I own a 2002 330 ci with a 5 speed manual transmission. Occasionally, the shifter, especially after going into 5th gear, will not return to "center" when in neutral. The shifter will stay stuck to the right. I can still drive the car, but it is difficult to shift from 2nd to 3rd without going straight into 5th. Then out of the blue, the shifter will pop back into center. Any ideas?
This is a fairly common issue.
There are "detent springs" in your trans, and they occasionally fail to return the shifter to center.
These items are externally serviceable, although you'll have to remove the trans. If you search long and hard, you'll be able to find a BMW service kit for these detent springs/pistons. The piston of this assembly is becoming stuck in it's bore, and should be replaced, and the bore cleaned thoroughly.
Be aware that dirty fluid aggravates this problem, but the bores aren't likely to be cleaned and pistons unstuck through a fluid change alone.
Chris Powell
BMWCCA 274412
Thanks for your input. Does this kind of service need to be performed by a BMW mechanic? Will the problem worsen if not repaired?
There is a very lengthy thread addressing this issue here:
http://forums.bimmerforums.com/forum...ad.php?t=48002
This thread is aimed at the problem on E36s but this issue and transmissions are the same I believe.
And the best single write-up that I have seen on it is here:
http://webspace.ringling.edu/~dplassma/bmw_diy/shift_pins/shift_pins.html
In my experience, not all that many shops are familiar with this repair and even the dealer in my area was unaware of the repair kits which meant they had little or no experience with this repair. If you want a shop to do this job, I would highly recommend that you find one who is already experienced in doing it - otherwise you will likely be paying their R&D for the tools and techniques (which are not necessarily straightforward).
Good luck
Tom Tice
'15 M3
'98 M3/4/5 - RIP
'01 740i 6sp
'93 325iS SE36 #110
