Ok there is too much info in this thread flying around.
First off, its not your VCG or fuel pump. How many time are you going to replace that VCG anyway? Will this be your third time? Some drop of oil on the plugs is not a big deal and something you should change when its nice and warm and have nothing to do. Its not part of the issue at hand.
With those three codes set. it seems like the engine was starved of fuel for that split moment which led to the stall. The lean codes (0171/0174) are the cause of the main code which everyone seems to be going at. That cylinder caught a lean condition, which in turn caused it to misfire heavily, which in turn told the DME to shut off the pump. THAT is the turn of events. The coil is fine as well. Can it go bad? Absolutely. When in doubt, move its position.
I would put money on a bad injector. We have swapped out a couple of M54's in the past month or so and we experienced all those codes. Those stupid lean codes haunt our E39's on a daily basis. For the most part, they just annoy but in your case, they actually told you what the deal was.
In rare cases, your Bank1Sensor1 O2 has called it quits.
Another FP5241 Creation
Parting out M54 Engine. Intake and all. Cats avail as well. PM ME!
Gumbi, thanks for the info. I was reading this:
http://repairpal.com/OBD-II-Code-P0171-and-P0174
and also read, "Fuel Pressure could also cause a lean condition. If the fuel filter is clogged or the fuel pump pressure is low, there could be higher level of oxygen in the exhaust also. Most of the time though, the ECU will compensate for the reduced fuel volume. So this is one of the least likely causes of a lean code."
I've had CEL's before, but never needed a tow. Will do a smoke test tomorrow to rule out any leaks. Saw where kerryb and you went thu this:
http://forums.bimmerforums.com/forum....php?t=1377410
Replacing the CCV tomorrow regardless of what takes place.
Here's a fuel pump relay for anyone out there reading:
https://wiki.bentleypublishers.com/d...elay+locations
I hope it's not an injector because then you're replacing the one and staring at the other five. Could be a vacuum leak, will smoke the car tomorrow...
Thanks.
may teh force be with you b5er... watch mickelson choke this afternoon and have a few beers..
It could be this, and it could be that....
Take it to someone that will know.
No comment. *
* = if you searched around you'll find literally thousands of posts where very, very bright BMW brethren chased the identical codes I have and paid $1,900.00 to a dealer here or there and still had the codes. This isn't your fuel pump which was screaming so loud it could be heard in Japan in 1985 and yet required a video with "What is this noise?" as your car stalled and stammered every ten miles. No, this is a ghost on a highly maintained e39. A smoke test might reveal a few things AND if you see the intelligencia above, very sound opinions, you'd clearly see that it taint' so very easy.
And fyi, wasn't it BMW Tech Master just last week who told me my noise in the drive side rear was a Jet Suction Pump? Man that would've been a waste of $125.00 and all those gas fumes during the replacement would've dropped my IQ below 100. I need to maintain triple digits as long as I can...
Best of luck finding the problem bimmer. Keep us updated!
Resident Third World Country Advisor
It took me almost five hours to do today:
1). OEM CCV and all hoses. I hate hate hate this job and will never ever do it again. Gumbi's father in law is a wizard at it and over 5-7 cigarettes he can install them better than I could. It took me 3 hours. My CCV was laden with mayo. Several hoses were more clogged than Michael Moore's arteries. Cleaned out the Air Distribution Piece. Cleaned out the ICV. Cleaned out the DISA Valve and gave the DISA some black RTV around it's gasket. My throttle body was crystal clean and I regret not having a new gasket but the original gasket looked fine and all is well.
2). Six new Bosch coils. Very easy job. Before I did this, I borrowed a smoke machine. Other than wreaking of Ash Wednesday, I could not find any vacuum leak in the car.
3). Fuel Pump Relay. This is the light green relay behind the glove compartment. Not so easy to get to and I'll post the part number for it as even BMW might struggle for a bit to find the proper part number.
Car idled sooooo much quieter. I swear the idle dropped 100 rpm and in terms of noise..a healthy CCV makes the car's engine purr like a kitten and idle not just more smoothy, but simply quieter.
At this point after a test drive I had two more things to do. I replaced the Fuel Filter (and regulator) and gave her seven new quarts of Royal Purple.
