Hello guys,
I have very annoying and unpleasant sound coming somewhere from underneath steering column. It sounds like some part got loose and hitting it whenever I hit pot hole or bump.
What this might be?
Thank you in advance,
siny528i
Endlinks!
Is your front suspension still stock?
How many miles in your baby?
Thanks for posting here!
I got 171227 right now.
I recently changed JUST Front Struts after reading your 1998 BMW 528i COMPLETE FRONT SUSPENSION OVERHAUL . They were leaking badly. I thought that sound was the part of their failure, but it still there.
I know what you gonna say about at this mileage anything can go bad and stuff. I think you are right, but I dont want to do Complete Overhaul.
I just want to eliminate that sound...
Then change the endlinks next. They usually fail around 50-60K, let alone 171K!
Very easy to do.
Thanks cnn!
The reason I asked about Stabilizer RUBBER MOUNTING and SUPPORT is becasue I had same problem with my 240sx. That time it was bad RUBBER MOUNTING.
Anyway, if I wanna change all RIGHT and LEFT SWING SUPPORTs (End Links), Stabilizer RUBBER MOUNTING and SUPPORT, is it hard to get to and replace Stabilizer RUBBER MOUNTING and SUPPORT?
Do I have to put it on Jacks or Ramps will be enough?
Well, cnn, I guess you were right!
Today I went to my local Pepboys for flat fix and found this:
I was going to do my rear endlinks anyway and thats why already ordered them. I hope having it loose like this didn't do any damage other than that unpleasant noise I was hunting for.
BMW CCA 434493
On another note, your picture above showed that you have ANOTHER problem.
Your rear brake hose is cracked, just like mine 1 month ago LOL!
Then I did a complete brake overhaul and here is the DIY:
DIY: 1998 BMW 528i Brake Hydraulic System Overhaul (Brake Hoses, Caliper Seals/Dust Boots)
http://forums.bimmerforums.com/forum...php?p=21926370
Heya guys,
There is another issue that most likely was causing this noise.
While installing new front Rotors and Bearings I found that my Left Tie Rod gone bad:
There is also a free play of left wheel when you try to move it left to right.
I am going to get both Left and Right Tie Rods online.
How hard is it to replace them?
Is it worth it since I am planning to do All 4 Tires rotation for FREE and then alignment for $45 at my local shop. I thought maybe its a good idea to ask them to do Tie Rods while they are there and then do the alignment. They said they will do them for $80 with my parts.
What do you think?
siny528i
BMW CCA 434493
siny528i,
Lemforder only. You can get them at EACeuroparts.com.
This is why I recommend that people do a complete FRONT suspension overhaul, otherwise you will be in and out of that place (front suspension) many times. I learned it the hard way on my 1998 Volvo V70: changed the tierods, 3 months later the endlinks, then 3 months the strut mount (on top of the strut), then 6 months later the control arms, then the CV boots etc. What a waste of time in and out of that place 5 times in a year!!!!!
So, best is to do them all. Info is here:
http://wwww.bimmerfest.com/forums/sh...d.php?t=399580
Hey cnn,
Thanks for your guidelines! Especially EDIT Jan 14, 2009!
I just did my Front Tie-Rods.
I gotta tell ya it was a piece of cake job. If you can call it a job.
Somehow I thought they tightened to Steering Rack deeper under the car, but it was right there.
Unfortunately that rattling sound still there...
BMW CCA 434493
Hello guys,
I did my Control Arms with proper loading (according Bentley) and torque. I actually did them 2 weeks ago. Sorry for the delay with update!
I also put good but USED tires, but didn't do alignment yet.
It performs much better now. Steering wheel is not shaking. "Bad Bearing" noise is gone OR at least I can not spot it, BUT knocking sound, like something loose and vibrating, is still there.
I wish someone who knows drive my car and tell approximately where its coming from.
Thanks a lot,
siny528i
BMW CCA 434493
I tell you I've gone thru what your going thru. And its the steering rack. There is no other explanation.
I have replaced every part replaceable on the front end that had to do with the suspension, and I have that knocking sound. My guess its the rack.
No, seriously, I've been thinking...
It doesnt necessary mean that I have to replace WHOLE Steering Rack?
Could be loose Steering Rack mounting bolts?
Or so called flexible joint pinch bolt?
Anyway, can it be visually seen orinspected for damage/malfunction?
Does anyone fix this problem before or been in that area?
Any ideas?
siny528i
BMW CCA 434493
I got the same noise and was planning to to a suspension overhaul but worried it won't fix this. I mean I planned to do suspension work regardless but want to get rid of this noise!
Keep me updated in your venture...I'm going to a shop tomorrow to see what's what.
I would replace everything in the front end including the rack mounts before replacing the rack. They seem to be pretty sturdy to the point where there are seal kits for them because the seals wear out before the rack does. That being said, if you live in an area with lots of potholes, then that may be your problem.
Good luck and don't forget to post the outcome.
Geoff
2002 Schwartz II 530 5spd Sport Premium
2011 X5 35i
1966 Mustang f/b longterm project
1996 Malibu ski boat
9 1968-73 2002s, all gone......
1995 530i w/4.4 conversion (sold).
1985 535i w/mods, sorely missed.
BMWCCA member #110881
He who dies with the most toys, wins....
Hey Geoff,
I live in Staten Island, so it is a Pothole Paradise like the rest of NYC So there are Rack Mounts? That most likely figures.
This noise does not sound like something broken but rather LOOSE and hitting back up to Steering Column. It happens only at slow speed and you hit pot holes. Its heard BEST when you slowly roll on gravel road and whole car vibrates.
I will see what I can do. Most likely next week I will take it to mechanic but just for inspection.
BMW CCA 434493
yes it definitely sounds like something worn out and moving more than normally banging into something...
