Will do. Have to wait for tomorrow.
Check valve was installed in the right orientation.
I think it's a great and proven setup...but my installation location was bad. I didn't want to clog the cat with carbon...
I will post pics tomorrow and see if you guys can find a problem somewhere
Jimmy
Technique Tuning Stage 2 on 9:1 built motor(SOLD)
Boost Addiction Support Group Member
Official "My Wife is Awesome" Club Member
Just an idiot with a wrench...
I love mine
I think the other guys should chime in here...but my instinct is down stream of the O2 as it could clog/screw up the readings...but yes I think closer to the turbo the better.
I am going to reattempt in a few weeks. I am tired of hauling exhaust system components to the shop to weld. I need a welder at home! After 2 guys have seen identical results on vastly different setups...I see no reason why this shouldn't be a good solution...so I'm sticking with it until I have tried everything.
I just ran out of time to work on the car and need to unwind before another start of a crazy schedule. I will post pics of my second try as I don't want to tear things apart just to get pics.
Jimmy
I'm thinking of relocating my o2 sensor bung a lot closer to the turbo then putting the Vibrant just down from that.
edit: now that I think of it my 02 sensor might be right after the turbo pre-cat but my wideband is post cat. Zepp can you confirm is your o2 sensor right after the turbo?
Jimmy
Rod and jmargo what epoxy did you all use for your fittings??
Also, jmargo any pictures of the "small set screw?"
This is my signature....
man i am so confused with all of this, i should have not bought a turbo kit. one thaats not even a full kit.
That's a good idea.
To be really honest I haven't worked on the car in a while. I'm happy with it as it stands...and my oil leaks are gone now that I dropped and re-sealed the oil pan.
I'll come back to this project...but with a car that holds it's fluids, runs great, and requires very little maintenance...car projects are on the back burner for now.
Jimmy
Here it is...
Sias Tuned, Vortech Blown, 3.2L S52...456WHP/360WTQ
Sias Tuning | HowertonEngineering | Davis Motorsports Club
That looks nice! Plus, it's that little extra precaution. Where did you source that "set screw"?
does it touch the fuel rail, line or clamp? Looks nice.
"If you can leave black marks from the time you exit a corner till the time you brake for the next turn, then you have enough horsepower." --Mark Donohue
^ that looks great
is everyone running a catch can with this setup? Mine is in and seems to be working great, car is very happy.
I am however blowing a bit of smoke that i wasnt before on engine decel as if the extra vac is pulling more oil vapor out of the crankcase.
I eliminated my McKinney catch can and ran the vent to the M5 cycl sep from the TT kit then to the exhaust.
I like the pretty AN fittings the shop hooked me up with.
[ame]http://www.youtube.com/watch?v=PSqjXEEPpII[/ame]
I dunno why everyone is messing around with a catch can exhaust valve set up... A boosted engine will not work with a factory style ccv system... Or the aftermarket it seems like either...
Just run a hose to a breather and enjoy your life!!!!
So check this out
Wonder how well that location works.
^ probably not so good, considering the outlet for ccv is tapped at the lowest possible point of top of the head.
I'm not sure the logic behind your statement. Why does height affect anything? If the crank case is pressurizing it should be applied pretty equally over everything
