I have a non HK sysyetm in my E46 sedan. I have a blown mid range or atleast I think so because its buzzy/ rattly and was looking at a few diys. I read that my car is an 8 ohm set up for the tweeeters/ midrange and 2 ohm for the mid bass,
I found a few diy's where people use 4 ohm Vifa speakers for a good alternative but would that work on my 8 ohm car? I think all those diy's were on HK set ups but idk how much a difference they are to mine.
I tryed to ask in the audio section but they were no help.
ask in the car audio section they should know
2016 328ix | Wagon | M-Sport | Alpine White | Black | iND | 513M | AC Schnizter | MPerformance |
2005 330CiC | Sparkling Graphite | Black | 6MT | ZHP
2004///M3 | Individual Sterling Gray | Imola Red | 6MT | Eisenmann | Style 163M | SOLD
2011 X5 35d | Black Sapphire | Nevada Brown Cinnamon | Sports Package | Totaled
2009///M3 | Interlagos Blue | Pallidum Silver | DINAN | MPerformance | DCT | SOLD
2002///M3 | Steel Gray Metallic | Imola Red | 6MT | Convertible| SOLD
2006 X5 4.8iS | LeMans Blue Metallic | Creme Beige | SOLD
2006 ///M3 | Silver Gray | Black | Competition Package (ZCP) | 6MT | SOLD
2000 ///M5 | Oxford Green Metallic II | Caramel Nappa Leather | BMW Individual Black Birch Trim | SOLD
2003 X5 4.6iS | Black Saphhire Metallic | Black Sport | SOLD
2006 X3 3.0i M-Sport | Silver Gray | Terracotta | SOLD
PM BennyZ...he should know...and while you're at it, tell him to get his ass back to our section...
06/99 328I | 124K MILES | M54B30 MANIFOLD SWAP | MS42 -> MS43 DME CONVERSION | STILL JUST AS SLOW AS EVER
BennyZ knows for sure, but its not a good idea to change to speakers with different impedance (ohms).
If you put a 4 ohm speaker on a circuit that was designed to drive a 2 ohm speaker, the speaker will be 1/2 as loud as before. You'll need to turn the volume button up on the amp which will likely start clipping sound and that won't sound good. If you listen to it low, its OK, but if you want to increase volume output, its likely to clip (distort).
Stick to the right 2 ohms for mid range bass.
These are pricey : http://www.bavariansoundwerks.com/ca...Speaker-Pairs/
Any right impedance speaker with approximate frequencies to the original will do.
You're best of staying with the same resistance (in ohms) speakers if you're driving them with the same factory stereo.
At a constant voltage (as we have in our cars, 14.4v), the current demands of the speakers increase proportional to a decrease in speaker resistance:
I=V/R (Current = Voltage / Resistance)
The power output of a speaker is defined by:
P = I*V (Power = Current * Voltage)
so at a constant voltage the power output increases proportional to the current (which increased inversely proportional to the speaker resistance)
Whether you can run the 4ohm speakers depends on whether your head unit can handle them (unlikely) and whether the speaker wires running along the car can cope with double the current capacity if you change a 8ohm speaker for a 4ohm (also unlikely)
As Oli77 said, increasing the resistance of a speaker from stock will decrease the volume of that speaker (it decreases the power to the speaker). Stick with stock resistances if you're using the stock head unit. If you have an aftermarket amp that can handle a variety of speaker types, that's a whole nother story.
Waehrik's post is correct with his summary. However, the audio signal from the amp is an A/C output where speaker ohm values are measured in impedance not resistance. Impedance = A/C resistance. I see where he uses P=IE (P=I*V) to demonstrate amp load. This is where it gets interesting as other variables come into play when you add frequency.
If you load the amp with a higher value speaker than it was designed for, you may have to adjust volume to get "unity gain" to achieve the same db output as the original speaker. In that you can't control just the mid-bass level for example, you may have undesirable results. Should you change out all speakers to let's say 8 ohm where the factory installed 4 ohm, you may find the volume knob has to be driven harder (1/4 turn) to get the same level as original. The amp can handle the load but is closer to clipping meaning there's less headroom and it won't go as loud. This is only noticeable with frequencies that suck power - Mid-bass and subs. Mid range and tweeters are barely noticeable (if at all) when substituting 4 ohm units into factory 2 ohm locations you will find they work fine. There are many variables with speaker design where a replacement unit may have better efficiency than the factory flavor where even though it may have a higher ohm value, it may produce better, even louder sound due to its efficiency.
Basically, there is considerable voo-doo going on here and no one is wrong with their contributions. But it's frequency dependant. Amps shouldn't be loaded with higher ohm speakers with demanding frequencies - mid-bass and subs. You will take away overall headroom and gain. But mid and high freq. speaker impedance is more forgiving to the amp because it's not "working" hard to drive them. Therefore, substituting a 4 ohm mid or tweeter will not be audibly noticeable or damage anything. Size and depth are more of a concern.
Note: installing a 4 ohm mid-range into an 8 ohm location will work and not be twice as loud as thought. I didn't mention this above as the thread was talking about going from a lower to higher value. The 4 ohm speakers, in this case, will be less working load on the amp but again, due to the cone material, voice coil winding and magnet pull, efficiency may be more responsive. Trust me, they won't suddenly seem punchy because of the lower impedance.
Speaker sizes are exactly the same in both the Standard and HK audio systems. The main difference between the two systems are the speakers impedance rating.
6.25" Midbass
HK : 3 ohms
Standard : 2 ohms
2.5" Midrange
HK: 4 ohms
Standard : 8 ohms
.75" Tweeter
Hk : 3 ohm
Standard : 8 ohm
Last edited by White Knuckles2; 02-07-2011 at 12:43 AM. Reason: Automerged Doublepost
Anything Made can be made Better
