Greetings
Considering that i gathered most of the information i needed for the job here at this forum, i figured it would be only fair to share here.
I just finished a 5 speed conversion on my '99 e39 528 touring:
Cost: ca. $1500 (not counting the income from the forthcoming sale of auto parts)
Time: 24 hrs over 4 days from on-the-jacks to on-the-road - done alone with manual tools in a freezing Michigan garage. With a helper and the car higher in the air and power tools you are looking at less than 8 hrs if you know what you are doing
Tools needed: lots!
Biggest pain: probably the exhaust, believe it or not.
Help needed?: only for clutch bleeding
Coding tools used: Carsoft interface, Ediabas with NCS expert and DIS.
Unexpected/unplanned parts: front exhaust gaskets (duh) and driveshaft nuts (Auto are M8, manual are M10)
Leftover jobs: cruise clutch switch (didn't feel like running lines behind the dash) and reverse lights (lines ran from trans to DME, just need to run one to the IKE)
Biggest boo boo: trying to steal 12V/ground signals from the EWS when running the clutch start switch (bad, use the brake switch signals instead, which is what the wiring schematics indicate anyway)
The swap was very straightforward. BMW makes most things very easy. It is amazing how much money they put into the flexibility of the car to accept either one or the other configuration.
My plan was to do a complete picture writeup but it was too damn cold and the car was pretty greasy down there.
If anyone has specific questions, let me know and i will fill you in. I may write things out as well later this week.
Cheers.
Wow...well done!
2007 Carerra S
2009 E91
1990 Toyo PU - POS
2000 E39/5
1976 911
Yes!
Nice!
Congrats!
Did you lay on cardboard or concrete?
Not a firearms expert
AWE-SUM
someday I may need this thread
congrats on your swap, it's a great feeling when it's all said and done!
Creeper....otherwise i would be in the hospital right now....
Couple of notes:
I think the tune is still auto as it still gives me blip when i shift...Will have to look into that over the weekend.
2nd gear is giving me a bit of vibration at higher RPMs, shifter shakes noticeably. Guibo and the driveshaft look OK, although there were no special marks on the driveshaft/guibo to align to, so the overall assembly may be out of balance?
No stalling or surging or other items i had with the good ole GM 4 speed, gets in gear and goes.
Excelent work!!
I would love to do the 6sp conversion on my 540iT. Did not know what all it would intale with the programing.
There are others that are probably more knowledgeable ( e.g. Mark@EAC) regarding that particular swap, considering that that particular combo never existed in the US? So i would assume that the DME coding may not be as straightforward.
Mine was an existing combination so it was fairly simple. Attached link walks you through the necessary steps. They are for a E36 but they worked for me.
http://www.bimmersport.co.nz/forums/...pic=30526&st=0
The assumption is that you would have the coding equipment and software to do it. If no, check out the Diagnostic software forum.
Been searching all day for a more current thread so I'm bringing this one back to life. Anyone have a list of all needed components. I hate finding out I am missing stuff mid job.
I had the same problem when i swapped out my transmission. Ontop of the transmission where the shifter assembly connects to the actual transmission its held by a clip. I broke my clip originally when removing it the first time and i didn't replace it, so in second gear the shifter vibrated. Just a though you could have a whole whole different issue, and yeah the hardest part is the damn exhaust, its one whole peice and its a major PITA i wish it was like the 3 series when it unbolts apart halfway through.
