on when HCVs are open and turn off when closed, right?
    Oct 2007
    St Albans, UK
    1991 850i 1989 325i
    From the IHKA manual:
    "Temperature regulation on E31 vehicles is accomplished by solenoid actuated water valves,
    normally help open by spring pressure, are pulsed closed by the IHKA E31 control module
    to regulate the flow of how coolant through the heater cores (and, thereby, the core
    temperatures)."
    The manual is on e31faq on Wuffer's site BTW.
    I had the same problem, it was the heater controls on mine too. I still have a problem in that the temp changes are much too sudden and the fan control is mad, so I think that's the sword. If you have access to DIS then you can get diagnostics from the IHKA module. It tells you what each sensor is reading (including core temps, ambient, etc) and what position each control is set at (at least what the module thinks they are), plus it gives you fault codes. I did a lot of digging on this problem and it seems that the IHKA control module itself is rarely at fault, it's normally the heater controls.
    Dec 2003
    SJ, CA
    '00 Z3C, '70 XJ6
    The sword repair is also a DIY if you feel like getting involved in some fairly simple circuitry. I just did mine a few weeks ago and it works great Search for the e32 DIYs and you'll save yourself a pretty penny!
    Tom, I'll be sure to crack my HVAC panel open next time I have the console out for you
    The heater valves do more than just open/close. The aux pump is only needed at low rpms as there isn't enough pressure to drive flow through the heater core. My understanding is that it is not tied to the opening/closing of the heater valves, can't be sure where this impression came from though
    Mar 2010
    Arlington, Tx
    850Ci, Venza, Prius
    How much is the IHKA?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Quote Originally Posted by Frankie View Post
    The heater control valves maintain the correct core temperature in each side of the matrix. The temperatures are monitored by two thermocouples, one for each side of the matrix. Once the matrix is up to temperature you will hear the valves clicking away maintaining the correct temperature.
    This set temperature is needed by the IHKA to approximate the correct settings for the mixer flaps (as it takes a while for the heat to be measured by the 'sniffer' in the control panel).
    If the water valves were left open all the time, the matrix temperatures would constantly change and the correct flap settings could not be approximated. You would also end up with very hot air coming out of the vents when pushing the engine hard - just at the time you least need it!
    The water valves and thermocouples essentially provide a 'thermostat' for the matrix. The mixer flaps can then be finely controlled to provide the correct cabin temperature - without this 'thermostat' the cabin temperatures would fluctuate quite considerably.
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Quote Originally Posted by Imndeep View Post
    Good Luck,
    Chris
    the "sword" controls the fan speed.
    I agree, most likely the stepper motors are not securely mounted anymore. You can remove the MID and look back there to see if the flapper linkages are actually moving as you switch the HVAC control between the different settings.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    La Costa, California
    1994 850CSi #125
    Quote Originally Posted by Bryson View Post
    Bryson, I too have this issue of heat always on. I defeat it by pressing the recirculation button which seems to also turn on the A/C to some extend. But then it gets too cold eventually so I would really like to learn more about how you fixed this by "supplying voltage to the pin."
    Can you elaborate? Was this a pin INSIDE the IHKA or something leading TO the IHKA? Were you able to determine why the voltage was not being supplied, as in, was this a broken lead or do you believe there might have been something else wrong but you found this to be a viable workaround?
    Where is the IHKA located - meaning are there 'brains' in the form of some other module behind the main Control Module located below the OBC?
    Sorry for all the questions - just trying to understand things before I start tearing apart the car. Thanks in advance.
    Taylor in Carlsbad
    P=(p x v3 x Cd x A)/2
    Dec 2007
    Dallas, TX
    IHKA controller is located on the firewall (in the cabin), accessible from the passenger footwell
    1994 850CSi #125
    Is it one of the three black boxes located in the 'rack' with the LKM?
    Taylor in Carlsbad
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Quote Originally Posted by TxGR8White View Post
    Now, that's a good idea!
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    Quote Originally Posted by NickF View Post
    ...The [IHKA] manual is on e31faq on Wuffer's site...
    Thanks Nick! I forgot about this resource. (Good to hear from you. If you remember, you gave me moral support about a year ago with a front-end vibration problem.)
    Quote Originally Posted by rchan11 View Post
    Over $1000. This is what I meant when I said "outrageously expensive circuitry".
    The heater control valves maintain the correct core temperature in each side of the matrix..
    Informative again, thanks Timm! Your new info has changed my take on the problem.
    The concensus seems to point toward the left temperature control wheel as the culprit, not the IHKA module. Perhaps this is the chain of events:
    1) Left temp control wheel malfunctions. "Shows" full hot to the IHKA module.
    2) IHKA commands left HCV to full open and mix flap to full hot blend.
    3) IHKA throws "left side water valve" fault, since valve is open even when engine is cold.
    I will perform some wiring tests next week on the HCV and look at the left mixing flap motor. I will also see if more diagnostic readouts of the IHKA are possible.
    Thanks to everyone who chimed in. This help makes these forums such a great resource.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The driver's control wheel will over-ride the passenger's setting when at the extremes of travel (past the detent). If you feel the passenger's control wheel is the problem, adjust the driver's control to fully cold, the passenger temperature should now drop.
    Dec 2007
    Dallas, TX
    Quote Originally Posted by taylorpatterson View Post
    nope, it is in the passenger footwell
    Dec 2003
    SJ, CA
    '00 Z3C, '70 XJ6
    Taylor, I'm referring to the controller beneath the head unit - the one in the console.
    The pin was indeed inside the IHKA controller (the one I'm referring to in the console) and my fix was a viable workaround for some internal failed circuitry that reflowing the solder joints did not fix. As the pin is supposed to get voltage at all times, bridging it with another has solved my problem.
    I seem to remember that there was something to do with the AC and/or recirc that would force the system cold again, but it was so long ago that I've forgotten now.
    I'll be pulling the console out to remove all the automatic wiring harnesses, so I'll be sure to open it up, get some details, and snap some pictures then. I'll probably just update this thread, so make sure you've subscribed to notifications
    1994 850CSi #125
    You doing it this weekend? Want some company/help?
    Taylor in Carlsbad
    Dec 2003
    SJ, CA
    '00 Z3C, '70 XJ6
    I wasn't planning on doing it this weekend, I suppose I could tomorrow, but are you still up north near SLO or are you going to be in SD? I'm leaving on Sunday afternoon for a week in San Diego
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    ...The IHKA controller in the console was the culprit in mine....
    Quote Originally Posted by Wuffer View Post
    ...Likewise, mine was also the console unit...
    Uh....after re-reading this, I think we have a terminology problem. Are you guys referring to the control panel (head unit, with temp control wheels and push buttons) or the control module (behind the dash, in front of heater box)?
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    I am referring to the unit on/in the center console, with the roller wheels and fan controls.
    Located below the radio, above the shifter - the one with crummy roller wheel lighting... 8-)
