I have been looking into the MAF story and this is what I found out and have confirmed.
It saves you a lot of $ to do it this way!
OK there are a few ways to find the MAF you need:
Bosch # 0280218002 (for VW)
VW # 06a906461a
Bosch sensor # that is in your car now: F00C2G2029 and is replaced/superseded with the F00C2G2032
Here are a few pics of the VW MAF and the sensor.
The sensor
Old and new
The VW sensor can be found at autohauz for a little over $70, just swap the sensor and drive!
Although a bad sensor does not have to throw a code, the check engine light can come on, without giving the MAF code.
Other codes that can be solved with a new MAF are Adaptive Value Bank 1 & 2
Also changing an aging MAF can help you reduce the MPG by as much as 20%, this also goes for the O2 sensors.
Bosch states that the MAF and O2 sensors are usable goods and not replacement parts, they advise to change them is every 70-80k, and it will impact the MPG and the way the car feels and responds to the throttle.
Max @ oembimmerparts has great prices for the O2 sensors, he maybe even start to stock the VW MAF
http://www.oembimmerparts.com/catalo...18/8927083.htm
Hope this helps some out there!
Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