The fuel filter that was in my car had 15K miles on it, I simply replaced it with a 'shotgun therapy' approach and not a 'rifle therapy' approach. The coils that were in my car had 75K on them and I replaced all of them, not just cylinder #1 as there is only one way to do it.
The car's RPMS are willing to fly up to 5K with a small tap of the gas pedal. My car used to have a very very slight miss, a tiny flutter like a heart murmur. She is now running, at 135K miles as if she has 13.5K miles.
I DO HAVE an OEM Fuel Pump in stock and will replace it in a month or two (or sooner if she breaks down and I need to get towed again).
All seems really well now. I just took her for a 30 minute spin and was laughing at the pep in the little 2.5 liter engine.
Fuel Pump next to-do.
Engine cover with new VCG to-do.
Rear brakes in April to-do.
Can't wait for effin winter to end...this winter has been hardcore and I look foward to more projects in the Spring.
If anyone has an extra Engine Cover (aka Cylinder Cover) PLEASE LET ME KNOW. I feel like a fool buying one, but I gotta bite the bullet as my VCG leaks no matter what I do.
Thanks to every single person who weighed in with ideas for the codes. Thanks to all who offered moral support. Getting flat-bedded sucks. I wouldn't wish it on anyone, ever. We should all be able to press a 'hyperspace' button and at least be able to warp home where we can fix the car.
Thanks.
Glad to hear you're back and running. And Yes, flat bed sucks big time.
I am betting your valve cover gasket leak was due to the clogged CCV.
There is nothing wrong with your valve cover, but I know how much you love buying parts...
LOL!
Going to keep an eye on it. It is frustrating as the leak this time is 6x within each spark plug well...not the area to have any leak if you're going to have one! Installing new coils into ports that had just a few drops in each spark plug well...it hurt my feelings.
I'd certainly rather spend $200.00 (cylinder/engine cover's cost) on other stuff for sure!
Car drove like a dream to work today. Fuel pump will be done in 4 weeks time, regardless. The CCV system in our cars IS a joke!!!
Keith, I have a whole M54 engine being parted out. I got parts, you need parts like engine cover. Let me know. I has pics.
How about you hang onto the engine cover and I pick up a pack of Marlboros and some beer. Your FIL is the perfect man for the VCG. I'd love to come over in March. I just need winter to die-down a bit and also wait for my budget (just dropped a load on this thread alone lol).
Please save the engine cover. A new VCG and an hour or so in your shop and I would truly enjoy knowing that it won't drip a drop of oil for a long time.
My engine cover is "from 9/2002" and is part # 11127512839 see here:
http://www.realoem.com/bmw/showparts...72&hg=11&fg=15
If it matches....please and thank you.
Good to hear she is running better Keith. Also surprised to hear there were not any vacuum leaks but I know you run a tight ship!
Did you break the hose ends off in order to disconnect the old CCV hoses?
Could an over-flowing gas station pump cause the Leak Detection Pump to fail?
Last year, when filling-up the car, the gas station pump did not automatically shut off, but instead shot gas all over my car.
This happened twice within a period of 2 months.
Could the over-flowing gas from the gas station pump cause the Leak Detection Pump (that is connected to the Charcoal Canister) to fail...???
Thanks!
Jason
Thanks!
Jason
In a wishy-washy non-committal way,
YES
/.randy
YES
/.randy
Why was this thread revived from the dead?
2000 BMW 740iL | 225,XXX miles | VW MAF | Bavarian Auto Coils | Timing Chain and Guides DIY Complete | M60 Manifold | BDC Polished Throttle Body| Custom Tuned | Performance Gearing 3.46 LSD| Magnaflow mufflers |
|1997 ///M3/2/5 | 104,XXX miles | Boston Green Metallic|2006 X3 3.0 SAV|121,XXX miles| Silver|
Thanks Randy for the reply...!
I guess my other question is that could a bad Leak Detection Pump, or bad Charcoal Canister cause:
1. the Fuel Pump to work harder?
2. And/ or cause lack in acceleration, as when you are accelerating, then hit the gas (punch-it), and then nothing happens (the doesn't rev to accelerate - bogs)...?
Because I wanted to...
And, my car is having problems related to the topic.
Last edited by Jason5driver; 06-26-2012 at 12:53 AM. Reason: Automerged Doublepost
